CM2 MemoryTool : Full Control in your hands ( info & manual ) According users request we introduce new useful stuff for CM2 modules : MemoryTool. At now it available in QLM module ( rest modules on way )
SW support binary files, raw(original) firmware parts flashing, including sparse and e.t.c.
You NOT depend on need xml files and etc. Just do what you need here and now! Manual : After init MemTool and success connection you will see internal device structure. https://s23.postimg.org/g9rn0tk09/image.png You can check every element manually ( i.e. empty or not, filesystem state for forensic and etc. ) Main Workplace overview : https://s23.postimg.org/6iywolax7/Mixed.png There is few fields for every part :
FILESYSTEM - means there is some of standard filesystems data present NONE - empty partition
DATA - means partition NOT empty
https://s23.postimg.org/nak87cb63/Select_Filepng.png You can press "Cancel" to make field empty. If field is NOT set - partition will be ignored, if it selected for WRITE operation.
You can press "Cancel" to make field empty. If field is NOT set - partition will be ignored, if it selected for READ operation. Operations overwiev : https://s23.postimg.org/flndvmaob/image.png 1. Read Selected Read selected partitions from device ( if RD FILE is set ) https://s23.postimg.org/b64yqcya3/Read_Ex_1.png 2. Write Selected Write selected partitions to device ( if WR FILE is set ) https://s23.postimg.org/9i5tbpkej/Skip_Unselect.png AT EVERY operation SW will ask about accept operation! https://s23.postimg.org/msto58ayz/image.png 3. Set WorkPath Set path for READ operations ( instead default one ) Useful for make full RAW copy or etc. https://s23.postimg.org/5083xctqj/WPATH.png 4. Memory Test Make FAST memory test ( Memory ReadOnly Test ) Test is completely safe, and not depend on selected partitions to avoid any users mistakes. https://s23.postimg.org/hha66rzij/Mem_Test.png 5.Init MemTool / Close Session Start / Close MemoryTool session. On close session device will be rebooted to charge/normal mode. 6. Main workplace window Here user can select need partitions for desired operations,, verify their state, set path for read and write data. MULTIPLE partitions selection possible with CTRL ( ony-by-one ) and SHIFT ( ROW between START SELECTION and END SELECTION ) keys holding on keyboard. https://s23.postimg.org/9i5tbpkej/Skip_Unselect.png |
Very intelligent ,hot world,s first usefull rocking job done by infinity team ,Salute to dear jaydi . |
Will activate WIPE and some more stuff and features after 1-2 version, depend on users expirience with current one. New QLM version will be on support today. |
Looks usefull! And realy inovative move. May the Force be with us! :D |
The most important thing is to see, how people will adopt this new stuff with ease. These operations are going to be very useful only if one can be familiar with it. |
good job cm2 team , plz don.t forget Secured MTK BOOT same Like Huawei? |
Users ask custom writing and so on - they got it :) |
Oh, that's nice, looks great and usefull for forensics and data recovery. With this, there's no more need for rawprogram.xml creator since it's possible to just pick and write partition images manually as well, should be easier to work with LG based phones. Something i've been waiting for, good job. We're limited to your loaders, right, as long as they support the phone, we're able to access the device? Any chance to maybe add ability to use own loader, just in case if there're a "custom" shipped with firmware or someone wants to try experimenting? Also, i have to ask if there's any chance to support Samsung, SONY, HTC phones with that, at least for data reading, maybe in the future? |
Hello all, Here is the PDF link to download the same manual as in post no 1 for offline use any time. Hope it will help someone. View & Download |
great job but one question remaines where is imei reparing option..................? |
hope that this will support samsung device i have accidentally erase the file with CWM and now only qualcom detection it says infinity can detect the device but CPU is not supported :( hop you will support samsung device so that i can revive this device. |
Enough to make dummy rawprogram.xml, with 1 line and put in it folder nedd firehose_loader. Select in flash tab. SW will use it by default. Or use ready/similar/"only for own use and not for share" fw. Just select it in flash tab. Can add separate "use own FH" button as well. But not think about more entropy will be good :D We add new model lines and types in every update. Who knows. |
is it possible to flash to add protect imei and calibration data during flash and imei repair must be added |
LYF in testing again- Memory testing- http://i63.tinypic.com/mvrzix.png Modem partition reading- http://i67.tinypic.com/291cm81.jpg Modem partition writing- http://i66.tinypic.com/4vpgrq.png Br. Infinity Box Team. |
simply which condition of handset is required for this tool this tool is like for person how is software enginer my quistion is which condition of handset is required for this tool i am really simple user and this tool and its function is not understand dont laugh please :confused: |
