10-08-2014, 17:16 | #1 (permalink) |
No Life Poster Join Date: Feb 2008 Location: budaun Age: 38
Member: 702572 Status: Offline Sonork: 9837200009 Thanks Meter: 74 | BB_CPU_ID : 6572 error lava 352e Chinese Miracle II [MTK module] v 1.01 Operation : Read Flash [ v1.01 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 42 ] Sync... Inital regs read done Boot Info : BB_CPU_ID : 6572 BB_CPU_HW : CA01 BB_CPU_SW : 8C00 BB_CPU_SB : 0000 BB_CPU_NM : [MediaTek] MT6572_S00 Processing BROM stage BLVersion : 0x01 SecCfgVal : 0x00000000 BromVersion : 0xFF BLVersion : 0x01 Processing DA stage NAND_ID : 009800BC009000660076 eMMC_ID : 00000000000000000000000000000000 DA Stat : v4.2 on BBID : 0x88 NAND FlashIC initialized [NAND] : FLASH_VEN : 0x0074 , UNKNOWN [NAND] : FLASH_DIE : 0098 00BC 0090 0066 0076 [NAND] : FLASH_LEN : 0x20000000 NAND not supported yet INT RAM : 0x00020000 EXT RAM : 0x10000000 BOOT TYPE : NAND_FLASH_BOOT SOC VERIFY : C1 Boot Ok! Boot Error! Operation Failed Elapsed: 00:00:13 Reconnect Power/Cable! |
10-08-2014, 17:29 | #2 (permalink) |
No Life Poster Join Date: Nov 2009 Location: Syberia Age: 34
Member: 1157320 Status: Offline Thanks Meter: 6,192 | Hello, I will put new version tomorrow, when get last need phone. If you need right now : CM2MTKv102c |
The Following User Says Thank You to Dzirt For This Useful Post: |
10-08-2014, 17:56 | #3 (permalink) | |
No Life Poster Join Date: Aug 2007 Location: Under Blue
Member: 569925 Status: Offline Sonork: 100.1624057 Thanks Meter: 6,313 | Quote:
Wait for phone... Phone found! [ 5 ] Sync... Inital regs read done Boot Info : BB_CPU_ID : 6572 BB_CPU_HW : CA01 BB_CPU_SW : 8C00 BB_CPU_SB : 0000 BB_CPU_NM : [MediaTek] MT6572_S00 Processing BROM stage BLVersion : 0x01 SecCfgVal : 0x00000000 BromVersion : 0xFF BLVersion : 0x01 Preloader Status : Alive Processing DA stage DA Select done , sending NAND_ID : 000100BC009000550056000100BC0000 eMMC_ID : 00000000000000000000000000000000 DA Stat : v4.2 on BBID : 0x88 DA Sent. Configure setting now ... NAND FlashIC initialized [NAND] : FLASH_VEN : 0x008F , [Spansion] KEM51200_NADGSBXM2C32 [NAND] : FLASH_DIE : 0001 00BC 0090 0055 0056 0001 00BC [NAND] : FLASH_LEN : 0x20000000 INT RAM : 0x00020000 EXT RAM : 0x10000000 BOOT TYPE : NAND_FLASH_BOOT SOC VERIFY : C1 Boot Ok! Reading Flash Conent now ... NAND settings not exists, will check now ... Settings read Ok! - > Re-connect battery and start operation again! Done! Elapsed: 00:00:13 Reconnect Power/Cable! waiting for to be fixed very soon .Phone is still in my hands till tomorrow Regards amn32 | |
10-08-2014, 17:57 | #4 (permalink) |
Member: 702572 Status: Offline Sonork: 9837200009 Thanks Meter: 74 | Card found: S/N 085E:0128 Chinese Miracle II [MTK module] v 1.02b Operation : Read Flash [ v1.02b ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 42 ] Sync... Inital regs read done Boot Info : BB_CPU_ID : 6572 BB_CPU_HW : CA01 BB_CPU_SW : 8C00 BB_CPU_SB : 0000 BB_CPU_NM : [MediaTek] MT6572_S00 Processing BROM stage BLVersion : 0x01 SecCfgVal : 0x00000000 BromVersion : 0xFF BLVersion : 0x01 Preloader Status : Alive Processing DA stage DA Select done , sending NAND_ID : 009800BC009000660076001500010000 eMMC_ID : 00000000000000000000000000000000 DA Stat : v4.2 on BBID : 0x88 DA Sent. Configure setting now ... NAND FlashIC initialized [NAND] : FLASH_VEN : 0x007F , [TOSHIBA] TYBC0A111557KC [NAND] : FLASH_DIE : 0098 00BC 0090 0066 0076 0015 0001 [NAND] : FLASH_LEN : 0x20000000 INT RAM : 0x00020000 EXT RAM : 0x10000000 BOOT TYPE : NAND_FLASH_BOOT SOC VERIFY : C1 Boot Ok! Reading Flash Conent now ... NAND settings not exists, will check now ... Settings read Ok! - > Re-connect battery and start operation again! Done! Elapsed: 00:00:12 Reconnect Power/Cable! Operation : Read Flash [ v1.02b ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 42 ] Sync... Brom Init not done Boot Error! Operation Failed Elapsed: 00:00:00 Reconnect Power/Cable! Operation : Read Flash [ v1.02b ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 42 ] Sync... Brom Init not done Boot Error! Operation Failed Elapsed: 00:00:04 Reconnect Power/Cable! Operation : Read Flash [ v1.02b ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 42 ] Sync... Inital regs read done Boot Info : BB_CPU_ID : 6572 BB_CPU_HW : CA01 BB_CPU_SW : 8C00 BB_CPU_SB : 0000 BB_CPU_NM : [MediaTek] MT6572_S00 Processing BROM stage BLVersion : 0x01 SecCfgVal : 0x00000000 BromVersion : 0xFF BLVersion : 0x01 Preloader Status : Alive Processing DA stage DA Select done , sending NAND_ID : 009800BC009000660076001500010000 eMMC_ID : 00000000000000000000000000000000 DA Stat : v4.2 on BBID : 0x88 DA Sent. Configure setting now ... NAND FlashIC initialized [NAND] : FLASH_VEN : 0x007F , [TOSHIBA] TYBC0A111557KC [NAND] : FLASH_DIE : 0098 00BC 0090 0066 0076 0015 0001 [NAND] : FLASH_LEN : 0x20000000 INT RAM : 0x00020000 EXT RAM : 0x10000000 BOOT TYPE : NAND_FLASH_BOOT SOC VERIFY : C1 Boot Ok! Reading Flash Conent now ... Read Ok , collect info MTKxCPU : MT6572 MTKxPRJ : wt97135 Saved to : C:\Documents and Settings\AMAN COMMUNICATION\Desktop\CM2MTKv102c\Flash\MT6572__wt 97135.ispff Done! Elapsed: 00:03:32 Reconnect Power/Cable! |
The Following User Says Thank You to amancommunicati For This Useful Post: |
10-08-2014, 18:11 | #5 (permalink) | |
Member: 1157320 Status: Offline Thanks Meter: 6,192 | Quote:
10-08-2014, 18:26 | #8 (permalink) |
Member: 569925 Status: Offline Sonork: 100.1624057 Thanks Meter: 6,313 | Sorry Dzirt i accept my mistake ,Read is done now . Thanx Wait for phone... Phone found! [ 5 ] Sync... Inital regs read done Boot Info : BB_CPU_ID : 6572 BB_CPU_HW : CA01 BB_CPU_SW : 8C00 BB_CPU_SB : 0000 BB_CPU_NM : [MediaTek] MT6572_S00 Processing BROM stage BLVersion : 0x01 SecCfgVal : 0x00000000 BromVersion : 0xFF BLVersion : 0x01 Preloader Status : Alive Processing DA stage DA Select done , sending NAND_ID : 000100BC009000550056000100BC0000 eMMC_ID : 00000000000000000000000000000000 DA Stat : v4.2 on BBID : 0x88 DA Sent. Configure setting now ... NAND FlashIC initialized [NAND] : FLASH_VEN : 0x008F , [Spansion] KEM51200_NADGSBXM2C32 [NAND] : FLASH_DIE : 0001 00BC 0090 0055 0056 0001 00BC [NAND] : FLASH_LEN : 0x20000000 INT RAM : 0x00020000 EXT RAM : 0x10000000 BOOT TYPE : NAND_FLASH_BOOT SOC VERIFY : C1 Boot Ok! Reading Flash Conent now ... Read Ok , collect info MTKxCPU : MT6572 MTKxPRJ : lightning89_wet_lca Saved to : C:\Documents and Settings\Amin\Desktop\CM2MTKv102c\Flash\MT6572__li ghtning89_wet_lca.ispff Done! Elapsed: 00:06:38 Reconnect Power/Cable! Regards amn32 |
The Following User Says Thank You to amn32 For This Useful Post: |
10-09-2014, 11:26 | #10 (permalink) | |
Download samsung mtk 6572 [Spansion] KEM51200 NADGSBXM2C32 rar Regards amn32 | |
