Old 11-10-2020, 07:23   #1 (permalink)
Member: 2908473
Thanks Meter: 2
cm2mt2 loads automatically.. i did not connect any device
Card found : F4F93A60 , v0144
Infinity-Box [ Chinese Miracle ] MediaTek Service Module [ MTK ] v2.14
Load IDBase v714150 Ok!
Operation : Identify [ v2.14 ]
Mode : FLASH
1. Make sure device is powered off. Power off, if need. Wait 20 seconds after
2. Insert USB cable in phone
Waiting for device connection ...
PTFN : MediaTek PreLoader USB VCOM (Android) (COM11)
MODE : PRELOADER PORT
PORT : 11
Error : Failed to open port!
Error : Fail to init protocol!
>>> Remove battery, cable. Check cable/connection/driver! Check SW hint! Repeat operation!
Reconnect Power/Cable!
but cm2mtk,,cm2spd,, cm2scr,,and others ,,,,,there is no problem,,,,,,,,,the problem is with cm2mt2,,,,i uninstalled and reinstalled,,but still same
Old 11-10-2020, 07:49   #2 (permalink)
gile@gile's Avatar
Member: 1473716
Thanks Meter: 1,273
Mode : FLASH
PORT : 11
https://forum.gsmhosting.com/vbb/f29...rward-2910780/
Download latest version....
Old 11-10-2020, 11:25   #3 (permalink)
Member: 1043909
Thanks Meter: 60,926
Are you sure you have no any usb devices connected to PC ?
Disconnect everything for all USB ports and try again
Page generated in 0.18339 seconds with 9 queries
