10-19-2017, 15:32 | #1 (permalink) |
Freak Poster Join Date: Feb 2010 Location: Iran-kurdestan
Member: 1228830 Status: Offline Thanks Meter: 15 | Error : FH Configuration failed! cm2qlm What is mean ??? Error : FH Configuration failed! Code: Operation : Identify [ v1.15 ] 1. Power Off Phone , Remove battery , Insert back 2. PRESS and HOLD BOTH VOLUME KEYS! 3. Insert USB cable. In some cases require use EDL cable or TP to force EDL mode! Wait for phone... Device Found! Initialize ... Handshake passed! BB_IDC_CPU : SnapDragon 2x/4x|00 [MSM8x12] ID_BLOCK_S : 0A78D4A0 ID_BLOCK_I : 008140E1 ID_BLOCK_L : 25DFB541EC7A67625D32C2C30C57DFEF ID_BLOCK_L : 5322EC3F30A30B983DF8DD0A189781CA Use CM2 Internal Loader Loader Sent! Initializing ... Error : FH Configuration failed! Remove battery, cable. Check cable and connection. Repeat operation! Reconnect Power/Cable! |
10-21-2017, 01:17 | #2 (permalink) |
Member: 163 Status: Offline Thanks Meter: 7,786 | From my experience with Huawei, and QComm in general, it can mean two things : 1. Change pc, re-check drivers, cable, usb port 2. eMMC (Flash memory) is DEAD. Need to be replaced on board. b.r. Alex
__________________ Always press THANKS button if my post was helpful! Please DO NOT send me PM's for help, You can ask for help on forum Do not post THANKS posts - use thanks button ! ALWAYS use SEARCH button before posting! |
The Following 6 Users Say Thank You to Brka For This Useful Post: |
04-30-2018, 16:17 | #3 (permalink) |
No Life Poster Join Date: Dec 2003 Location: Karachi Pakistan Age: 38
Member: 47321 Status: Offline Sonork: 100.54032 Thanks Meter: 497 | Phone is ASUS Z01BDC and has FRP Lock same error Error : FH Configuration failed! Remove battery, cable. Check cable and connection. Repeat operation! |
09-02-2018, 22:40 | #6 (permalink) |
Junior Member Join Date: Dec 2013 Location: Dhaka, BanglaDesh
Member: 2076448 Status: Offline Thanks Meter: 5 | Error : FH Configuration failed! cm2qlm I've got this error on xiaomi note 5 pro (whyred). But the phone is only locked with mi account. And the phone is completely OK. Also notice that the phone has been updated with anti rollback firmware which is miui version 9.5.19.0 (Global Stable Firmware) I tried with previous firehorse loader which was failed to send the loader. But with new firmware (v9.5.19.0) loader provided with firmware, it says that Error : FH Configuration failed! What will be the next step for me to overcome this sort of problem. Thanks in advance, rsHEMEL |
09-03-2018, 09:34 | #7 (permalink) | |
No Life Poster Join Date: Feb 2017 Location: Quelimane Mz Age: 26
Member: 2680008 Status: Offline Thanks Meter: 1,640 | Quote:
