12-17-2016, 08:40 | #1 (permalink) |
Freak Poster Join Date: Oct 2015 Location: Pakistan
Member: 2475109 Status: Offline Thanks Meter: 140 | 206 During flash dead Every time error occurred here. Card found: S/N : 979F6F6D , v0122 Registered to: akhtar maqbool Connect phone on selected interface... SSChannel : Create SC SSChannel : SC Created! ProductID HWCode : RM-872 Selected Variant : RM-872 MEA_M2_BLACK_URDU_PK Firmware Version : 04.52 Platform Version : Series 40 SSChannel : DC Ok with code 0x04 Switch to IDM now ... IDM initializing, wait... Checking access to Products folder... Folder for RM-872 not exist. Attempt to create Prepare done, collect info [Query] : rm872__04.52.image_m2_059Q4J7 , 16.47 MiB [Query] : rm872__04.52.mcusw , 25.47 MiB [Query] : rm872__04.52.ppm_m2 , 3.99 MiB [Query] : RM872_059Q4J7_04.52_023.vpl , 3.10 KiB Files to download : 4 Total size to download : 45.93 MiB Downloading now, please, wait... [Download] : rm872__04.52.image_m2_059Q4J7 [Download] : rm872__04.52.mcusw [Download] : rm872__04.52.ppm_m2 [Download] : RM872_059Q4J7_04.52_023.vpl Verify files now ... [Verify Ok] : rm872__04.52.mcusw [Verify Ok] : rm872__04.52.ppm_m2 [Verify Ok] : rm872__04.52.image_m2_059Q4J7 All done, all files were downloaded! Core : v2.25 , BB5XG FlashEngine : v10.3 Selected FlashSettings : Manual Check FlashFiles, Please, wait... Files Set for Flashing : MCU : rm872__04.52.mcusw PPM : rm872__04.52.ppm_m2 CNT : rm872__04.52.image_m2_059Q4J7 Flashing phone now... [Gen] Rules accepted for : XGOLD Generation Check files done... -> SWversion check skipped : Dead mode selected Dead Mode is Selected Waiting for USB device... -> If Windows say "Unrecognized device" / Operation not start -> Or if Phone start charge - just reinsert battery -> If flashing freeze - reinsert cable/battery and try again --- Press phone's power button or insert usb cable! --- Connection opened successfully IF Boot Init : 0xF0 IF Resp Len : 0x0A IF xCPUID : XGOLD 213 [XMM2130 QUANTUM] IF Resp Data : 1FB300020303010100FF Sending EBL Loader ... EBL Loader Ok, 01 EBL Loader ready, AA Sending EBL ... EBL sent Ok EBL : Quantum_Bootloader_10.53_M1S1 Speed accepted, use 6.500.000 FLASHID : 89008289 FLIC conf set, RST set Boot done! Check keys... Check done. Image can be flashed Backup enabled, will read all certificates Reading CCC Reading HWC Reading NPC IMEI 1 : 356724058312203 IMEI 2 : 356724058312211 PCcode : 059Q4J7 NPC Certificate saved... CCC Certificate saved... HWC Certificate saved... RPL saved : C:\InfinityBox\BEST\Backup\Cert\356724058312203_2n d_XG213_CRT.rpl Settings : EDM [0x8] , Block Mode , Fast CRC , Verify ===Flashing [MCU]=== File : rm872__04.52.mcusw Image : rm872__04.52.mcusw_ebl_psi.fls Sec-pack found, sending ... Sec-pack sent Found 5 region(s) Processing Region 1/5 Erase , Start : 0x40000000 , Len : 0x00020000 Erasing, wait ... Erase done, time : 00:00:00 Write , Start : 0x40000000 , Len : 0x00020000 Flashing , wait ... Region flash done, time : 00:00:00 Processing Region 2/5 Erase , Start : 0x40040000 , Len : 0x00020000 Erasing, wait ... Erase done, time : 00:00:00 Write , Start : 0x40040000 , Len : 0x00020000 Flashing , wait ... Region flash done, time : 00:00:00 Processing Region 3/5 Erase , Start : 0x40060000 , Len : 0x00100000 Erasing, wait ... Erase done, time : 00:00:06 Write , Start : 0x40060000 , Len : 0x00100000 Flashing , wait ... Region flash done, time : 00:00:02 Processing Region 4/5 Erase , Start : 0x40280000 , Len : 0x01800000 Erasing, wait ... Erase done, time : 00:01:20 Write , Start : 0x40280000 , Len : 0x01800000 Flashing , wait ... Region flash done, time : 00:00:32 Processing Region 5/5 Erase , Start : 0x43E20000 , Len : 0x00040000 [ERR_hReqFlashEraseStart] : 8201410040000000 Error... -> Check cable, flashfile, try again from this file Connect phone on selected interface... Elapsed: 00:02:47 Connect phone on selected interface... |
