01-04-2012, 08:55 | #1 (permalink) |
Freak Poster Join Date: Jul 2003 Age: 45
Member: 34261 Status: Offline Thanks Meter: 6 | Cordless Phone Model : FC 8050 Not unlocked COM2 [VCP0] selected module v4.13 Device: _Autodetect MT6205-6239 NOR Checking data, wait... advanced flash detection enabled Action: "sp-unlock" unlock method: standard ffs/eeprom backup enabled, it may takes several minutes ! ====> Boot ... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing [6223:8A08]... CPU: MT6223 high speed boot On chip: 0011:67F1:000C status: FF boot packet size: 0400 Release Power button now ! Boot Done ====> Initialize ... detecting chip #00 in region #00... flash: 7F227E220A2201:2BEA0000000000 flash: AMD/Fujitsu std [D 0008x002000 003Ex010000 0008x002000] 4Mb otp offset: 00000000 detecting chip #01 in region #00... flash: 7F227E220A2201:2BEA0000000000 flash: AMD/Fujitsu std [D 0008x002000 003Ex010000 0008x002000] 4Mb otp offset: 00000000 detecting chip #02 in region #00... flash: 7F227E220A2201:2BEA0000000000 flash: AMD/Fujitsu std [D 0008x002000 003Ex010000 0008x002000] 4Mb otp offset: 00000000 detecting chip #03 in region #00... flash: 7F227E220A2201:2BEA0000000000 flash: AMD/Fujitsu std [D 0008x002000 003Ex010000 0008x002000] 4Mb otp offset: 00000000 detecting chip #04 in region #00... flash: 7F227E220A2201:2BEA0000000000 flash: AMD/Fujitsu std [D 0008x002000 003Ex010000 0008x002000] 4Mb otp offset: 00000000 detecting chip #05 in region #00... flash: 7F227E220A2201:2BEA0000000000 flash: AMD/Fujitsu std [D 0008x002000 003Ex010000 0008x002000] 4Mb otp offset: 00000000 detecting chip #06 in region #00... flash: 7F227E220A2201:2BEA0000000000 flash: AMD/Fujitsu std [D 0008x002000 003Ex010000 0008x002000] 4Mb otp offset: 00000000 detecting chip #07 in region #00... flash: 7F227E220A2201:2BEA0000000000 flash: AMD/Fujitsu std [D 0008x002000 003Ex010000 0008x002000] 4Mb otp offset: 00000000 detecting chip #08 in region #00... flash: 7F227E220A2201:2BEA0000000000 flash: AMD/Fujitsu std [D 0008x002000 003Ex010000 0008x002000] 4Mb otp offset: 00000000 detecting chip #09 in region #00... flash: 7F227E220A2201:2BEA0000000000 flash: AMD/Fujitsu std [D 0008x002000 003Ex010000 0008x002000] 4Mb otp offset: 00000000 detecting chip #0A in region #00... flash: 7F227E220A2201:2BEA0000000000 flash: AMD/Fujitsu std [D 0008x002000 003Ex010000 0008x002000] 4Mb otp offset: 00000000 detecting chip #0B in region #00... flash: 7F227E220A2201:2BEA0000000000 flash: AMD/Fujitsu std [D 0008x002000 003Ex010000 0008x002000] 4Mb otp offset: 00000000 detecting chip #0C in region #00... flash: 7F227E220A2201:2BEA0000000000 flash: AMD/Fujitsu std [D 0008x002000 003Ex010000 0008x002000] 4Mb otp offset: 00000000 detecting chip #0D in region #00... flash: 7F227E220A2201:2BEA0000000000 flash: AMD/Fujitsu std [D 0008x002000 003Ex010000 0008x002000] 4Mb otp offset: 00000000 detecting chip #0E in region #00... flash: 7F227E220A2201:2BEA0000000000 flash: AMD/Fujitsu std [D 0008x002000 003Ex010000 0008x002000] 4Mb otp offset: 00000000 detecting chip #0F in region #00... flash: 7F227E220A2201:2BEA0000000000 flash: AMD/Fujitsu std [D 0008x002000 003Ex010000 0008x002000] 4Mb otp offset: 00000000 number of flash chip/regions detected: 10/01 Initialize Done ====> Set baud ... 115200 Set baud Done ====> Initialize bootcode ... interesting cpu type found Initialize bootcode Done ====> Check firmware integrity ... device parameters detection in progress... detecting chip #00 in region #00... flash: 7F227E220A2201:2BEA0000000000 flash: AMD/Fujitsu std [D 0008x002000 003Ex010000 0008x002000] 4Mb otp offset: 00000000 detecting chip #01 in region #00... flash: 7F227E220A2201:2BEA0000000000 flash: AMD/Fujitsu std [D 0008x002000 003Ex010000 0008x002000] 4Mb otp offset: 00000000 it's time to stop: 2B0000EA18F09FE518F09FE518F09FE518F09FE518F09FE5 number of flash chip/regions detected: 01/01 total flash region size: 00400000 usb