11-04-2016, 11:41 | #1 (permalink) |
Registered User Join Date: Sep 2015
Member: 2462860 Status: Offline Thanks Meter: 71 | world first zte v811w Infinity-Box Qualcomm Module [QLM] v 1.02 Operation : Identify [ v1.02 ] 1. Power Off Phone , Remove battery , Insert back 2. PRESS and HOLD BOTH VOLUME KEYS! 3. Insert USB cable. In some cases require use EDL cable or TP to force EDL mode! Wait for phone... Device Found! Initialize ... Handshake passed! ID_BLOCK_S : 00EC5471 ID_BLOCK_I : 008150E1 ID_BLOCK_L : 49C762F6FE52E492 ID_BLOCK_L : 9B939302A85331CC Use CM2 Internal Loader Error : Prepare target failed! Unsupported CPU??? Send log and report.log to support! Include device info also! Reconnect Power/Cable! Operation : Reset Settings [ v1.02 ] 1. Power Off Phone , Remove battery , Insert back 2. PRESS and HOLD BOTH VOLUME KEYS! 3. Insert USB cable. In some cases require use EDL cable or TP to force EDL mode! Wait for phone... Device Found! Initialize ... Handshake passed! ID_BLOCK_S : 00EC5471 ID_BLOCK_I : 008150E1 ID_BLOCK_L : 49C762F6FE52E492 ID_BLOCK_L : 9B939302A85331CC Use CM2 Internal Loader Error : Prepare target failed! Unsupported CPU??? Send log and report.log to support! Include device info also! Reconnect Power/Cable! Operation : Identify [ v1.02 ] 1. Power Off Phone , Remove battery , Insert back 2. PRESS and HOLD BOTH VOLUME KEYS! 3. Insert USB cable. In some cases require use EDL cable or TP to force EDL mode! Wait for phone... Device not found! Check cable, connection and drivers! Reconnect Power/Cable! Operation : Identify [ v1.02 ] 1. Power Off Phone , Remove battery , Insert back 2. PRESS and HOLD BOTH VOLUME KEYS! 3. Insert USB cable. In some cases require use EDL cable or TP to force EDL mode! Wait for phone... Device Found! Initialize ... Handshake passed! BB_IDC_CPU : SnapDragon 2x/4x|00 [MSM8x10] ID_BLOCK_S : 03505532 ID_BLOCK_I : 008110E1 ID_BLOCK_L : 49C762F6FE52E492 ID_BLOCK_L : 9B939302A85331CC Use CM2 Internal Loader Loader Sent! Initializing ... Running FireHose on BBID : MSM8x10 , FLASH : eMMC , VER : 1 ExtInfo : 0x0000C000/0000C000/00001000/00001000 Boot Ok! Brand : ZTE ProdName : ZTE-V811 ProdModel : ZTE V811W Device : P821E10 AndroidVer: 4.4.2 Manufact. : ZTE QLMxCPU : MSM8610 Done! Elapsed: 00:00:05 Reconnect Power/Cable! Operation : Read Flash [ v1.02 ] 1. Power Off Phone , Remove battery , Insert back 2. PRESS and HOLD BOTH VOLUME KEYS! 3. Insert USB cable. In some cases require use EDL cable or TP to force EDL mode! Wait for phone... Device Found! Initialize ... Handshake passed! BB_IDC_CPU : SnapDragon 2x/4x|00 [MSM8x10] ID_BLOCK_S : 03505532 ID_BLOCK_I : 008110E1 ID_BLOCK_L : 49C762F6FE52E492 ID_BLOCK_L : 9B939302A85331CC Use CM2 Internal Loader Loader Sent! Initializing ... Running FireHose on BBID : MSM8x10 , FLASH : eMMC , VER : 1 ExtInfo : 0x0000C000/0000C000/00001000/00001000 Boot Ok! Brand : ZTE ProdName : ZTE-V811 ProdModel : ZTE V811W Device : P821E10 AndroidVer: 4.4.2 Manufact. : ZTE QLMxCPU : MSM8610 DevInfo : MSM8610__ZTE__ZTE__ANDR_v4.4.2__ZTE_V811W__P821E10 __ZTE-V811 Reading Flash Content ... [Read Ok] : gpt_main0.bin [Read Ok] : NON-HLOS.bin [Read Ok] : sbl1.mbn [Read Ok] : deploy.mbn [Read Ok] : emmc_appsboot.mbn [Read Ok] : rpm.mbn [Read Ok] : boot.img [Read Ok] : tz.mbn [Read Ok] : system.img [Read Ok] : userdata.img [Read Ok] : persist.img [Read Ok] : cache.img [Read Ok] : recovery.img [Read Ok] : fs_gc.img [Read Ok] : splash.img [Read Ok] : gpt_backup0.bin Android Info saved! Read finished! Configuration : MSM8x10 / eMMC Firmware Size : 798 MiB Done! Elapsed: 00:02:31 Reconnect Power/Cable! Operation : Reset Settings [ v1.02 ] 1. Power Off Phone , Remove battery , Insert back 2. PRESS and HOLD BOTH VOLUME KEYS! 3. Insert USB cable. In some cases require use EDL cable or TP to force EDL mode! Wait for phone... Device Found! Initialize ... Handshake passed! BB_IDC_CPU : SnapDragon 2x/4x|00 [MSM8x10] ID_BLOCK_S : 03505532 ID_BLOCK_I : 008110E1 ID_BLOCK_L : 49C762F6FE52E492 ID_BLOCK_L : 