09-07-2009, 08:37 | #1 (permalink) |
No Life Poster Join Date: Feb 2004 Age: 49
Member: 53198 Status: Offline Sonork: 100.1589499 Thanks Meter: 819 | ChineseMiracle v2.91 can't write full flash please fix Phone : OPPO A400 MCU : MT6223P Flash :[ST]M58WR06AKT (16MB) ChineseMiracle can't detect side flash chip Code: COM5 [VCP4] selected module v2.91 Device: Autodetect 6205-6227 NOR Checking data, wait... advanced flash detection enabled Action: write NOR flash write: Firmware MT6223C_08A_GEMINI_PCB01_GPRS_MT6223P_S00.ZT_T322_CH_SU1_SET_V22_90516__fullflash_20090907-142019.B0M.bin skip: Customization/Language Pack skip: Customization skip: Eeprom/ffs Boot ... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing [6223:8A05:8A00]... CPU: MT6223 high speed boot On chip: 0011:876F:000C status: FF boot packet size: 0400 Release Power button now ! Boot Done Initialize ... detecting chip #00 in region #00... flash: EC240200000000:2BEA0000000000 error: detected/calculated [01000000/00010000] chip size mismatch, chip detection failedflash: AMD/Fujitsu std [def 0008x002000 00FFx010000] 16Mb detecting chip #01 in region #00... flash: EC240200000000:2BEA0000000000 error: detected/calculated [01000000/00010000] chip size mismatch, chip detection failedflash: AMD/Fujitsu std [def 0008x002000 00FFx010000] 16Mb detecting chip #02 in region #00... flash: EC240200000000:2BEA0000000000 error: detected/calculated [01000000/00010000] chip size mismatch, chip detection failedflash: AMD/Fujitsu std [def 0008x002000 00FFx010000] 16Mb detecting chip #03 in region #00... flash: EC240200000000:2BEA0000000000 error: detected/calculated [01000000/00010000] chip size mismatch, chip detection failedflash: AMD/Fujitsu std [def 0008x002000 00FFx010000] 16Mb number of flash chip/regions detected: 04/01 Initialize Done Set baud ... 921600 Set baud Done Initialize bootcode ... Initialize bootcode Done Check firmware integrity ... detect device rom info... detection phase #1... detect device rom info finished rom info structure: 2nd [enhanced] generation startup code area #1 is Ok startup code area #1 backup saved: E:\Infinity Box\ChineseMiracle\backup_security\id.1C16A9A3.[MT6223C_08A_GEMINI_PCB01_GPRS_MT6223P_S00.ZT_T322_CH_SU1_SET_V22_90516.BIN_2D21C535].rpl ==================== New firmware detected (v.2.91, database date: unknown): MT6223C_08A_GEMINI_PCB01_GPRS_MT6223P_S00.ZT_T322_CH_SU1_SET_V22_90516.BIN This firmware is missing in support area. If this phone is good and working: - make "Read full flash" operation - send flash backup files to support: [email protected] or upload files to http://rapidshare.com or http://4shared.com - include in your e-mail full text from phone back label (phone name etc.) ==================== rom info detection finished device-id: 1C16A9A3 rom info protocol ver: 04 ver. sw 1: MT6223C_08A_GEMINI_PCB01_GPRS_MT6223P_S00.ZT_T322_CH_SU1_SET_V22_90516.BIN ver. sw 2: ZT_T322_CH_SU1_SET_V22_90516, CA3ADED2 ffs offset/size: 00E00000/00200000 detect device sec info... detection phase #1... . detect device sec info finished Check firmware integrity Done Check firmware content ... Check firmware content Done Backup required data ... Backup required data Done Patch required data ... Patch required data Done Special operation ... Special operation Done Write ... detect device sec info... detection phase #1... . detect device sec info finished startup code area #1 check... warning: rpl file not found: E:\Infinity Box\ChineseMiracle\id.1C16A9A3.[MT6223C_08A_GEMINI_PCB01_GPRS_MT6223P_S00.ZT_T322_CH_SU1_SET_V22_90516.BIN_2D21C535].rpl warning: rpl file not found: E:\Infinity Box\ChineseMiracle\id.1C16A9A3._MT6223C_08A_GEMINI_PCB01_GPRS_MT6223P_S00.ZT_T322_CH_SU1_SET_V22_90516.BIN_2D21C535_.rpl startup code area #1 backup loaded startup code area #1 calculation... startup code area #1 fixed detecting startup code area #2... startup code area #2 is absent file saved: E:\Infinity Box\ChineseMiracle\backup_security\MT6223C_08A_GEMINI_PCB01_GPRS_MT6223P_S00.ZT_T322_CH_SU1_SET_V22_90516__system_log_1C16A9A3_2D21C535_20090907-142828.B0X.bin Area: Firmware flash: EC240200000000:2BEA0000000000 error: detected/calculated [01000000/00010000] chip size mismatch, chip detection failedWrite: Firmware error: error# 0000002B error: flash write error: 00000000:00002000 detect device sec info... detection phase #1... . detect device sec info finished Write Done Finalization ... Finalization Done file saved: E:\Infinity Box\ChineseMiracle\backup_security\MT6223C_08A_GEMINI_PCB01_GPRS_MT6223P_S00.ZT_T322_CH_SU1_SET_V22_90516__system_log_1C16A9A3_2D21C535_20090907-142835.B0X.bin Finished, time used: 45 sec Remove/Install battery now ! |
09-07-2009, 09:42 | #2 (permalink) | |
Member: 53198 Status: Offline Sonork: 100.1589499 Thanks Meter: 819 | Full flash read from working phone Download here MT6223C_08A_GEMINI_PCB01_GPRS_MT6223P_S00.ZT_T322_ CH_SU1_SET_V22_90516__fullflash_20090907-142019.B0M.bin Quote:
09-08-2009, 02:56 | #4 (permalink) | ||
Member: 53198 Status: Offline Sonork: 100.1589499 Thanks Meter: 819 | Quote:
i try all version but same problem i think this phone is have new flash, new firmware so ChineseMiracle can't detect size flash chip for write flash or repair security. Quote:
Waiting..... for news Thanks | ||
09-09-2009, 02:59 | #6 (permalink) |
Member: 53198 Status: Offline Sonork: 100.1589499 Thanks Meter: 819 | Thanks All phone is new and full working ( 10 phone wait for edit langpack ) More info i try flash with other tool: Spiderman read full flash ok but can't write, CPF,VE,Flash tool read and write ok but after that phone can't power on. Wait for new........... |
11-08-2009, 10:39 | #9 (permalink) | |
Member: 130995 Status: Offline Thanks Meter: 35,229 | Quote:
I was a problem with new type of phone hardware. Please, try to use this software for flashing: http://www.infinity-box.com/download...acle_v2.97.rar It was tested with new flash chip types. Waiting for your results. | |
ChineseMiracle v2.96 can't detect new flash chip | Star75 | Infinity-Box | 4 | 11-22-2009 09:34 |
ChineseMiracle v2.91 can't boot phone, Why ?? | coolderheart | Infinity-Box | 4 | 09-05-2009 18:53 |
ChineseMiracle E770i or E778 need full flash | Freshbol | Infinity-Box | 0 | 03-24-2007 20:30 |
K310, K510 can't unlock with UB, please fix this problem | gsm-brest | Universalbox | 4 | 01-29-2007 19:45 |
i can't write full flash 3210 in PC-III 800 | Siemens man | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 12 | 05-13-2002 14:04 |
