12-26-2018, 15:31 | #1 (permalink) |
Freak Poster Join Date: Apr 2014 Location: Una,gujarat
Member: 2166052 Status: Offline Sonork: 100.1678339 Thanks Meter: 56 | Vivo Y81 Showing only 3GB after removing pattern & frp using CM2 i have vivo y81 i removed pattern using CM2MT2 by selecting model vivo y83 & frp remove using android tool via ADB ...i have same 2 handsets but in both showing only 3GB instead of 32GB ...if i flashing it throws error so now how can i flash it using cm2 or how i fix this issue logs are following.dear cm2 team please give me some solution fast for this........ |
12-26-2018, 15:31 | #2 (permalink) |
Member: 2166052 Status: Offline Sonork: 100.1678339 Thanks Meter: 56 | Card found : XXXXXXXX , v0137 Infinity-Box Chinese Miracle MediaTek Service Module [ MTK ] v2.02 Load IDBase v12974 Ok! Update configuration ... Update Ok! Load IDBase v12974 Ok! Preloader [HW DEV] Info : EMI : DEV : MT6765 EMI : SRC : preloader_k62v1_64_bsp.bin EMI : CNT : 0008 EMI : [00] : eMCP : eMMC+LP/DDR3 , ID : 150100524436344D42 : VEN : SAMSUNG | DEV : RD64MB : RAM : [ 4.00 GB ] EMI : [01] : eMCP : eMMC+LP/DDR3 , ID : 150100524836344142 : VEN : SAMSUNG | DEV : RH64AB : RAM : [ 4.00 GB ] EMI : [02] : eMCP : eMMC+LP/DDR3 , ID : 150100474436424D42 : VEN : SAMSUNG | DEV : GD6BMB : RAM : [ 3.00 GB ] EMI : [03] : eMCP : eMMC+LP/DDR3 , ID : 90014A484247346132 : VEN : HYNIX | DEV : HBG4a2 : RAM : [ 4.00 GB ] EMI : [04] : eMCP : eMMC+LP/DDR4 , ID : 150100444836444D42 : VEN : SAMSUNG | DEV : DH6DMB : RAM : [ 4.00 GB ] EMI : [05] : eMCP : eMMC+LP/DDR4 , ID : 150100445636444D42 : VEN : SAMSUNG | DEV : DV6DMB : RAM : [ 4.00 GB ] EMI : [06] : eMCP : eMMC+LP/DDR3 , ID : 90014A68423861503E : VEN : HYNIX | DEV : hB8aP> : RAM : [ 3.00 GB ] EMI : [07] : eMCP : eMMC+LP/DDR3 , ID : 90014A484347386134 : VEN : HYNIX | DEV : HCG8a4 : RAM : [ 4.00 GB ] Operation : Write Flash [ v2.02 ] Repartition : Enabled Flash Verify : Disabled Reg.Pre-Erase : Disabled Verify HW/SW : Enabled SData Backup : Disabled Safe UserData : Disabled Files :22 [FL] : Set : recovery-verified.img [FL] : Set : survival-verified.img [FL] : Set : oem.img [FL] : Set : efuse.img [FL] : Set : md1img-verified.img [FL] : Set : md1dsp-verified.img [FL] : Set : spmfw-verified.img [FL] : Set : scp-verified.img [FL] : Set : scp-verified.img [FL] : Set : sspm-verified.img [FL] : Set : sspm-verified.img [FL] : Set : lk-verified.img [FL] : Set : lk-verified.img [FL] : Set : boot-verified.img [FL] : Set : logo-verified.bin [FL] : Set : odmdtbo-verified.img [FL] : Set : tee-verified.img [FL] : Set : tee-verified.img [FL] : Set : vendor.img [FL] : Set : system.img [FL] : Set : cache.img [FL] : Set : userdata.img [FL] : Total size : 0x1497EB874 [ 5.15 GB ] 1. Make sure device is powered off. Power off, if need. Wait 20 seconds after 2. Insert USB cable in phone Waiting for device connection ... PTFN : MediaTek PreLoader USB VCOM_V1632 (Android) (COM6) MODE : PRELOADER PORT PORT : 6 Waiting BOOT ack ... PRELOADER : ACK confirmed! BROM : Init BROM BROM init passed! CHIP : MT6765 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0000 