9B939302A85331CC Use CM2 Internal Loader Loader Sent! Initializing ... Running FireHose on BBID : MSM8x10 , FLASH : eMMC , VER : 1 ExtInfo : 0x0000C000/0000C000/00001000/00001000 Boot Ok! Format USER ... Format CACHE ... Format Ok! Done! Elapsed: 00:00:32 Reconnect Power/Cable! Loading firmware ... Created by Infinity-Box (c) Chinese Miracle II (c) 2016 Device Brand : ZTE Device Manufact.: ZTE Device Model : P821E10 Device CPU : MSM8610 Device IntName : ZTE-V811 Device Version : 4.4.2 CU_SWVer : ZTE Device Compile : 5/22/2014 3:46:34 PM Device ExtInfo : ZTE V811W Load Ok! Operation : Flash [ v1.02 ] Verify FW package ... Verification passed! 1. Power Off Phone , Remove battery , Insert back 2. PRESS and HOLD BOTH VOLUME KEYS! 3. Insert USB cable. In some cases require use EDL cable or TP to force EDL mode! Wait for phone... Device Found! Initialize ... Handshake passed! BB_IDC_CPU : SnapDragon 2x/4x|00 [MSM8x10] ID_BLOCK_S : 03505532 ID_BLOCK_I : 008110E1 ID_BLOCK_L : 49C762F6FE52E492 ID_BLOCK_L : 9B939302A85331CC Pickup loader from firmware package Loader Sent! Initializing ... Running FireHose on BBID : MSM8x10 , FLASH : eMMC , VER : 1 ExtInfo : 0x0000C000/0000C000/00001000/00001000 Boot Ok! Files in Chain : 19 Flashing now Flashing : gpt_main0.bin Flashing : NON-HLOS.bin Flashing : sbl1.mbn Flashing : deploy.mbn Flashing : emmc_appsboot.mbn Flashing : rpm.mbn Flashing : boot.img Flashing : tz.mbn Flashing : system.img Flashing : userdata.img Flashing : persist.img Flashing : cache.img Flashing : recovery.img Flashing : splash.img Flashing : gpt_backup0.bin Flashing done! Done! Elapsed: 00:01:39 Reconnect Power/Cable! [IMG][/IMG] |
11-04-2016, 12:38 | #2 (permalink) |
No Life Poster Join Date: Feb 2010 Location: Pinas
Member: 1243303 Status: Offline Sonork: 1591167 Thanks Meter: 514 | what is trick all driver installed but cant coonect like this http://forum.gsmhosting.com/vbb/f296/zte-frp-2151916/ |
11-04-2016, 12:54 | #3 (permalink) | |
Member: 462970 Status: Offline Thanks Meter: 20,352 | Quote:
11-04-2016, 12:59 | #4 (permalink) |
Member: 462970 Status: Offline Thanks Meter: 20,352 | @ORITECH, can you share info about phone, which you try connect before that ZTE? Code: Operation : Reset Settings [ v1.02 ] 1. Power Off Phone , Remove battery , Insert back 2. PRESS and HOLD BOTH VOLUME KEYS! 3. Insert USB cable. In some cases require use EDL cable or TP to force EDL mode! Wait for phone... Device Found! Initialize ... Handshake passed! ID_BLOCK_S : 00EC5471 ID_BLOCK_I : 008150E1 ID_BLOCK_L : 49C762F6FE52E492 ID_BLOCK_L : 9B939302A85331CC Use CM2 Internal Loader Error : Prepare target failed! Unsupported CPU??? Send log and report.log to support! Include device info also! Reconnect Power/Cable! |
01-02-2017, 14:10 | #5 (permalink) |
Freak Poster Join Date: Sep 2008
Member: 853097 Status: Offline Sonork: 100.1622287 Thanks Meter: 131 | Code: Operation : Flash [ v1.02 ] Verify FW package ... Verification passed! 1. Power Off Phone , Remove battery , Insert back 2. PRESS and HOLD BOTH VOLUME KEYS! 3. Insert USB cable. In some cases require use EDL cable or TP to force EDL mode! Wait for phone... Device Found! Initialize ... Handshake passed! BB_IDC_CPU : SnapDragon 2x/4x|00 [MSM8x10] ID_BLOCK_S : 03505532 ID_BLOCK_I : 008110E1 ID_BLOCK_L : 49C762F6FE52E492 ID_BLOCK_L : 9B939302A85331CC Pickup loader from firmware package Loader Sent! Initializing ... Running FireHose on BBID : MSM8x10 , FLASH : eMMC , VER : 1 ExtInfo : 0x0000C000/0000C000/00001000/00001000 Boot Ok! Files in Chain : 19 Flashing now Flashing : gpt_main0.bin Flashing : NON-HLOS.bin Flashing : sbl1.mbn Flashing : deploy.mbn Flashing : emmc_appsboot.mbn Flashing : rpm.mbn Flashing : boot.img Flashing : tz.mbn Flashing : system.img Flashing : userdata.img Flashing : persist.img Flashing : cache.img Flashing : recovery.img Flashing : splash.img Flashing : gpt_backup0.bin Flashing done! Done! Elapsed: 00:01:39 Reconnect Power/Cable! Hi ORITECH, can u share that readed cm2 firmware? Thanks... |
