11-13-2016, 10:05 | #1 (permalink) |
No Life Poster Join Date: Oct 2009 Location: india Age: 37
Member: 1146038 Status: Offline Thanks Meter: 196 | Lenovo A7020a48 after frp reset DL mode can't fix Info Code: Operation : Check / Read Info [ v1.58 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 25 ] Sync... Inital Boot Ok! BB_CPU_PID : 6755 BB_CPU_NME : [MediaTek] Helio[P10]|MT6755_S00 BB_CPU_EXT : 0xCB00 , 0x8A00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x01000000 BromVer : 0x00FF BLVersion : 0x0001 PreLoader : Active [ Boot with PL ] BootLdrSS : SIGNED with SPRELOADER Processing DA stage DA Select done, will use MTK_AllInOne_DA_v5.1624.16.07 Sending and initialize DA ... DAgent configured successfully Connection agent : PRELOADER DRAM already initialized by Preloader Link with DAgent established eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0x15 , OEM : 0100 [eMMC] : FLASH_INF : [SAMSUNG] , BM41X [eMMC] : FLASH_CID : 150100525831344D4207FC23DC8663EF [eMMC] : FLASH_BRT : 0x00400000 , 0x00400000 , 0x00400000 [eMMC] : FLASH_LEN : 0x0000000747C00000 [eMMC] : FLASH_UCP : 29820 MiB [eMMC 32 GiB] DEV RID : 0x63002BF5AB0582AF9A5E7B06D4C0113B INT RAM : 0x00000000 EXT RAM : 0x80000000 [2 GiB] [NAND] : FLASH : NOT INSTALLED [UFSM] : FLASH : NOT INSTALLED [HSUSB] : MODE : HIGH-SPEED Boot Ok! [AP] : Initial info read Ok! Brand : Lenovo ProdName : k52_a48 ProdModel : Lenovo A7020a48 Device : A7020a48 AndroidVer: 6.0 MTKxCPU : MT6755 MTKxPRJ : A7020a48_USR_S259_1607211026_mp7-V2.3_lenovo6755.66c.m_P67_ROW EXTRA : LCD : Not info available :( LCD Res : 1920x1080 TOUCH [0] : GT1XX CAM [0] : s5k3m2_mipi_raw CAM [1] : ov8865_mipi_raw CAM [2] : s5k3m2_sunny_mipi_raw CAM [3] : ov8865_sunny_mipi_raw MODEM : STOM_MODEM=koleos2_row_lwctg_md1 LOCALE : en_US zh_CN zh_TW es_ES pt_BR ru_RU fr_FR de_DE tr_TR vi_VN ms_MY in_ID th_TH it_IT ar_EG hi_IN bn_IN ur_PK fa_IR pt_PT nl_NL el_GR hu_HU tl_PH ro_RO cs_CZ ko_KR km_KH iw_IL my_MM pl_PL es_US bg_BG hr_HR lv_LV lt_LT sk_SK uk_UA de_AT da_DK fi_FI nb_NO sv_SE en_GB hy_AM zh_HK et_EE ja_JP kk_KZ sr_RS sl_SI ca_ES Done! Elapsed: 00:00:21 Reconnect Power/Cable! Finish at : [13-11-2016 / 12:03:53 PM] Start at : [13-11-2016 / 12:04:00 PM] Operation : Format FileSystem [ v1.58 ] Code: 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 25 ] Sync... Inital Boot Ok! BB_CPU_PID : 6755 BB_CPU_NME : [MediaTek] Helio[P10]|MT6755_S00 BB_CPU_EXT : 0xCB00 , 0x8A00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x01000000 BromVer : 0x00FF BLVersion : 0x0001 PreLoader : Active [ Boot with PL ] BootLdrSS : SIGNED with SPRELOADER Processing DA stage DA Select done, will use MTK_AllInOne_DA_v5.1624.16.07 Sending and initialize DA ... DAgent configured successfully Connection agent : PRELOADER DRAM already initialized by Preloader Link with DAgent established eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0x15 , OEM : 0100 [eMMC] : FLASH_INF : [SAMSUNG] , BM41X [eMMC] : FLASH_CID : 150100525831344D4207FC23DC8663EF [eMMC] : FLASH_BRT : 0x00400000 , 0x00400000 , 0x00400000 [eMMC] : FLASH_LEN : 0x0000000747C00000 [eMMC] : FLASH_UCP : 29820 MiB [eMMC 32 GiB] DEV RID : 0x63002BF5AB0582AF9A5E7B06D4C0113B INT RAM : 0x00000000 EXT RAM : 0x80000000 [2 GiB] [NAND] : FLASH : NOT INSTALLED [UFSM] : FLASH : NOT INSTALLED [HSUSB] : MODE : HIGH-SPEED Boot Ok! Clear FRP ( Google Reset Protection ) Clear Ok! Clear PVL ( PrivacyLock ) Clear Ok! Done! Elapsed: 00:00:11 Reconnect Power/Cable! Finish at : [13-11-2016 / 12:04:12 PM] Code: ========================= Start ========================= 13-11-2016 / 02:22:09 PM ========================================================= Card found : S/N : Chinese Miracle II [MTK module] v 1.58 Start at : [13-11-2016 / 02:22:34 PM] Operation : Fix DL Errors [ v1.58 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 