Old 04-21-2009, 18:03   #1 (permalink)
Registered User
Member: 292907
Sonork: None
Thanks Meter: 51
Question Motorola C261 restart problem
I was trying to unlock a c261 from Virgin network. After doing the direct unlock the phone kept on restarting. I formatted it and this is the log and still having the restart problem:
COM5 selected
Action: format
Device: C261
Checking data, wait...
Connect...
Press and HOLD Power button...
rom version: 0411
Connecting...
initial boot phase complete
Release Power button !
Connect Done
Boot...
Boot Done
Set Baud...
460800
Set Baud Done
Check Flash-1...
SW version: 0.1.31
HW version: MOTOROLA_E58S
LP ver: LPA3_0132
Flex ver: FLEX_90_64_3903
cpu id: 08B6
Check Flash-1 Done
Check Flash-2...
reading ...
file saved: C:\Program Files\InfinityBox\Moto01\backup_eeprom_calibration __20090421-115506.34E.bin
Check Flash-2 Done
Write...
unexpected answer: 54
Write Done
Finished, time used: 117 sec
Remove/Install battery now !
What other way is there to fix this.
i even try writing the backed up eeprom, but still the same thing. Help.
The Following User Says Thank You to curtisbcm For This Useful Post:
Old 04-21-2009, 18:14   #2 (permalink)
Member: 98928
Thanks Meter: 464
Write...
Write Done
her is your problem!
try to flash your phone full flash and try unlock after it
good luck
The Following User Says Thank You to bavesore For This Useful Post:
Old 04-21-2009, 18:18   #3 (permalink)
Registered User
Member: 292907
Sonork: None
Thanks Meter: 51
Question
Originally Posted by bavesore View Post
Write...
Write Done
good luck
So I should full flash again and then do direct unlock and problem will be solved?
Old 04-21-2009, 18:31   #4 (permalink)
jabed_net's Avatar
Member: 538824
Thanks Meter: 274
pls flash phone by this file version
C261_0.1.76
then unlock
The Following User Says Thank You to jabed_net For This Useful Post:
Old 04-21-2009, 18:33   #5 (permalink)
Registered User
Member: 292907
Sonork: None
Thanks Meter: 51
C261_0.1.76
then unlock
Ok, will do and post result.
Old 04-21-2009, 19:40   #6 (permalink)
Registered User
Member: 292907
Sonork: None
Thanks Meter: 51
Question
C261_0.1.76
then unlock
It did not work. See log:
COM5 selected
Action: unlock
Device: C261
Connect...
rom version: 0411
Connecting...
Connect Done
Boot...
Boot Done
Set Baud...
460800
Set Baud Done
Check Flash-1...
SW version: 0.1.76
LP ver: LPNA_0176
cpu id: 08B6
Check Flash-1 Done
Check Flash-2...
reading ...
file saved: C:\Program Files\InfinityBox\Moto01\backup_eeprom_calibration __20090421-133757.34E.bin
unlock step-1 Ok
unlock step-2 Ok
unlock step-3 Ok
unlock step-4 Ok
error: unlock step-5.1 failed: A410
error: errorcode#10: can't find required data, eeprom damaged
Finished, time used: 36 sec
Is there a next way to try.
Old 04-21-2009, 22:30   #7 (permalink)
Member: 130995
Thanks Meter: 35,227
Hello,
1. write back original eeprom, it should be created automatically during first operation
2. try to make unlock again
Old 04-22-2009, 19:22   #8 (permalink)
Registered User
Member: 292907
Sonork: None
Thanks Meter: 51
Red face
Originally Posted by InfinitySupport View Post
Hello,
Hi bro, I did this and phone is still re-starting.
Old 04-23-2009, 00:41   #9 (permalink)
tavoonly's Avatar
Member: 586318
Thanks Meter: 112
Dear friend, I spent more than one month trying to fix this problem and the only way I could solve it was using the eeprom repair option with the smart moto software from smart clip.
