Com not available Hello. In my infinity showing "error com not available" .but some time working. i installed the diffrent driver version (1.2, 1.4).change the cable (usb v2.), formatt the pc. but not luck pls help.... THNX |
hello! i would advice to test following: go to windows device manager go to desired com port advanced settings and change it's value to another. i hope this will solve com port conflict |
my infinity showing "error com not available" even i changed the com,but the problem is same. thnk you adv |
COM6 [VCP0] selected error: can't open COM6 module v3.03 error: operation failed ! Finished, time used: 19 min 9 sec Remove/Install battery now ! |
hello! go to device manager, remove damaged port from system and install again. drivers you will find here: C:\Program Files\InfinityBox\Drivers\box\FTDI |
