09-08-2009, 09:05 | #1 (permalink) |
No Life Poster Join Date: Sep 2006 Location: Allah is Greatest
Member: 358694 Status: Offline Sonork: 100.1597323 Thanks Meter: 994 | Coral 300 Unlock here is the log COM11 [VCP0] selected module v1.32 Device: Coral-300 Checking data, wait... Action: unlock Boot ... Phone should be Switched OFF ! Press and HOLD Power button ! Connecting, wait... error: boot failed: Release Power button ! error: unexpected answer during boot procedure Boot Fail Finished, time used: 16 sec Remove/Install battery now ! now hot to solve the problem. here is my cable detail connector_usb_mini-5.gif keyboard top _____ /12345\ _______ 1: Gnd 3: box Tx/phone Rx (RJ45 pin-2) 4: box Rx/phone Tx (RJ45 pin-3) in case of connection problems add two 10k resistors: 1. from RJ-45 pin-1 to RJ-45 pin-2 2. from RJ-45 pin-1 to RJ-45 pin-3 |
09-08-2009, 09:12 | #2 (permalink) |
Member: 358694 Status: Offline Sonork: 100.1597323 Thanks Meter: 994 | Its ok. I have use power supply and now my phone is unlocked.. Thanks to My *** and infinity team. COM11 [VCP0] selected module v1.32 Device: Coral-300 Checking data, wait... Action: unlock Boot ... Phone should be Switched OFF ! Press and HOLD Power button ! Connecting, wait... Release Power button ! flash: EC22E000000000:70E59F00000000 flash: Samsung KAD060300B T 8Mb id: 00005258 Boot Done Set baud ... 115200 Set baud Done Check flash ... current eeprom imei: 356624012380839 file saved: C:\Program Files\InfinityBox\AModule\eeprom_356624012380839_C oral-300_20090908-131010.98E.bin Check flash Done Check space ... file saved: C:\Program Files\InfinityBox\AModule\_eeprom-calibration_20090908-131021.98E.bin file saved: C:\Program Files\InfinityBox\AModule\_eeprom-ffs_20090908-131109.98E.bin reading lock-area-2... file saved: C:\Program Files\InfinityBox\AModule\lock-area-2_Coral-300_20090908-131129.98E.bin Check space Done Check parameters ... Check parameters Done Erase ... Erase Done Write ... Write Done Finished, time used: 115 sec Remove/Install battery now ! |
The Following User Says Thank You to alamgarh For This Useful Post: |
11-23-2009, 15:46 | #3 (permalink) |
Freak Poster Join Date: Jun 2004 Age: 48
Member: 68824 Status: Offline Thanks Meter: 5 | Testing COM6 at 115200... COM6 selected Device: Alcatel OT152 Checking data, wait... Action: Unlock Boot... Phone must be POWERED-OFF ! Press and HOLD Power button ! Connecting, wait... Release Power button ! Flash: EC22E000000000 Flash: 70E59F00000000 flash: Samsung KAD060300B top 8 Mb Boot Done Set baud... 115200 Set baud Done Check flash... Check flash Done Check space... file saved: Backup_eeprom_2009-11-23_11-43-2.28E.bin Err: sp-unlocked or unknown eeprom Read flash and send to Support ! Check space Fail Finished, time used: 27 sec Remove/Install battery now ! can u please help me with this ? |
11-23-2009, 17:15 | #6 (permalink) |
Member: 130995 Status: Offline Thanks Meter: 35,227 | @jerrel_s now read your own post and tell me, what model you have tried to unlock ? http://forum.gsmhosting.com/vbb/show...92&postcount=3 waiting for your answer |
11-23-2009, 20:01 | #8 (permalink) | |
so why you ignored my advice and did not tried to read your own message carefully ? | |
11-24-2009, 12:32 | #9 (permalink) |
Member: 68824 Status: Offline Thanks Meter: 5 | ooh sorry my bad it would seem i have an old version of AMODULE (v1.16) and i can't seem to find v1.32 when i select coral 300 in the shell it gives me AMODULE alcatel ot-152 do you know where i can find AMODULE v1.32 ? |
11-24-2009, 20:38 | #10 (permalink) |
Member: 130995 Status: Offline Thanks Meter: 35,227 | Hello, You need to download and install latest full installation package from support area. Then do not forget to download and install latest updates from software/updates folder in support area. |
coral 300 unlock via modify cable.. | ken_jez | Infinity-Box | 1 | 12-06-2008 14:55 |
coral-300 unlock done | jakoy | Infinity-Box | 4 | 11-26-2008 22:04 |
help to unlock zte f156 & coral 300 & konka c625 | chris2007 | FuriousGold | 1 | 08-07-2008 03:41 |
Coral 300 Unlocked Successfully | elcapitel | Infinity-Box | 1 | 07-16-2008 14:41 |
error coral 300 unlocking | sabbalde | Infinity-Box | 3 | 03-21-2008 17:22 |