TYPE : MODERN RAPHAEL BROM : SecLevel : 0x00000005 BROM : SecMode : SBC+SDA BROM : PRELOADER PORT MODE : Vivo : Y83 | Manual : Disabled AGENT : Look for suitable BootChain in DA ... AGENT : MTK_AllInOne_DA_VIP.bin AGENT : Found MT6765 AGENT : MTK_DOWNLOAD_AGENT BROM : Sending 1st DA ... BROM : DA sent BROM :Transfer control to DA ... DA : AGENT started! DA : SYNC DA : MODE : PRELOADER DA : EXT_RAM initialized! DA : BOOT to 2nd DA ... DA : 2ND stage confirmed! DA : SYNC with DA passed! DA : Receiving HW info SRAM: 0x00040000 [ 256.00 KB ] DRAM: 0x30000000 [ 768.00 MB ] EMMC: 90014A68423861503E0344D036FA5551 EMMC: VEN : HYNIX | OEM : 4A01 | DEV : hB8aP> EMMC: BOOT1 : 0x00400000 [ 4.00 MB ] BOOT2 : 0x00400000 [ 4.00 MB ] RPMB : 0x01000000 [ 16.00 MB ] USER : 0x747C00000 [ 29.12 GB ] CHIP : MT6765 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0000 , EVOL : 0x0000 RNID : D00FEAF635CD3EBAC5BD1BCE505B8B48 DA : USB : HIGH-SPEED Boot done! [FL] : HW verification passed! SEC_DL : False (RAPHAEL) SEC_ID : 0x494E46494E495459424F584245535432 [FL] : RePartition [FL] : RePartition Ok! [FL] : Flashing now ... Write : RECOVERY Write : SURVIVAL Write : CUST Write : EFUSE Write : MD1IMG Write : MD1DSP Write : SPMFW Write : SCP1 Write : SCP2 Write : SSPM_1 Write : SSPM_2 Write : LK Write : LK2 Write : BOOT Write : LOGO Write : ODMDTBO Write : TEE1 Write : TEE2 Write : VENDOR Write : SYSTEM Error : Flashing failed! Seems as some of MANDATORY section of FW is damaged! If device alive and work - send report! Reconnect Power/Cable! |
01-09-2019, 20:32 | #7 (permalink) |
Insane Poster Join Date: Aug 2006 Location: Romania Age: 40
Member: 327867 Status: Offline Thanks Meter: 12 | 1. Factory meniu reset - not solve 2. Reset from fastboot - not solve 3. Reset factory (all from infinity) - not solve Flashed with another version (2.2.15) not solve, in meniu at space it say 25.25Gb are occupied by firmware and only 2.98Gb free. |
01-09-2019, 20:58 | #8 (permalink) | |
Freak Poster Join Date: Dec 2010
Member: 1477125 Status: Offline Thanks Meter: 88 | Quote:
Go to about phone.. Tap 7 time on buld number... Go to developer option.. 1st oem unlock. 2 usb dibug on.. Then factory reset from setting... Hope your problem solve | |
01-10-2019, 04:56 | #11 (permalink) |
No Life Poster Join Date: Feb 2005 Location: GSM WORLD
Member: 118520 Status: Offline Thanks Meter: 3,551 | HELLO @chauhanyash70; YOUR PHONE IS ENCRYPTED STORAGE YOU CAN CHECK IN SECURITY OPTION ITS NOT CM2MT2 TOOL PROBLEM BEFORE FORMING THE PHONE STORAGE WAS IN ENCRYPTED IN SETTING BY THE USER OF PHONE GOOD LUCK! ______________________ WORKING ON MY BRAIN |
01-10-2019, 19:05 | #13 (permalink) |
Member: 1477125 Status: Offline Thanks Meter: 88 | Hello.. Flash with ota flash file (sd card update from recovery mode) https://vivo.com/en/support/support-.../system-update Go here and download update file Then post result Best of luck |
01-11-2019, 03:41 | #15 (permalink) | |
Member: 2166052 Status: Offline Sonork: 100.1678339 Thanks Meter: 56 | Quote:
Sent from my SM-A750F using Tapatalk | |
