04-30-2008, 03:52 | #1 (permalink) |
No Life Poster Join Date: Apr 2001 Location: Sun Age: 44
Member: 4021 Status: Offline Thanks Meter: 782 | coral 200 unlocking problem Code: COM3 [VCP0] selected Device: Coral-200 Checking data, wait... Action: unlock unlock method-1 Boot... Press and HOLD Power button now (if boot does not start remove/install batery) ! loading... next part... boot answer: 01 Release Power button now Boot Done Set Baud... 230400 Set Baud Done Connecting... flash: 00EC:22A0 Connecting Done Check hardware... flash chip supported Check hardware Done Check parameters... Check parameters Done backup critical area... reading [eeprom-sta]... file saved: C:\Program Files\InfinityBox\Pana01\backup_Coral-200_eeprom-sta_20080430-104845.B1E.bin loading data... data loaded reading [eeprom-sec]... file saved: C:\Program Files\InfinityBox\Pana01\backup_Coral-200_eeprom-sec_20080430-104905.B1E.bin reading [eeprom-complete]... file saved: C:\Program Files\InfinityBox\Pana01\backup_Coral-200_eeprom-complete_20080430-104909.B1E.bin reading additional data... done backup critical area Done Check memory... current status: 2 already done (mode-0), operation aborted Check memory Failed Finished, Remove/Install battery now ! Time used: 48 sec i already flashed it and even wrote an eeprom on it.. but still cant enter codes... this phone is digicel locked... please guide me... thanks! br |
04-30-2008, 04:11 | #2 (permalink) | |
No Life Poster Join Date: Jul 2006 Location: Philippines
Member: 306786 Status: Offline Sonork: 100.1596805 Thanks Meter: 516 | Quote:
If you want i will send you the files to unlock... YM: FMC_GSM | |
04-30-2008, 08:17 | #3 (permalink) | |
There is a manual in Infinity-Box support area: Infinity-Box-How_to_unlock_Coral-200.txt | |
04-30-2008, 08:23 | #4 (permalink) | |
Member: 4021 Status: Offline Thanks Meter: 782 | Quote:
can you please upload it here... i have problem with my YM sir... ill be waiting.. coz i only found two flash file at support site and still no luck.. @infinity support yes sir i did try that solution already but still no luck... phone is still locked.... thanks for the support!! br | |
05-01-2008, 03:23 | #5 (permalink) |
Member: 306786 Status: Offline Sonork: 100.1596805 Thanks Meter: 516 | DOwNload BeloW: Main => http://www.megaupload.com/?d=RCS204VK Lang => http://www.megaupload.com/?d=CHC9BY3N select ZTE-225 then enter unlock code post result... |
The Following User Says Thank You to FMC_GSM For This Useful Post: |
06-19-2008, 18:48 | #8 (permalink) | |
No Life Poster Join Date: Mar 2008 Location: infinity-box
Member: 720034 Status: Offline Thanks Meter: 213 | Quote:
Please, download manual from Infinity-Box support area: Infinity-Box-How_to_unlock_Coral-200.txt | |
== problem unlock ZTE coral 200 == | FMC_GSM | Infinity-Box | 7 | 07-20-2011 16:43 |
coral 200solar unlock problem.. | lester_oh | Infinity-Box | 4 | 03-28-2010 19:05 |
Problem on having unlocked Coral 200 and Coral 400 | unlockmoto | Infinity-Box | 11 | 05-07-2009 15:05 |
VK 200 unlocking problem.... | Faheem Anjum | FuriousGold | 4 | 02-05-2009 13:46 |
Coral 200 Unlocking help!!! | jburakers | Infinity-Box | 1 | 11-12-2008 11:41 |
