[CM2QLM] Device unsupported Device Coolpad E501 Dualsim BR David PS. Device is alive - FRP blocked only ;) Code: Wait for phone... |
hi which cable do you have used ? pyroz |
with v1.07 cpu not suported i used EDL cabl but stil not suprted,i most to remove patern Card found : 1FC12125 , v0134 Infinity-Box Chinese Miracle Qualcomm Module [QLM] v 1.07 Operation : Reset Settings [ v1.07 ] 1. Power Off Phone , Remove battery , Insert back 2. PRESS and HOLD BOTH VOLUME KEYS! 3. Insert USB cable. In some cases require use EDL cable or TP to force EDL mode! Wait for phone... Device Found! Initialize ... Handshake passed! BB_IDC_CPU : SnapDragon 410 [MSM8916] ID_BLOCK_S : 101391F5 ID_BLOCK_I : 007050E1 ID_BLOCK_L : 338022845613FA102717854782BD851F ID_BLOCK_L : 6C93143E15B76A6E44BAC7A053590E3C Use CM2 Internal Loader Error : Prepare target failed! Unsupported SecureType! Send log and report.log to support! Include device info also! in txt of suported versin vrite for this model is suported |
frp can be removed via menu trick, soft key, on coolpad modena e501, i dont remember how exactly, but can be done |
Br - srinibas |
Is not posinle to read file is not supprted cpu Sent from my iPhone using Tapatalk |
Br - srinibas |
I have bat not posible to flash stil unsuported cpu Sent from my iPhone using Tapatalk |
Br - srinibas |
Need drivers for this model E501, how to connect, failed to connect.... Need help please |
Install driver from support, need to connect phone in EDL mode. Refer Manual for more help- C:\InfinityBox\CM2QLM\docs Br. Infinity Box Team. |
Thanks for the answer, connected, is not supported with version Infinity-Box Chinese Miracle Qualcomm Module [QLM] v 1.09 |
CM2QLM 1.10 Wait for phone... Device Found! Initialize ... Handshake passed! BB_IDC_CPU : SnapDragon 410 [MSM8916] ID_BLOCK_S : 12A8DB89 ID_BLOCK_I : 007050E1 ID_BLOCK_E : 12A8DB89 ID_BLOCK_L : DF14D668C2FF6EBCB3EB19EB1649798B ID_BLOCK_L : C104A393821AF103D10552CBC8ECB3A9 Use CM2 Internal Loader Loader Sent! Initializing ... Running FireHose on BBID : MSM8916 , FLASH : eMMC , mVER : 1 MemInfo : 0x0003 / 0x0200 / 0x00000001D2000000 [ eMMC 8 GiB ] ExtInfo : 0x00004000/00004000/00001000/00001000 Boot Ok! Format USER ... Format CACHE ... Format Ok! Remove FRP ( Google Reset Protection ) FRP removed! Tnx infinity team! |
How did you connected this model? I have the same E501 dual sim and can not connect with the CM2. In device manage I can find QC hs-usb QDloader 9008 port, but that is all. I use EDL cable and latest drivers of course. Thanks for help. Operation : Reset Settings [ v1.14 ] 1. Power Off Phone , Remove battery , Insert back 2. PRESS and HOLD BOTH VOLUME KEYS! 3. Insert USB cable. In some cases require use EDL cable or TP to force EDL mode! Wait for phone... Device Found! Initialize ... Error : Fail to init protocol! Check cable, connection and drivers! Reconnect Power/Cable! |
Wait for phone... Device Found! Initialize ... Handshake passed! BB_IDC_CPU : SnapDragon 210 [MSM8x09] ID_BLOCK_S : 1268D69A ID_BLOCK_I : 009600E1 ID_BLOCK_L : 161CF9C9DB516DFAB368E9E37574A96B ID_BLOCK_L : 78483FA1A74894A3C9805ACD18EC0522 Use BEST Internal Loader Error : Prepare target failed! Unsupported SecureType! Send log and report.log to support! Include device info also! Reconnect Power/Cable! |
