01-08-2018, 22:04 | #1 (permalink) |
No Life Poster Join Date: Oct 2017
Member: 2766801 Status: Offline Thanks Meter: 182 | hisense f10 7.0 frp failed help please Start at : [08/01/2018 / 21:50:32] Operation : Format FileSystem [ v1.53 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 20 ] Sync... Inital Boot Ok! BB_CPU_PID : 6737 BB_CPU_NME : [MediaTek] MT6737M|MT6737_S00 BB_CPU_EXT : 0xCB00 , 0x8A00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x05000000 BromVer : 0x0005 BLVersion : 0x00FE PreLoader : NOT Active [ Erased ] BootLdrSS : LOCKED with CUSTOM BL Processing DA stage DA Select done, will use MTK_AllInOne_DA_v5.1624.16.07 Sending and initialize DA ... [DA_ERROR] : Boot Error! Operation Failed Elapsed: 00:00:03 Reconnect Power/Cable! Finish at : [08/01/2018 / 21:50:35] Start at : [08/01/2018 / 21:50:39] Operation : Format FileSystem [ v1.53 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 20 ] Sync... Inital Boot Ok! BB_CPU_PID : 6737 BB_CPU_NME : [MediaTek] MT6737M|MT6737_S00 BB_CPU_EXT : 0xCB00 , 0x8A00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x05000000 BromVer : 0x0005 BLVersion : 0x00FE PreLoader : NOT Active [ Erased ] BootLdrSS : LOCKED with CUSTOM BL Processing DA stage DA Select done, will use MTK_AllInOne_DA_v5.1624.16.07 Sending and initialize DA ... [DA_ERROR] : Boot Error! Operation Failed Elapsed: 00:00:03 Reconnect Power/Cable! Finish at : [08/01/2018 / 21:50:43] Please if there is any solution on how to bypass it manually let me know, any concern or contribution will be appreciated thanks |
