cm2 qualcomm phone booting problem 1 Attachment(s) many of time when i try to identify qualcomm phone via cm2 i found the follwing error Card found : B796139F , v0145 Infinity-Box Chinese Miracle Qualcomm Module [QLM] v 1.16 Operation : Identify [ v1.16 ] 1. Power Off Phone , Remove battery , Insert back 2. PRESS and HOLD BOTH VOLUME KEYS! 3. Insert USB cable. In some cases require use EDL cable or TP to force EDL mode! Wait for phone... BREAK : Device not found! HINT : Check cable, connection and drivers! Reconnect Power/Cable! Operation : Reset Settings [ v1.16 ] 1. Power Off Phone , Remove battery , Insert back 2. PRESS and HOLD BOTH VOLUME KEYS! 3. Insert USB cable. In some cases require use EDL cable or TP to force EDL mode! Wait for phone... BREAK : Device not found! HINT : Check cable, connection and drivers! Reconnect Power/Cable! Operation : Reset Settings [ v1.16 ] 1. Power Off Phone , Remove battery , Insert back 2. PRESS and HOLD BOTH VOLUME KEYS! 3. Insert USB cable. In some cases require use EDL cable or TP to force EDL mode! Wait for phone... BREAK : Device not found! HINT : Check cable, connection and drivers! Reconnect Power/Cable! Operation : Reset Settings [ v1.16 ] 1. Power Off Phone , Remove battery , Insert back 2. PRESS and HOLD BOTH VOLUME KEYS! 3. Insert USB cable. In some cases require use EDL cable or TP to force EDL mode! Wait for phone... BREAK : Device not found! HINT : Check cable, connection and drivers! Reconnect Power/Cable! the fone recognised by pc so i think there is no driver issue.where is mistak can anyone guide me |
download driver from support.... cm2 has different driver for quallcom not like other |
