10-25-2019, 10:02 | #1 (permalink) |
Freak Poster Join Date: Apr 2016 Location: South Africa /Pakistan Age: 29
Member: 2555393 Status: Offline Thanks Meter: 268 | CM2 SPD2 Flashing Problem Next update please fix flashing problem and make faster. SPD 1.27 work fine for flash Astro. Operation : Flash Firmware [ v2.01 ] Setting : Update NVRAM : False Setting : Force NVRAM : False Setting : Update PMT : True 1. Power off device, wait 10-15 seconds 2. Press and hold BooKey ( 1 : BOTH VOL , 2 : VOL+ , 3 : VOL- ) 3. Insert cable in device! Wait for device ... Device Connected! BootVersion : SPRD3 Boot : PAC : Mobicel_ASTRO_Pac_By_GSM AFRICA.pac Sending Init Boot ... Boot sent! Kick FDL ... BootVersion : Spreadtrum Boot Block version 1.1 Protocol setup ... Port speed : 921600 Sending Flash Boot ... Boot sent! Kick FLASH FDL ... FDL : Control transfered! Boot Done! PMTMng : Load PMT PMTMng : 0x20 PMTMng : Update PMT Ok! CODE : prodnv.img ERASE : UBOOT ERASE : UBOOT_LOG UBOOT : u-boot-spl-16k-sign.bin CODE : vbmeta-sign.img CODE : SC9600_pike2_pubcp_modem.dat CODE : pike2_pubcp_deltanv.bin CODE : PIKE2_DM_DSP.bin CODE : pike2_cm4.bin CODE : gnssmodem.bin CODE : gnssbdmodem.bin CODE : PM_pike2_cm4.bin Failed to update block! ERROR : 0000008E:00000000FF7F0000 Error : Flashing failed! Check previous message for more info! |
10-29-2019, 09:32 | #2 (permalink) |
Member: 2555393 Status: Offline Thanks Meter: 268 | same problem with new update also please fix this issue . no reply from infinity team Card found : 7A5A6AEC , v0138 Infinity-Box Chinese Miracle II : SPD/USC Module [SP2] v2.02 Load IDBase v10107 Ok! Open : Mobicel_Trendy_Lite_Pac_ VER : BP_R1.0.0 LEN : 0x67EA152F CPU : k101 VER : Mobicel_Trendy_Lite_Pac Reading package ... Read package finished! Patch Level : OPM2.171019.012 Display ID : OPM2.171019.012 release-keys Ver. CodeName : REL Ver. Release : 8.1.0 Sec. Patch : 2018-04-05 Build Time : 1528971470 Product Info : k101 Product Model : ASTRO Product Brand : Mobicel Product Name : ASTRO Product Device : ASTRO Product Manfct : Mobicel Product Board : k101 Board Platform : sp7731e Operation : Flash Firmware [ v2.02 ] Setting : Update NVRAM : False Setting : Force NVRAM : False Setting : Update PMT : True 1. Power off device, wait 10-15 seconds 2. Press and hold BooKey ( 1 : BOTH VOL , 2 : VOL+ , 3 : VOL- ) 3. Insert cable in device! Wait for device ... Device Connected! BootVersion : SPRD3 Boot : PAC : Mobicel_Trendy_Lite_Pac Sending Init Boot ... Boot sent! Kick FDL ... BootVersion : Spreadtrum Boot Block version 1.1 Protocol setup ... Port speed : 921600 Sending Flash Boot ... Boot sent! Kick FLASH FDL ... FDL : Control transfered! Boot Done! PMTMng : Load PMT PMTMng : 0x20 PMTMng : Update PMT Ok! CODE : prodnv.img ERASE : UBOOT ERASE : UBOOT_LOG UBOOT : u-boot-spl-16k-sign.bin CODE : vbmeta-sign.img CODE : SC9600_pike2_pubcp_modem.dat CODE : pike2_pubcp_deltanv.bin CODE : PIKE2_DM_DSP.bin CODE : pike2_cm4.bin CODE : gnssmodem.bin CODE : gnssbdmodem.bin CODE : PM_pike2_cm4.bin Failed to update block! ERROR : 0000008E:00000000FF7F0000 INT : WAIT TIMEOUT! DEVICE PROBLEM or WRONG FDL! Error : Flashing failed! Check previous message for more info! Reconnect Power/Cable! Flashing finished! Reconnect Power/Cable! Done! Elapsed: 00:05:18 |
10-30-2019, 12:20 | #3 (permalink) |
Member: 462970 Status: Offline Thanks Meter: 20,352 | Unfortunately not see here any issue. Can you check this pac and device with UpgradeTool? |
03-10-2023, 16:26 | #8 (permalink) |
Junior Member Join Date: Sep 2022 Location: Nigeria, kebbi state
Member: 3020993 Status: Offline Thanks Meter: 2 | Infinix x6511B flash failed Prepare target .... ERROR : 00000000FE:FE000000000FF017E00 GEN : UNKNOWN RESPONSE Please help I need to change the firmware of the device please |
03-10-2023, 16:36 | #9 (permalink) | |
Thank you very much for your kind help! | |
03-17-2023, 02:35 | #14 (permalink) |
Member: 148515 Status: Offline Thanks Meter: 19,534 | Download it from Infinity server https://infinity-box.com/?r=100215 |