9 ] Sync... Inital Boot Ok! BB_CPU_PID : 6755 BB_CPU_NME : [MediaTek] Helio[P10]|MT6755_S00 BB_CPU_EXT : 0xCB00 , 0x8A00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x01000000 BromVer : 0x00FF BLVersion : 0x0001 PreLoader : Active [ Boot with PL ] BootLdrSS : SIGNED with SPRELOADER Processing DA stage DA Select done, will use MTK_AllInOne_DA_v5.1624.16.07 Sending and initialize DA ... DAgent configured successfully Connection agent : PRELOADER DRAM already initialized by Preloader Link with DAgent established eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0x15 , OEM : 0100 [eMMC] : FLASH_INF : [SAMSUNG] , BM41X [eMMC] : FLASH_CID : 150100525831344D4207FC23DC8663EF [eMMC] : FLASH_BRT : 0x00400000 , 0x00400000 , 0x00400000 [eMMC] : FLASH_LEN : 0x0000000747C00000 [eMMC] : FLASH_UCP : 29820 MiB [eMMC 32 GiB] DEV RID : 0x63002BF5AB0582AF9A5E7B06D4C0113B INT RAM : 0x00000000 EXT RAM : 0x80000000 [2 GiB] [NAND] : FLASH : NOT INSTALLED [UFSM] : FLASH : NOT INSTALLED [HSUSB] : MODE : HIGH-SPEED Boot Ok! DA DLFix Passed! Done! Elapsed: 00:00:31 Reconnect Power/Cable! |
11-14-2016, 11:08 | #3 (permalink) |
Member: 1146038 Status: Offline Thanks Meter: 196 | i will try to reflash with og tool so give error please help about this flashfile : A7020a48_S259_160721_ROW 1.50 gb size please guide about this |
11-14-2016, 11:12 | #4 (permalink) |
Member: 1146038 Status: Offline Thanks Meter: 196 | flash with cm2 but give error Code: Operation : Flash [ v1.58 ] ======= Flash 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 9 ] Sync... Inital Boot Ok! BB_CPU_PID : 6755 BB_CPU_NME : [MediaTek] Helio[P10]|MT6755_S00 BB_CPU_EXT : 0xCB00 , 0x8A00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x01000000 BromVer : 0x00FF BLVersion : 0x0001 PreLoader : Active [ Boot with PL ] BootLdrSS : SIGNED with SPRELOADER Processing DA stage DA Select done, will use MTK_AllInOne_DA_v5.1624.16.07 Sending and initialize DA ... DAgent configured successfully Connection agent : PRELOADER DRAM already initialized by Preloader Link with DAgent established eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0x15 , OEM : 0100 [eMMC] : FLASH_INF : [SAMSUNG] , BM41X [eMMC] : FLASH_CID : 150100525831344D4207FC23DC8663EF [eMMC] : FLASH_BRT : 0x00400000 , 0x00400000 , 0x00400000 [eMMC] : FLASH_LEN : 0x0000000747C00000 [eMMC] : FLASH_UCP : 29820 MiB [eMMC 32 GiB] DEV RID : 0x63002BF5AB0582AF9A5E7B06D4C0113B INT RAM : 0x00000000 EXT RAM : 0x80000000 [2 GiB] [NAND] : FLASH : NOT INSTALLED [UFSM] : FLASH : NOT INSTALLED [HSUSB] : MODE : HIGH-SPEED Boot Ok! ScatCFG : BaseBand : MT6755 , Project : k52_a48 , Storage : EMMC Setting : Flash Pre-Erase (Safe) : Enabled Setting : AFF verify : Enabled Setting : HW verify : Enabled M67BL : Check eMMC compatibility M67BL : eMMC supported by BootLoader! Selected forced PMT update Build new PMT ... Update Primary ... Update Mirror ... PMT update Ok! M67BL : Flash Erase Total blocks to Erase : 5 Erase : 0x0000000000008000-0x0000000001BC0000 Erase : 0x0000000004BC8000-0x0000000004000000 Erase : 0x000000000A000000-0x0000000001000000 Erase : 0x000000000B300000-0x0000000002480000 Erase : 0x000000000DC80000-0x000000033E380000 Flash Erase Done, time used : 00:00:01 Processing : Writing all Flash Files Flash Partition : PRELOADER Flash PLC Image Flash Ok Flash Partition : RECOVERY Image Flash Failed! Something wrong with files or connection! Operation Failed Elapsed: 00:00:16 Reconnect Power/Cable! |
12-05-2016, 13:40 | #11 (permalink) |
Junior Member Join Date: Mar 2004 Age: 44
Member: 58201 Status: Offline Thanks Meter: 0 | Hello Guys I've the same issue with the same error I've Format and install A7020a48_S312_160926_ROW with no luck I need to change IMEI and WIFI Mac , I try with SN Writer with the ROM DB but I've the error Can any help me ??? |
