10-25-2020, 09:23 | #1 (permalink) |
Junior Member Join Date: May 2019 Location: Bangladesh
Member: 2908473 Status: Offline Thanks Meter: 2 | cm2mt2 automatically shows ports even when i did not connect any device Card found : F4F93A60 , v0144 Infinity-Box [ Chinese Miracle ] MediaTek Service Module [ MTK ] v2.14 Load IDBase v714150 Ok! Operation : Identify [ v2.14 ] Mode : FLASH 1. Make sure device is powered off. Power off, if need. Wait 20 seconds after 2. Insert USB cable in phone Waiting for device connection ... PTFN : MediaTek PreLoader USB VCOM (Android) (COM11) MODE : PRELOADER PORT PORT : 11 Error : Failed to open port! Error : Fail to init protocol! >>> Remove battery, cable. Check cable/connection/driver! Check SW hint! Repeat operation! Reconnect Power/Cable! |
10-25-2020, 13:20 | #2 (permalink) | |
Member: 148515 Status: Offline Thanks Meter: 19,534 | Quote:
Reboot PC and try again. Also open your PC DeviceManager. Do you see any ports there ? | |