Do not waste your time, look for someone who own smart clip and get your phone fixed.
PD. Writing the original eeprom does not work. I tried all those steps,
BR FROM NICARAGUA.
The Following User Says Thank You to tavoonly For This Useful Post:
Old 04-23-2009, 01:03   #10 (permalink)
Member: 560185
Thanks Meter: 101
sir is the supply of the unit good? are you just using battery or regulated power supply? cause if your only using battery maybe the supply is nit enough... if the supply is good, then try to repair eeprom using smart clip via infinity interface..
b.r
The Following User Says Thank You to amats211 For This Useful Post:
Old 04-23-2009, 23:10   #11 (permalink)
Member: 130995
1. Are you sure that you have flashed phone with it's original eeprom backup that was created before unlock ?
2. Make "format ffs" once again.
Post here operation log.
Old 04-24-2009, 15:29   #12 (permalink)
Registered User
Member: 292907
Sonork: None
Thanks Meter: 51
As soon as I try again will do.
Old 04-24-2009, 16:50   #13 (permalink)
Registered User
Member: 292907
Sonork: None
Thanks Meter: 51
Question
Here is log:
COM5 selected
"smart write" active
Action: flash
Skip: Firmware
Skip: Language Pack
Skip: Flex
Write: Eeprom
Device: C261
Connect...
rom version: 0411
Connecting...
Connect Done
Boot...
Boot Done
Set Baud...
460800
Set Baud Done
Check Flash-1...
SW version: 0.1.32
LP ver: LP12_0132
Flex ver: C 73'DAF n
cpu id: 08B6
Check Flash-1 Done
Check Flash-2...
reading ...
file saved: C:\Program Files\InfinityBox\Moto01\backup_eeprom_calibration __20090424-093808.34E.bin
Check Flash-2 Done
Write...
Writing: Eeprom
eeprom write address adjusted
Write Done
Finished, time used: 31 sec
COM5 selected
Action: format
Device: C261
Connect...
rom version: 0411
Connecting...
Connect Done
Boot...
Boot Done
Set Baud...
460800
Set Baud Done
Check Flash-1...
SW version: 0.1.32
LP ver: LP12_0132
cpu id: 08B6
Check Flash-1 Done
Check Flash-2...
reading ...
file saved: C:\Program Files\InfinityBox\Moto01\backup_eeprom_calibration __20090424-094102.34E.bin
Check Flash-2 Done
Write...
Write Done
Finished, time used: 89 sec
As you can see I did exactly what you instructed me to do, now all I see on phone screen for the passed hour is this message:
'FMGR_Waiting for Total Completion MMI'
What next should I do?
Thank you.
Old 04-24-2009, 19:45   #14 (permalink)
Member: 744454
Sonork: shakil
Thanks Meter: 26
I did lots of c261 of this problem just by formatting no need to flash full or eeprom. this happens because mostly many people use camera to capture photos and this phone has inbulid memory area which goes full with no space or little space so it restarts.
Old 04-24-2009, 20:04   #15 (permalink)
ps_tech's Avatar
Member: 448980
Thanks Meter: 136
Hi!
I've been encountered that problem few weeks ago after unlocked. and I fix it using infinity box by fullflash with firmwares 0.1.69 then format ffs again after flash, but be sure your battery is full while flashing or use power supply adapter.
BR,
PS_tech
c261 restart problem matrix1 Motorola ODM 13 07-24-2007 20:05
motorola c261 restart sanjeewa57 Infinity-Box 7 03-15-2007 20:11
motorola c261 restart problem . evil.zone Infinity-Box 1 01-19-2007 12:35
i have 1 pieces motorola c261 restart problem aurelmarius1 Infinity-Box 2 08-28-2006 14:30
C261 restart problem.. please help.. dlanor0221 Infinity-Box 0 06-18-2006 10:33
Page generated in 0.22691 seconds with 9 queries
