02-25-2009, 13:56 | #1 (permalink) |
No Life Poster Join Date: Sep 2007 Location: Gsm_World
Member: 583353 Status: Offline Thanks Meter: 259 | -=coral c100 and c200 lock from digicel easily unlocked by infinity=- COM113 [VCP0] selected module v1.61 Device: Coral-100 Checking data, wait... Action: unlock unlock method-1 Boot ... loader: standard type: 4 Press and HOLD Power button now ! loading... next part... boot answer: 01 Release Power button now Boot Done Set Baud ... 115200 Set Baud Done Connecting ... flash: 0001:22C4 Connecting Done Check hardware ... sw version: -DG-P108A1V1.0.0B06 Sep 20 2007 11 27 47 04.12.00 18.26.11 08.02 Check hardware Done Check parameters ... Check parameters Done backup critical area ... reading eeprom-static... file saved: C:\Program Files\InfinityBox\Pana01\Coral-100_eeprom-static_20090223-151420.B1E.bin loading data... data loaded reading eeprom-security... file saved: C:\Program Files\InfinityBox\Pana01\Coral-100_eeprom-security_20090223-151421.B1E.bin reading eeprom-complete... file saved: C:\Program Files\InfinityBox\Pana01\Coral-100_eeprom-complete_20090223-151427.B1E.bin reading additional data... file saved: C:\Program Files\InfinityBox\Pana01\Coral-100_lock-area_20090223-151447.B1E.bin backup critical area Done Check memory ... lock found Check memory Done Write ... Erasing: lock-area Writing: lock-area Write Done Finished, time used: 65 sec Remove/Install battery now ! CORAL C200 LOGS: COM113 [VCP0] selected module v1.61 Device: Coral-200 Checking data, wait... Action: unlock unlock method-1 Boot ... loader: standard type: 4 Press and HOLD Power button now ! loading... next part... boot answer: 01 Release Power button now Boot Done Set Baud ... 115200 Set Baud Done Connecting ... flash: 00EC:22A0 Connecting Done Check hardware ... sw version: -DG-P108A2V1.0.0B06 Sep 20 2007 11 40 41 VDF-P108A2B07-FrEs-DG05 Check hardware Done Check parameters ... Check parameters Done backup critical area ... reading eeprom-static... file saved: C:\Program Files\InfinityBox\Pana01\Coral-200_eeprom-static_20090223-152046.B1E.bin loading data... data loaded reading eeprom-security... file saved: C:\Program Files\InfinityBox\Pana01\Coral-200_eeprom-security_20090223-152047.B1E.bin reading eeprom-complete... file saved: C:\Program Files\InfinityBox\Pana01\Coral-200_eeprom-complete_20090223-152054.B1E.bin reading additional data... file saved: C:\Program Files\InfinityBox\Pana01\Coral-200_lock-area_20090223-152106.B1E.bin backup critical area Done Check memory ... lock found Check memory Done Write ... Erasing: lock-area Writing: lock-area Write Done Finished, time used: 61 sec Remove/Install battery now ! BR, |
The Following User Says Thank You to nelsky For This Useful Post: |
05-18-2009, 20:58 | #3 (permalink) |
Member: 130995 Status: Offline Thanks Meter: 35,227 | Hello, Here is an instruction how to get cable/pinout information: 1. be sure that you have downloaded and installed latest Infinity-Box Pinouts update 2. run Infinity-Box Shell 3. select required model 4. see detailed information about cable/pinout (Rx/Tx/Gnd pins and other information) Here is an example of information given by Infinity-Box Shell: Here is information how to build your own cable: http:///vbb/showthread.php?t=342807 |
lg kh1200 locked from cyon ..need unlock.. | alf007 | LG | 25 | 09-23-2010 20:44 |
v570x unlocked by infinity and me!!!! | doonyi | Infinity-Box | 1 | 04-20-2009 10:36 |
-=m3200 samsung easily unlocked by ust-pro v8.6=- | nelsky | UST Pro II | 0 | 02-01-2009 15:35 |
8210, v5.28, mcc+mnc and gid1 locked, from orange,help! | rango | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 1 | 12-18-2001 10:53 |
