Old 12-20-2017, 11:24   #1 (permalink)
ntothel's Avatar
Member: 266180
Thanks Meter: 25
Infinix X555-H538A-N-170521V167 invalid Imei
Hi there i need some idea i have this phone Infinix X555 with invalid imei. i try to write permanent and shows done as below
IMEI [00] : 35XXXXXXXXXXXX
IMEI [01] : 35XXXXXXXXXXXX
Set IMEI [00] : 35XXXXXXXXXXXX
Set IMEI [01] : 35XXXXXXXXXXXX
Prepare finished. Security check required!
Wait for phone...
Phone found! [ 11 ]
Sync...
Repair done!
Done!
Elapsed: 00:01:11
Reconnect Power/Cable!
But when i check still Invalid imei so i try with Temporary/parmanent and here are the result below..
Wait for phone...
Phone found! [ 11 ]
Sync...
Init Ok, waiting for phone ...
Reading initial info, wait...
Phone Info :
BB : AT+EGMR=0,0
HW : AT+EGMR=0,4
SW : AT+EGMR=0,3
MM : AT+EGMR=0,1
VR : AT+EGMR=0,2
SN : AT+EGMR=0,5
Security Info :
IMEI [1] : AT+EGMR=0,7
IMEI [2] : AT+EGMR=0,10
IMEI [3] : AT+EGMR=0,11
IMEI [4] : AT+EGMR=0,12
Read Ok!
Update IMEI[1] to : 35XXXXXXXXXXXX failed , record not exist or NVRAM damaged!
Update IMEI[2] to : 35XXXXXXXXXXXX failed , record not exist or NVRAM damaged!
Done!
Elapsed: 00:01:23
Thats the result i get. plz any one with the solution can u plz share how to fix this problem?? Infinity team. or any one Thanks in advance
Old 12-20-2017, 11:28   #2 (permalink)
Member: 1677653
Thanks Meter: 2,769
Bro,
1 - check baseband
2 - look for nv file
3 - write nv file
4 - repair security
5 - done.
Old 12-20-2017, 11:38   #3 (permalink)
ntothel's Avatar
Member: 266180
Thanks Meter: 25
Originally Posted by Yusuf Lawal View Post
Bro,
1 - check baseband
3 - write nv file
4 - repair security
5 - done.
Baseband is ok. Can u share NV file for this model if u have? Thanks for the Idea
Old 12-20-2017, 11:48   #4 (permalink)
Member: 1677653
Thanks Meter: 2,769
Bro, I don't have @all
Old 12-20-2017, 11:54   #5 (permalink)
Member: 1677653
Thanks Meter: 2,769
Bro, also try this tool.
https://drive.google.com/file/d/0ByV...w?usp=drivesdk
Old 12-20-2017, 11:55   #6 (permalink)
ntothel's Avatar
Member: 266180
Thanks Meter: 25
Any one with nv file or other solution @infinityteam @JayDi or any one
Old 12-20-2017, 11:57   #7 (permalink)
ntothel's Avatar
Member: 266180
Thanks Meter: 25
Ur link need permision can u correct it
Old 12-20-2017, 12:17   #8 (permalink)
ntothel's Avatar
Member: 266180
Thanks Meter: 25
Does not work on this one
Old 12-20-2017, 12:27   #9 (permalink)
ntothel's Avatar
Member: 266180
Thanks Meter: 25
any one with another idea plz
Old 12-20-2017, 13:57   #10 (permalink)
princesaddam's Avatar
Member: 1010626
Sonork: using fb
Thanks Meter: 735
Hello,
USe fix BB with deep fix and then try again to repair security,, if still same just flash and try again
The Following User Says Thank You to princesaddam For This Useful Post:
Old 12-20-2017, 15:11   #11 (permalink)
ntothel's Avatar
Member: 266180
Thanks Meter: 25
Originally Posted by princesaddam View Post
Hello,
Thanks alot ur method works perfect.
Page generated in 0.19062 seconds with 8 queries
