03-13-2019, 17:35 | #1 (permalink) |
No Life Poster Join Date: Oct 2004 Location: Madeira Island Age: 47
Member: 85718 Status: Offline Thanks Meter: 449 | Clone Welcome Huawei P20 Pro firmware Chinese Miracle II [MTK module] v 1.58 Operation : Check / Read Info [ v1.58 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 21 ] Sync... Inital Boot Ok! BB_CPU_PID : 6580 BB_CPU_NME : [MediaTek] MT6580_S00 BB_CPU_EXT : 0xCA00 , 0x8A00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x00000000 BromVer : 0x00FF BLVersion : 0x0001 PreLoader : Active [ Boot with PL ] BootLdrSS : NORMAL with PRELOADER Processing DA stage DA Select done, will use MTK_AllInOne_DA_v5.1624.16.07 Sending and initialize DA ... Running DA ver.4.2 on BBID : 0x94 NAND Flash : NOT INSTALLED eMMC Flash : 90014A4838473264040507A13D368117 Initialize Memory ... DRAM already initialized by Preloader DAgent sent , init HW now eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0x90 , OEM : 014A [eMMC] : FLASH_INF : [HYNIX] , d2G8 [eMMC] : FLASH_CID : 90014A4838473264040507A13D368117 [eMMC] : FLASH_BRT : 0x00400000 , 0x00400000 , 0x00400000 [eMMC] : FLASH_LEN : 0x00000001D2000000 [eMMC] : FLASH_UCP : 7456 MiB [eMMC 8 GiB] DEV RID : 0x7D96EB9031FBD6101D8A04BD08B56AB3 INT RAM : 0x00020000 EXT RAM : 0x40000000 [1 GiB] BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! [AP] : Initial info read Ok! Brand : WELCOME ProdName : P20 Pro ProdModel : P10 Device : P20Pro AndroidVer: 8.1 MTKxCPU : MT6580 MTKxPRJ : ALPS.L1.MP6.V2_DROI6580.WEG.L SECURITY : IMEI_SW [1] : 3589657792XXXXX IMEI_SW [2] : 3589657792XXXXX BTMAC Addr : DE2A46658089 WiFi MAC : 000000000000 MODEM : BaseBand : MT6580_S00_MOLY_WR8_W1449_MD_WG_MP_V6_P5_1_wg_n EXTRA : LCD : Not info available LCD Res : 960x480 TOUCH [0] : ft3427_zaw875 CAM [0] : sp2609sub_mipi_raw CAM [1] : sp2509_mipi_raw CAM [2] : sp2509sub_mipi_raw CAM [3] : sp2609_mipi_raw CAM [4] : gc2235_mipi_raw CAM [5] : gc2235sub_mipi_raw MODEM : f9_we_l_hspa_1258 LOCALE : en_US zh_CN zh_TW es_ES pt_BR ru_RU fr_FR de_DE tr_TR vi_VN ms_MY in_ID th_TH it_IT ar_EG hi_IN bn_IN ur_PK fa_IR pt_PT nl_NL el_GR hu_HU tl_PH ro_RO cs_CZ ko_KR km_KH iw_IL my_MM pl_PL es_US bg_BG hr_HR lv_LV lt_LT sk_SK uk_UA de_AT da_DK fi_FI nb_NO sv_SE en_GB hy_AM zh_HK et_EE ja_JP kk_KZ sr_RS sl_SI ca_ES Done! Elapsed: 00:00:16 Reconnect Power/Cable! |
The Following 2 Users Say Thank You to ct3im For This Useful Post: |
03-27-2019, 01:47 | #3 (permalink) |
Member: 163 Status: Offline Thanks Meter: 7,785 | If you still have the phone, I can upload ... b.r. Alex
__________________ Always press THANKS button if my post was helpful! Please DO NOT send me PM's for help, You can ask for help on forum Do not post THANKS posts - use thanks button ! ALWAYS use SEARCH button before posting! |
The Following User Says Thank You to Brka For This Useful Post: |
03-28-2019, 20:33 | #4 (permalink) |
Member: 85718 Status: Offline Thanks Meter: 449 | [QUOTE=Brka;13595753]If you still have the phone, I can upload ... b.r. Alex[/QUOTE Now I have solved, in support have a new firmware for this model. Anyway thank you for your cooperation. |
03-31-2019, 20:22 | #5 (permalink) |
Member: 163 Status: Offline Thanks Meter: 7,785 | What I found out while playing with that one ... Factory rom is full of Trojans/visruses ... There are some cleaned roms for that device ... B.r. Alex
