11-18-2020, 19:05 | #1 (permalink) |
Junior Member Join Date: May 2018
Member: 2840925 Status: Offline Thanks Meter: 0 | connect the phone to the computer Card found : 340F2D5A , v0146 Infinity-Box [ Chinese Miracle ] MediaTek Service Module [ MTK ] v2.15 Load IDBase v729152 Ok! Operation : Identify [ v2.15 ] Mode : FLASH 1. Make sure device is powered off. Power off, if need. Wait 20 seconds after 2. Insert USB cable in phone Waiting for device connection ... PTFN : MTK USB Modem Port (COM79) MODE : PRELOADER PORT PORT : 79 Error : Failed to open port! Error : Fail to init protocol! >>> Remove battery, cable. Check cable/connection/driver! Check SW hint! Repeat operation! Reconnect Power/Cable! |
11-19-2020, 10:29 | #2 (permalink) |
Member: 462970 Status: Offline Thanks Meter: 20,352 | Port stuck by some reason. Try remove it in device manager and reboot PC for start. |
11-21-2020, 08:44 | #5 (permalink) |
Member: 2840925 Status: Offline Thanks Meter: 0 | I have tried the suggestion but it does not seem to work. I have uninstalled the mtk preloader driver and restarted the computer but I still get the error. Quite mysteriously, the CM2 MTK version works fine, the error is only in the CM2 MT2 version. |
11-23-2020, 19:55 | #7 (permalink) |
Member: 2840925 Status: Offline Thanks Meter: 0 | I do not have a usb modem, I use wifi. I uninstalled the mtk modem driver and the box moved on to the next available driver. I even removed all the mtk vcom drivers and it moved to mediatek usb ports and usb debug port, still displaying the same error message. |
