08-16-2022, 11:01 | #76 (permalink) |
Member: 1043909 Status: Offline Thanks Meter: 60,926 | [+] G-Touch [+] Hotwav [+] Infinix [+] Mito [+] Mobicel [+] QC-QcTech [+] Realme [+] Symphony [+] Stylus [+] ZTE |
08-18-2022, 15:34 | #78 (permalink) |
Junior Member Join Date: Mar 2014 Location: malawi LILONGWE
Member: 2138943 Status: Offline Thanks Meter: 5 | PLEASE HELP UNLOCK NETWORK ?? Device info : Product Brand : Itel Product Device : L6502 Product Model : itel L6502 Product Name : L6502 Patch Level : QP1A.190711.020 Display ID : L6502-F3208G-10.0-ZA-VDC-L-V009-20220428 Ver. Incmt : ZA-VDC-L-V009-20220428 Ver. CodeName : REL Ver. Release : 10 Sec. Patch : 2022-04-05 Build Time : 28.04.2022 Product Name : F3208G Product Device : itel-L6502 Product Info : L6502 Product Board : L6502 Board Platform : sp9832e Product Manfct : itel NVMng : SecurityInfo IMEI[1] : 356450383312284 IMEI[2] : 356450383312292 IMEI[3] : 867400020316638 WIFIMAC : FFFFFFFFFFFF BT_MAC : FFFFFFFFFFFF SEC : SLS:1, SKS:0, SKV:3 SLStatus : 32 Status : Locked! Server unlock required! >>> Error : Security override! Unsupported in selected mode! >>> Device supported in FLASH MODE! Select SS-base or MODEL loader and repeat under FLASH! |
The Following User Says Thank You to hezekiamalilana For This Useful Post: |
08-19-2022, 15:17 | #79 (permalink) | |
08-22-2022, 11:41 | #80 (permalink) |
Member: 2138943 Status: Offline Thanks Meter: 5 | I TRIED BOTH METHODS Operation : SP Unlock [ v2.14 ] BootMode : FLASH 1. Power off device, wait 10-15 seconds 2. Press and hold BooKey ( 1 : BOTH VOL , 2 : VOL+ , 3 : VOL- ) 3. Insert cable in device! Wait for device ... Device Connected! BootVersion : SPRD3 Boot : INF : iTel : L6502-F3208G Sending Init Boot ... Boot sent! Kick FDL ... BootVersion : Spreadtrum Boot Block version 1.1 Protocol setup ... Port speed : 921600 Sending Flash Boot ... Boot sent! Kick FLASH FDL ... FDL : 0x0008 FDL : EMMC_RO : False ; EMMC_PART : True ; EMMC_RPMB_SET : False FDL : RAW : 0x0002 FDL : FLH : 0x400000 FDL : SEC : RSA auth required! FDL : Process authentification ... FDL : SEC : RSA auth passed! FDL : Control transfered! Boot Done! Device info : Product Brand : Itel Product Device : L6502 Product Model : itel L6502 Product Name : L6502 Patch Level : QP1A.190711.020 Display ID : L6502-F3208G-10.0-ZA-VDC-L-V009-20220428 Ver. Incmt : ZA-VDC-L-V009-20220428 Ver. CodeName : REL Ver. Release : 10 Sec. Patch : 2022-04-05 Build Time : 28.04.2022 Product Name : F3208G Product Device : itel-L6502 Product Info : L6502 Product Board : L6502 Board Platform : sp9832e Product Manfct : itel NVMng : SecurityInfo IMEI[1] : 356450383312284 IMEI[2] : 356450383312292 IMEI[3] : 867400020316638 WIFIMAC : FFFFFFFFFFFF BT_MAC : FFFFFFFFFFFF SEC : SLS:1, SKS:0, SKV:3 SLStatus : 32 Status : Locked! Server unlock required! >>> Error : Security override! Unsupported in selected mode! >>> Device supported in FLASH MODE! Select SS-base or MODEL loader and repeat under FLASH! |
08-23-2022, 23:25 | #81 (permalink) | |
Result? | |
08-24-2022, 13:09 | #82 (permalink) |
