12-04-2016, 10:49 | #1 (permalink) |
No Life Poster Join Date: Jan 2009
Member: 946381 Status: Offline Thanks Meter: 150 | COOLPAD 8298-100 IMEI BLANK-help Wait for phone... Phone found! [ 24 ] Sync... Inital Boot Ok! BB_CPU_PID : 6735 BB_CPU_NME : [MediaTek] MT6735_S00 BB_CPU_EXT : 0xCA00 , 0x8A00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x00000000 BromVer : 0x00FF BLVersion : 0x0001 PreLoader : Active [ Boot with PL ] BootLdrSS : NORMAL with PRELOADER Processing DA stage DA Select done, will use MTK_AllInOne_DA_v5.1624.16.07 Sending and initialize DA ... Running DA ver.4.2 on BBID : 0x93 NAND Flash : NOT INSTALLED eMMC Flash : 484A01906532474181290705655E79A9 Initialize Memory ... DRAM already initialized by Preloader DAgent sent , init HW now eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0x90 , OEM : 014A [eMMC] : FLASH_INF : [HYNIX] , e2GA [eMMC] : FLASH_CID : 90014A484147326505072981A9792365 [eMMC] : FLASH_BRT : 0x00400000 , 0x00400000 , 0x00400000 [eMMC] : FLASH_LEN : 0x00000003AB800000 [eMMC] : FLASH_UCP : 15032 MiB [eMMC 16 GiB] DEV RID : 0x76D40596FF761D8CBAA9C6C91AC545B8 INT RAM : 0x00020000 EXT RAM : 0xC0000000 [3 GiB] BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! IMEI [00] : 357263047380400 IMEI [01] : 357263047380400 Set IMEI [00] : 911498056130887 Set IMEI [01] : 911498056130887 Prepare finished. Security check required! Wait for phone... Phone found! [ 24 ] Sync... Repair done! Done! Elapsed: 00:00:52 Reconnect Power/Cable! """"""""""""""""still imei blank"""""""""""""""""""""" so i repaired fix unknown baseband and again repeat imei rebuild -logs ok-but still imei blank so i think it software version problem-back sticker version 5.1.019 but menu version 15 """""""i think must need 5.1.019 flash file""""am i right? help me |
02-05-2018, 13:53 | #3 (permalink) |
Junior Member Join Date: Dec 2010
Member: 1469862 Status: Offline Thanks Meter: 0 | IMEI [00] : 357263047380400 IMEI [01] : 357263047380400 Set IMEI [00] : 911498056130887 Set IMEI [01] : 911498056130887 Prepare finished. Security check required! Wait for phone... Phone found! [ 24 ] Sync... Repair done! Done! Elapsed: 00:00:52 Reconnect Power/Cable! """"""""""""""""still imei blank"""""""""""""""""""""" so i repaired fix unknown baseband and again repeat imei rebuild -logs ok-but still imei blank after go 2 seting facter rest ur phonw with ur sim ur problam salou |
