01-03-2009, 12:00 | #1 (permalink) |
Freak Poster Join Date: Feb 2006 Location: sri lanka
Member: 230371 Status: Offline Sonork: 100.1614924 Thanks Meter: 52 | Coral 200 successfull unlocked Logs, COM19 [VCP8] selected module v1.53 Device: Coral-200 Checking data, wait... Action: flash write Boot... Press and HOLD Power button now (if boot does not start remove/install batery) ! loading... next part... boot answer: 01 Release Power button now Boot Done Set Baud... 921600 Set Baud Done Connecting... flash: 00EC:22A0 Connecting Done Check hardware... Check hardware Done Check parameters... Check parameters Done backup critical area... reading [eeprom-sta]... file saved: D:\INFINITY BOX\InfinityBox\Pana01\Coral-200_eeprom-sta_20090103-152217.B1E.bin loading data... data loaded reading [eeprom-sec]... file saved: D:\INFINITY BOX\InfinityBox\Pana01\Coral-200_eeprom-sec_20090103-152227.B1E.bin reading [eeprom-complete]... file saved: D:\INFINITY BOX\InfinityBox\Pana01\Coral-200_eeprom-complete_20090103-152229.B1E.bin backup critical area Done Check memory... Check memory Done Write... reset... done Erasing: Firmware Writing: Firmware Erasing: Language Pack Writing: Language Pack Write Done Finished, Remove/Install battery now ! Time used: 125 sec COM19 [VCP8] selected module v1.53 Device: Coral-200 Checking data, wait... Action: unlock unlock method-1 Boot... Press and HOLD Power button now (if boot does not start remove/install batery) ! loading... next part... boot answer: 01 Release Power button now Boot Done Set Baud... 921600 Set Baud Done Connecting... flash: 00EC:22A0 Connecting Done Check hardware... Check hardware Done Check parameters... Check parameters Done backup critical area... reading [eeprom-sta]... file saved: D:\INFINITY BOX\InfinityBox\Pana01\Coral-200_eeprom-sta_20090103-152511.B1E.bin loading data... data loaded reading [eeprom-sec]... file saved: D:\INFINITY BOX\InfinityBox\Pana01\Coral-200_eeprom-sec_20090103-152513.B1E.bin reading [eeprom-complete]... file saved: D:\INFINITY BOX\InfinityBox\Pana01\Coral-200_eeprom-complete_20090103-152515.B1E.bin reading additional data... done backup critical area Done Check memory... current status: 0 Check memory Done Write... Erasing: lock-area Writing: lock-area Write Done Finished, Remove/Install battery now ! Time used: 21 sec Unlock instruction: 1. Power-On phone 2. Enter code: 12345678 |
The Following User Says Thank You to jayanthabandara For This Useful Post: |
== problem unlock ZTE coral 200 == | FMC_GSM | Infinity-Box | 7 | 07-20-2011 16:43 |
Coral 200 and coral 400 dead, badly support infinity ! | DENISCASTILLO | Infinity-Box | 2 | 08-19-2009 20:01 |
Problem on having unlocked Coral 200 and Coral 400 | unlockmoto | Infinity-Box | 11 | 05-07-2009 15:05 |
>>> Coral 200 successfully unlocked <<< | keaelite | Infinity-Box | 4 | 07-08-2008 07:49 |
Coral 200 successfully unlock but no service... | brabbsss | Infinity-Box | 5 | 05-07-2008 08:02 |
