07-01-2020, 09:19 | #1 (permalink) |
No Life Poster Join Date: Sep 2007 Location: rajasthan
Member: 597610 Status: Offline Thanks Meter: 50 | coolsand cpu unlocking problem Chinese Miracle II [RDA module] v 1.05 Operation : Check Device / Info ======= Settings Settings : Read AllInfo is Off Settings : Full Boot disabled by default Waiting phone ... Connect battery, press and hold '0' button Connect USB cable and keep hold button, until phone will be detected Phone not found Operation : Read User Code Waiting phone ... Connect battery, press and hold '0' button Connect USB cable and keep hold button, until phone will be detected Init : CCCDCCCC Settings registers ... 1st boot Ok ==== CPU CPU_ID : 0809 , rev : 0007 CPU_CN : ==== FLASH FL_VEN : 0000 , rev : 0000 FL_CNM : FL_CAP : 00000000 Initial : 81C0024C ==== Booting Sending RamRun Loader ... Set : 0809 , 00000000 Boot File Not Found! CPU not Supported , or BootFiles are missng. Contact to Support! Reconnect Power/Cable! which problem ......................???????????????????? boot file not found .................. |
07-01-2020, 12:41 | #2 (permalink) |
Member: 462970 Status: Offline Thanks Meter: 20,352 | Just open and use SCR module. It replace old RDA one. https://forum.gsmhosting.com/vbb/f29...tures-2823096/ |
