03-23-2018, 06:11 | #1 (permalink) |
No Life Poster Join Date: Nov 2006 Location: philippines Age: 42
Member: 388962 Status: Offline Sonork: 100.1637202 Thanks Meter: 264 | Cm2 qualcomm invalid pointer operation at 99% the software stops and then a small window pops up with INVALID POINTER OPERATION message have tried 3 times, all the same, at 99% error here is logs : Code: Card found : 456E58FB , v0136 Infinity-Box Chinese Miracle Qualcomm Module [QLM] v 1.16 Loading firmware ... Created by Infinity-Box (c) Chinese Miracle II (c) 2017 Device Brand : OPPO Device Manufact.: OPPO Device Model : A37f Device CPU : MSM8916 Device IntName : A37f Device Version : 5.1.1 SWVersion : A37fEX_11.A.22_INT_022_201705221641 CU_SWVer : OPPO Device Compile : 5/22/2017 10:56:07 AM Device ExtInfo : A37f Load Ok! Operation : Flash [ v1.16 ] ForceFlashing : Disabled Verify FW package ... Verification passed! 1. Power Off Phone , Remove battery , Insert back 2. PRESS and HOLD BOTH VOLUME KEYS! 3. Insert USB cable. In some cases require use EDL cable or TP to force EDL mode! Wait for phone... Device Found! Initialize ... Handshake passed! ID_BLOCK_I : SnapDragon 410 [MSM8916] ID_BLOCK_S : 233C3790 ID_BLOCK_L : 15EF8571DC4A77722D02F2D31C67EFDF ID_BLOCK_L : 176ED07B7CE757DCF13C914E44AB4586 Pickup loader from firmware package Loader Sent! Initializing ... Running FireHose on BBID : MSM8916 , FLASH : eMMC , mVER : 1 MemInfo : 0x0003 / 0x0200 / 0x00000003A3E00000 [ eMMC 16 GiB ] ExtInfo : 0x00004000/00004000/00001000/00001000/00000200 Boot Ok! Flash Chain : 43 Flashing now Flashing : gpt_main0.bin Flashing : NON-HLOS.bin Flashing : sec.dat Flashing : sbl1.mbn Flashing : sbl1.mbn Flashing : emmc_appsboot.mbn Flashing : emmc_appsboot.mbn Flashing : rpm.mbn Flashing : rpm.mbn Flashing : tz.mbn Flashing : tz.mbn Flashing : hyp.mbn Flashing : hyp.mbn Flashing : lsplash.img Flashing : boot.img Flashing : recovery.img Flashing : system.img Flashing : cache.img Flashing : persist.img Flashing : misc.img Flashing : driver.iso Flashing : userdata.img |
The Following 2 Users Say Thank You to eivelice For This Useful Post: |
05-01-2018, 13:10 | #3 (permalink) |
Freak Poster Join Date: Feb 2017 Location: Alipur
Member: 2683134 Status: Offline Thanks Meter: 59 | try to reset factory setting by some tool if it says erase failed or something like that then I think its surly emmc Problem |
The Following 2 Users Say Thank You to Love_InsPeXtor For This Useful Post: |
