10-08-2009, 01:19 | #1 (permalink) |
No Life Poster Join Date: Jul 2006 Location: DAVIE FLORIDA
Member: 309299 Status: Offline Thanks Meter: 259 | coral 200fm, coral400fm, coral500fm all dead by infinity COM4 [VCP0] selected module v1.70 Device: Coral-200FM Checking data, wait... Action: flash write Boot ... Press and HOLD Power button now ! e-gold: 820000 loading... next part... boot answer: 01 Release Power button now Boot Done Set Baud ... 460800 Set Baud Done Connecting ... flash: 0098:0096 Connecting Done Check hardware ... Check hardware Done Check parameters ... Check parameters Done backup critical area ... reading eeprom-static... file saved: C:\Program Files\InfinityBox\Pana01\Coral-200FM_eeprom-static_20091007-180940.B1E.bin loading data... data loaded imei: 000000O00090<0G reading eeprom-security_000000O00090<0G... file saved: C:\Program Files\InfinityBox\Pana01\Coral-200FM_eeprom-security_000000O00090<0G_20091007-180941.B1E.bin reading eeprom-complete_000000O00090<0G... file saved: C:\Program Files\InfinityBox\Pana01\Coral-200FM_eeprom-complete_000000O00090<0G_20091007-180943.B1E.bin backup critical area Done Check memory ... Check memory Done Write ... reset... done Erasing: Firmware Writing: Firmware repair write error [00800000:0800]... error: write failed[00800000] Write Failed Finished, time used: 63 sec Remove/Install battery now ! and COM4 [VCP0] selected module v1.69 Device: Coral-500FM Checking data, wait... Action: unlock unlock method-1 Boot ... Press and HOLD Power button now ! e-gold: 820000 loading... next part... boot answer: 01 Release Power button now Boot Done Set Baud ... 921600 Set Baud Done Connecting ... flash: 0098:0096 Connecting Done Check hardware ... sw version: -DG-P108C1FM G U V1.0.0B03 13 56 54 VDF-P108C1FM G U B02-FrEs- Check hardware Done Check parameters ... Check parameters Done backup critical area ... reading eeprom-static... file saved: C:\Program Files\InfinityBox\Pana01\Coral-500FM_eeprom-static_20090810-141700.B1E.bin loading data... data loaded reading eeprom-security... file saved: C:\Program Files\InfinityBox\Pana01\Coral-500FM_eeprom-security_20090810-141700.B1E.bin reading eeprom-complete... file saved: C:\Program Files\InfinityBox\Pana01\Coral-500FM_eeprom-complete_20090810-141702.B1E.bin reading additional data... file saved: C:\Program Files\InfinityBox\Pana01\Coral-500FM_lock-area_20090810-141706.B1E.bin backup critical area Done Check memory ... lock found lock type #1 found Check memory Done Write ... Erasing: lock-area Writing: lock-area repair write error [00E00000:0800]... error: write failed[00E00000] Write Failed Finished, time used: 29 sec Remove/Install battery now ! and COM4 [VCP0] selected module v1.70 Device: Coral-400FM Checking data, wait... Action: flash write Boot ... Press and HOLD Power button now ! e-gold: 820000 loading... next part... boot answer: 01 Release Power button now Boot Done Set Baud ... 460800 Set Baud Done Connecting ... flash: 0098:0096 Connecting Done Check hardware ... Check hardware Done Check parameters ... Check parameters Done backup critical area ... reading eeprom-static... file saved: C:\Program Files\InfinityBox\Pana01\Coral-400FM_eeprom-static_20091007-180743.B1E.bin loading data... data loaded imei: ÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿ reading eeprom-security_ÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿ... file saved: C:\Program Files\InfinityBox\Pana01\Coral-400FM_eeprom-security_ÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿ_20091007-180745.B1E.bin reading eeprom-complete_ÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿ... file saved: C:\Program Files\InfinityBox\Pana01\Coral-400FM_eeprom-complete_ÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿ_20091007-180747.B1E.bin backup critical area Done Check memory ... Check memory Done Write ... reset... done Erasing: Firmware Writing: Firmware repair write error [00800000:0800]... error: write failed[00800000] Write Failed Finished, time used: 67 sec Remove/Install battery now ! all phones have the same problem so please give us solution it is like 4 months since i post the same problem since we do some test with me with the soft you send me and told me that you know where the problem was so what is your answer now are you going to fix this problem or not many users have the same problem with this model |
10-08-2009, 14:50 | #2 (permalink) |
Freak Poster Join Date: Oct 2007 Location: Heaven Age: 41
Member: 613221 Status: Offline Thanks Meter: 26 | I have the same problem with these phones, I recently posted a thread explaining the problem I had with a coral 200fm and didn't get an answer for support team. |
10-10-2009, 11:58 | #4 (permalink) |
Member: 309299 Status: Offline Thanks Meter: 259 | still waiting for answer with solution is been a long time and never get the solution or remove model in shell if you dont fully supported many phones killed in the area of the world because users think it is supported and try to unlock the phone since is listed and then we finish with brick in hand and mad clients |
10-13-2009, 18:02 | #7 (permalink) |
No Life Poster Join Date: Jan 2005 Location: Land of Lakes and Volcanoes Age: 51
Member: 111014 Status: Offline Thanks Meter: 132 | Why, support cant answer to this problem? But anyway Not only infinity kills these phone, Polarbox 2 kill too, I tried lol danm Im in trouble oh well |
11-07-2009, 04:56 | #12 (permalink) |
Member: 309299 Status: Offline Thanks Meter: 259 | dear supporter why dont you answer this post i got more than 6 months waiting for your response and like a month with this threat infinity still killing many coral 200fm, coral400fm, coral500fm from digicel salvador and digicel honduras when are you going to be able to launch and update that allow to write flash and unlock data in phone |
11-09-2009, 09:30 | #14 (permalink) |
Member: 130995 Status: Offline Thanks Meter: 35,227 | Hello, We are informed well about this problem (it's problem with latest hardware in this kind of phones). We have no solution yet for this problem but we are working to make solution. |
help infinity team, v670 dead by infinity !! | wejwej | Infinity-Box | 3 | 07-08-2009 09:38 |
coral 400 fm after unlock dead help infinity team | Rajkumar_India | Infinity-Box | 2 | 03-25-2009 18:08 |
Coral C200 Digicel Locked/ unlocked success by infinity box.. | kingskie | Infinity-Box | 1 | 11-20-2008 04:55 |
KG200 Dead by Infinity how 2 revive it ? | GSMBALOCH | Infinity-Box | 26 | 11-26-2007 19:42 |
j100i dead by infinity | .::ricky rayya::. | Infinity-Box | 5 | 04-30-2007 17:28 |
