08-09-2016, 09:39 | #4 (permalink) |
Insane Poster Join Date: Jun 2010
Member: 1326633 Status: Offline Thanks Meter: 6 | here are the log that i take format error Card found: S/N : CCDF238F , v0132 Chinese Miracle II [SPD module] v 1.20 Operation : Check/Read Info [ v1.20 ] 1. Remove battery. Insert battery back 2. Insert cable 3. In case of SVC init problems - connect with hold "VolDown" button! ==== Wait for phone... Phone found! [ 119 ] Port Opened Sync... InitSvc Done Wait for phone... Sync... Phone Initial Info : Platform : MOCORTM_14B_7731C_W16.09.2_Debug Project : sc7731g_CP0_modem HWInfo : sc7731g_CP0_modem Compile : 02-19-2016 17:07:00 Phone Security Info : IMEI [1] : 869325021377073 IMEI [2] : 869325021407375 BT_ADDR : 000000000000 SelfInfo : BatVoltage : 3.723 V Done Reconnect Power/Cable! Operation : Format File System / Reset Settings [ v1.20 ] Settings : SmartFormat is On 1. Remove battery. Insert battery back 2. Insert cable 3. In case of SVC init problems - connect with hold "VolDown" button! ==== Wait for phone... Phone found! [ 119 ] Port Opened Sync... InitSvc Done Wait for phone... Sync... Init Ok , reset settings ... Format Error! Done Elapsed: 00:00:25 Reconnect Power/Cable! |
08-09-2016, 10:39 | #5 (permalink) |
Member: 541591 Status: Offline Sonork: 100.1611509 Thanks Meter: 7,361 | Hello, For frp you need to Format without SVC mode. SC7731 has 4 options (including LDR mode) + manual SLDR files, try with all and Format phone. Br. Infinity Box Support Team. |
08-09-2016, 12:50 | #6 (permalink) | |
Junior Member Join Date: Jul 2016 Location: bulacan phillippines
Member: 2605409 Status: Offline Thanks Meter: 6 | Quote:
Chinese Miracle II [SPD module] v 1.20 Operation : Format File System / Reset Settings [ v1.20 ] Settings : SmartFormat is On 1. Remove battery. Insert battery back 2. Press and hold 'VolumeUp' and 'VolumeDown' keys 3. Insert cable ==== Wait for phone... Phone found! [ 19 ] Port Opened Sync... Initial Boot Failed! Reconnect Power/Cable! Operation : Format File System / Reset Settings [ v1.20 ] Settings : SmartFormat is On 1. Remove battery. Insert battery back 2. Press and hold 'VolumeUp' and 'VolumeDown' keys 3. Insert cable ==== Wait for phone... Phone found! [ 15 ] Port Opened Sync... InitBoot Done [ 0x81 ] , Ver : SPRD3 Sync... Sending FDL [Info] : If SW freeze here more, than 15 seconds - remove cable Boot failed! Boot failed! Reconnect Power/Cable! | |
