Old 06-15-2020, 03:22   #16 (permalink)
sneha's Avatar
Member: 327043
Sonork: 100.1587811
Thanks Meter: 1,514
Originally Posted by YellowBoss View Post
Download free antivirus to cure your PC - https://free.drweb.com/download+cureit+free/?lng=en
Result ?
after scan PC with this 2.11 works till restart PC after restart same
Old 06-15-2020, 05:15   #17 (permalink)
Member: 2802601
Thanks Meter: 4
i also this problem plz fix this issue as soon as possible
Old 06-15-2020, 18:52   #18 (permalink)
Member: 130995
Thanks Meter: 35,227
So scan PC once again after restart.
Do you see viruses again ?
Old 06-15-2020, 18:54   #19 (permalink)
Member: 130995
As I can see it was an issue with PC infected by virus.
If you have your PC infected you should clean vruses before run software.
Link to antivirus software is in this thread.
Clean your PC now !
result ?
Old 06-16-2020, 04:32   #20 (permalink)
sneha's Avatar
Member: 327043
Sonork: 100.1587811
Thanks Meter: 1,514
yes sir if scan again it show virus
Old 06-16-2020, 09:22   #21 (permalink)
Member: 130995
This means you should REMOVE virus !
Infinity software works like virus-detector for your PC.
If your PC infected with virus - virus also damage Infinity exe and Infinity exe see that it was changed (damaged by virus) and can not run because it was DAMAGED BY VIRUS.
Do you understand the idea ?
Old 06-16-2020, 14:41   #22 (permalink)
sneha's Avatar
Member: 327043
Sonork: 100.1587811
Thanks Meter: 1,514
yes i understand
any suggestion how i remove that virus without permanent instalation any AV ?
dr web antivirus scaner scan and show me virus and then remove also
but after PC restart all same
because AV hang PC many time
Old 06-16-2020, 15:43   #23 (permalink)
Member: 148515
Thanks Meter: 19,534
yes i understand
you can try any other antivirus. I do not know what is better, all of them steal user's data
Old 06-16-2020, 15:58   #24 (permalink)
rahihimkhan's Avatar
Member: 613449
Sonork: 100.1614074
Thanks Meter: 634
1th i install a new window 7 32bit
2nd install cm2mt2 v2.11
3rd cm2mt2 v2.11 open and work
4th after some time not open cm2mt2 v2.11
Frist time fs_external.dll size 1,100 kb After some time fs_external.dll size 1,176 (file size atuo change from 1.07 mb to 1.14 mb)
The Following User Says Thank You to rahihimkhan For This Useful Post:
Old 06-16-2020, 16:01   #25 (permalink)
Member: 613449
Sonork: 100.1614074
Thanks Meter: 634
now i install a new window
Window 10 pro
Old 06-16-2020, 21:26   #26 (permalink)
Member: 148515
Window 10 pro
Is it Ok with Window 10 pro ?
Old 06-17-2020, 04:52   #27 (permalink)
Member: 613449
Sonork: 100.1614074
Thanks Meter: 634
same problem
Rahim
Old 06-17-2020, 07:46   #28 (permalink)
Member: 148515
same problem
Rahim
Run Free antivirus to cure your PC - https://free.drweb.com/download+cureit+free/?lng=en
Do you see any virus found ?
Old 06-17-2020, 08:02   #29 (permalink)
Member: 148515
- Dr. Web CureIT
- Microsoft Safety Scanner
https://docs.microsoft.com/en-us/win...anner-download
- Avira PC Cleaner
http://install.avira-update.com/pack...cleaner_en.exe
- Intel McAfee GetSusp
https://www.mcafee.com/enterprise/en...s/getsusp.html
- Intel McAfee Stinger
https://www.mcafee.com/enterprise/en...s/stinger.html
- Intel McAfee RootkitRemover
https://www.mcafee.com/enterprise/en...itremover.html
- Comodo Antivirus With Internet Security
https://www.comodo.com/home/internet...php?track=8234
- Symantec Norton Power Eraser
https://us.norton.com/support/tools/npe.html
- TrendMicro HouseCall
https://www.trendmicro.com/en_us/for...housecall.html
- ClamWin Portable
https://portableapps.com/apps/security/clamwin_portable
Old 06-17-2020, 08:28   #30 (permalink)
Member: 154448
Sonork: not yet
Thanks Meter: 50
if you want work with all infinity .exe you will disable antivirus in first and work again
if you can't work open infinty folder and delet fault.bin file and run exe again
i work with this solution
Page generated in 0.27470 seconds with 9 queries
