01-19-2017, 06:30 | #1 (permalink) |
No Life Poster Join Date: May 2010 Location: Incredible-India
Member: 1301233 Status: Offline Sonork: Closed Thanks Meter: 9,297 | intex aqua q7 error read pattern lock read pattern lock Code: Operation : Read PatternLock [ v1.24 ] 1. Remove battery. Insert battery back 2. Press and hold 'VolumeUp' and 'VolumeDown' keys 3. Insert cable ==== Wait for phone... Phone found! [ 157 ] Port Opened Sync... InitBoot Done [ 0x81 ] , Ver : SPRD3 Sync... Sending FDL [Info] : If SW freeze here more, than 15 seconds - remove cable PickUp loaders from pac FDL Ready! Boot Ver : Spreadtrum Boot Block version 1.1 Sending FLASH FDL FLASH FDL Ready! Boot Ok! Checking Structure ... Detected eMMC Flash , Structure detect Ok! FlashMode Set : Ok! Reading PatternLock ... [Info] : UserData is big! Result can be empty! PatternLock Not Set! Elapsed: 00:00:11 Reconnect Power/Cable! Last edited by Deepesh Sharma; 01-19-2017 at 06:34. Reason: model number add |
01-19-2017, 06:56 | #2 (permalink) |
No Life Poster Join Date: Dec 2013 Location: India
Member: 2082450 Status: Offline Thanks Meter: 1,454 | Hello, CM2 SPD not able to read pattern lock on big use data. Code: Reading PatternLock ... [Info] : UserData is big! Result can be empty! |
The Following User Says Thank You to chandanps18 For This Useful Post: |