The Following 3 Users Say Thank You to Brka For This Useful Post: |
04-11-2019, 21:48 | #7 (permalink) | |
Member: 163 Status: Offline Thanks Meter: 7,785 | Quote:
ASSEMBLY 05.03.17 - Download Pay attention, there are two different preloaders, one with preloader_f9b1_tc_g4 - first link another with preloader_aeon6580_weg_l_l100 - second link To be sure which one you have - make backup first and see preloader name, or check size ... preloader_f9b1_tc_g4 = 121 KB (124,304 bytes) preloader_aeon6580_weg_l_l100 = 122 KB (125,372 bytes) p.s. This is stock rom, not cleaned or something. If you want to get rid of trojans, you will need TWRP recovery installed, and custom rom. ONE ROM V1.1 - Download Test TWRP Recovery: Welcome_P20_Pro_clone_TWRP_recovery b.r. Alex
__________________ Always press THANKS button if my post was helpful! Please DO NOT send me PM's for help, You can ask for help on forum Do not post THANKS posts - use thanks button ! ALWAYS use SEARCH button before posting! | |
The Following 14 Users Say Thank You to Brka For This Useful Post: |
04-14-2019, 09:30 | #8 (permalink) |
Member: 130995 Status: Offline Thanks Meter: 35,227 | Dear Sirs, If you have good flash files and if you want to share it with other users please use IOS File Uploader Tool Please do not upload password protected or damaged files, all of them will be deleted after upload. Thank you ! |
06-19-2019, 18:35 | #9 (permalink) | |
No Life Poster Join Date: Mar 2010 Location: Unknown
Member: 1274304 Status: Offline Sonork: 100.1617965 Thanks Meter: 195 | Quote:
The Following User Says Thank You to Denva For This Useful Post: |
08-21-2019, 08:12 | #10 (permalink) |
Junior Member Join Date: Mar 2013 Location: dhaka
Member: 1896791 Status: Offline Thanks Meter: 0 | EMI : SRC : INFINITY-BOX_INTERNAL_EMIDB_v0 INIT : 0xBC : LP/DDR2 [ 0x00000000 : [ 0 B ] ] DA : Failed to configure DA! ERROR : 00000BC4 : DEVICE NOT FOUND Error : Fail to init protocol! Remove battery, cable. Check cable/connection/driver! Check SW hint! Repeat operation! |
08-21-2019, 15:31 | #11 (permalink) | |
What is it ? | |
09-25-2019, 14:52 | #12 (permalink) |
Major Poster Join Date: Aug 2006 Location: Ukraine
Member: 324787 Status: Offline Sonork: No sonork Thanks Meter: 32 | ASSEMBLY 09.11.18 one with preloader_f9b1_tc_g4 - link Factory rom is full of Trojans/visruses |
The Following 5 Users Say Thank You to Jonic77 For This Useful Post: |
06-20-2020, 12:36 | #13 (permalink) | |
Crazy Poster Join Date: Mar 2020 Location: africa
Member: 2949792 Status: Offline Thanks Meter: 5 | Quote:
Please post new links | |
07-06-2020, 23:18 | #14 (permalink) |
Junior Member Join Date: Jul 2020 Location: freiburg, germany Age: 32
Member: 2961763 Status: Offline Thanks Meter: 0 | Need the Clean ROM and preloader Dear Brka, I#m currently in my project with the "WELCOME P20 Pro" and I messed my phone by installing the false preloader. I have no backup an now after connecting it wit SP loader I receive "ERROR : S_FT_ENABLE_DRAM_FAIL (4032)" All available Preloaders didn't fix the phone, so maybe I need the preloader_f9b1_tc_g4 Thank you very much for your Help, Best bta003 |
09-05-2020, 19:14 | #15 (permalink) | |
No Life Poster Join Date: Jul 2005 Location: In My PC Age: 46
Member: 165971 Status: Offline Thanks Meter: 65 | Quote:
the link is dead | |
The Following User Says Thank You to bendou For This Useful Post: |