Member: 2138943 Status: Offline Thanks Meter: 5 | Originally Posted by hezekiamalilana I TRIED BOTH METHODS Operation : SP Unlock [ v2.14 ] BootMode : FLASH 1. Power off device, wait 10-15 seconds 2. Press and hold BooKey ( 1 : BOTH VOL , 2 : VOL+ , 3 : VOL- ) 3. Insert cable in device! Wait for device ... Device Connected! BootVersion : SPRD3 Boot : INF : iTel : L6502-F3208G Sending Init Boot ... Boot sent! Kick FDL ... BootVersion : Spreadtrum Boot Block version 1.1 Protocol setup ... Port speed : 921600 Sending Flash Boot ... Boot sent! Kick FLASH FDL ... FDL : 0x0008 FDL : EMMC_RO : False ; EMMC_PART : True ; EMMC_RPMB_SET : False FDL : RAW : 0x0002 FDL : FLH : 0x400000 FDL : SEC : RSA auth required! FDL : Process authentification ... FDL : SEC : RSA auth passed! FDL : Control transfered! Boot Done! Device info : Product Brand : Itel Product Device : L6502 Product Model : itel L6502 Product Name : L6502 Patch Level : QP1A.190711.020 Display ID : L6502-F3208G-10.0-ZA-VDC-L-V009-20220428 Ver. Incmt : ZA-VDC-L-V009-20220428 Ver. CodeName : REL Ver. Release : 10 Sec. Patch : 2022-04-05 Build Time : 28.04.2022 Product Name : F3208G Product Device : itel-L6502 Product Info : L6502 Product Board : L6502 Board Platform : sp9832e Product Manfct : itel NVMng : SecurityInfo IMEI[1] : 356450383312284 IMEI[2] : 356450383312292 IMEI[3] : 867400020316638 WIFIMAC : FFFFFFFFFFFF BT_MAC : FFFFFFFFFFFF SEC : SLS:1, SKS:0, SKV:3 SLStatus : 32 Status : Locked! Server unlock required! >>> Error : Security override! Unsupported in selected mode! >>> Device supported in FLASH MODE! Select SS-base or MODEL loader and repeat under FLASH! Very good try but now you must repeat the process again but first read instruction that you see at LAST line of the software log text. Result? My customer withdrew the phone |
09-01-2022, 16:20 | #87 (permalink) |
Member: 2138943 Status: Offline Thanks Meter: 5 | PLEASE HELP Wait for device ... Device Connected! BootVersion : SPRD3 Boot : INF : INFINITY FW PACKAGE Sending Init Boot ... Boot sent! Kick FDL ... BootVersion : Spreadtrum Boot Block version 1.1 Protocol setup ... Port speed : 921600 Sending Flash Boot ... Boot sent! Kick FLASH FDL ... FDL : 0x0008 FDL : EMMC_RO : False ; EMMC_PART : True ; EMMC_RPMB_SET : False FDL : RAW : 0x0002 FDL : FLH : 0x400000 FDL : SEC : RSA auth required! FDL : Process authentification ... FDL : SEC : RSA auth passed! FDL : Control transfered! Boot Done! ERASE : FORMAT WHOLE FLASH ... ERASE : FORMAT FLASH Completed! PMTMng : Load PMT PMTMng : 0x29 PMTMng : Update PMT Ok! NVRM : nvitem_w.bin NVMng : Load 0x30 NVMng : Init SRC NVMng : Trying use recover mode NVMng : Security DAMAGED! NVMng : Backup Ok , 0x00100000 NVMng : Trying use recover mode NVMng : Init DST NVMng : NV has been destroyed! Forced Update enabled! Repair security after! NVMng : NVM block updated! Prepare target ... |
09-01-2022, 16:34 | #88 (permalink) |
09-12-2022, 10:04 | #89 (permalink) |
Member: 1043909 Status: Offline Thanks Meter: 60,926 | Infinity #CM2SP2 boot pack v1.11 released with updated loaders [+] Ais [+] BQ [+] Expert [+] FinePower [+] Ginzzu [+] Micromax [+] Oysters [+] Philips [+] Stark [+] teXet [+] Vertex https://infinity-box.com/news/?r=4269 |
10-12-2022, 11:16 | #90 (permalink) |
Member: 1043909 Status: Offline Thanks Meter: 60,926 | Infinity #CM2SP2 boot pack v1.12 released with updated loaders [+] Huawei [+] /boot-fdl/ has FDL loaders: - Blackview - Blu - BMobile - Infinix - iTel - Lenovo - Maxwest - Realme - Tecno - Yezz - ZTE https://infinity-box.com/news/?r=4276 |