bootloader detect... .. usb bootloader detect (phase #2)... .. usb bootloader (chip) is absent searching rom info... search rom info finished rom info structure: [standard] type (04) TCL-ID is absent rom info detection finished rom info ver: 04 sw version: ATEL23_08A_BULGRIAN_PCB01_GSM_MT6223_S00.08GE0_H_0 7_11.BIN project-id: 08GE0_H_07_11, 00000000 code offset: 00000000 ffs offset/size [01]: 00380000/00080000 rom info structure: [standard] type (04) TCL-ID is absent detecting ffs/eeprom area in 1 chip(s)... standard ffs/eeprom offset detected: 00380000 standard ffs/eeprom offset confirmed: 00380000 detecting ffs/eeprom size... ffs/eeprom size: 00080000 ffs/eeprom chip: 00 ffs/eeprom area: 00000000:00380000-003FFFFF firmware area: 00000000-0037FFFF detecting startup code area #2... .................................................. .................................................. .................................................. .................................................. .................................................. ...... startup code area #2 is absent detecting ffs/eeprom structure pass 1... .......... ffs/eeprom: detect std location pass #1... .............. ffs/eeprom: detect ext location pass #1... ............ ffs/eeprom: detect standard offset pass #1... ffs/eeprom record offset detected ffs/eeprom: detect standard data... ffs/eeprom record size detected ffs/eeprom layout detection complete ffs/eeprom detected ok: element #1 sec info (detailed) detection... searching sec info#1... . search sec info#1 finished Check firmware integrity Done ====> Check firmware content ... Check firmware content Done ====> Backup required data ... reading: ATEL23_08A_BULGRIAN_PCB01_GSM_MT6223_S00.08GE0_H_0 7_11__ffs... file saved: C:\InfinityBox\MModule\ATEL23_08A_BULGRIAN_PCB01_G SM_MT6223_S00.08GE0_H_07_11__ffs_20111228-124200.B0E.bin flash: 7F227E220A2201:2BEA0000000000 Backup required data Done ====> Patch required data ... detection procedure, wait... detection procedure completed Patch required data Done ====> Special operation ... Special operation Done ====> Write ... flash: 7F227E220A2201:2BEA0000000000 Write: ffs Write Done ====> Finalization ... Finalization Done Finished, time used: 3 min 13 sec Remove/Install battery now ! Phone says " OPERATOR LOCKED " Support help !!! BR Kotogsm |
01-04-2012, 17:43 | #3 (permalink) |
Member: 34261 Status: Offline Thanks Meter: 6 | Hi Thanks for fast answer . After format FFS complete , no result " OPERATOR LOCKED " Here log : COM2 [VCP0] selected module v4.13 Device: _Autodetect MT6205-6239 NOR Checking data, wait... advanced flash detection enabled Action: reset settings ("format ffs") Do you want to make ffs/eeprom backup before format ? ffs/eeprom backup enabled, it may takes several minutes ! ====> Boot ... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing [6223:8A08]... CPU: MT6223 high speed boot On chip: 0011:67F1:000C status: FF boot packet size: 0400 Release Power button now ! Boot Done ====> Initialize ... detecting chip #00 in region #00... flash: 7F227E220A2201:2BEA0000000000 flash: AMD/Fujitsu std [D 0008x002000 003Ex010000 0008x002000] 4Mb otp offset: 00000000 detecting chip #01 in region #00... flash: 7F227E220A2201:2BEA0000000000 flash: AMD/Fujitsu std [D 0008x002000 003Ex010000 0008x002000] 4Mb otp offset: 00000000 detecting chip #02 in region #00... flash: 7F227E220A2201:2BEA0000000000 flash: AMD/Fujitsu std [D 0008x002000 003Ex010000 0008x002000] 4Mb otp offset: 00000000 detecting chip #03 in region #00... flash: 7F227E220A2201:2BEA0000000000 flash: AMD/Fujitsu std [D 0008x002000 003Ex010000 0008x002000] 4Mb otp offset: 00000000 detecting chip #04 in region #00... flash: 7F227E220A2201:2BEA0000000000 flash: AMD/Fujitsu std [D 0008x002000 003Ex010000 0008x002000] 4Mb otp offset: 00000000 detecting chip #05 in region #00... flash: 7F227E220A2201:2BEA0000000000 flash: AMD/Fujitsu std [D 0008x002000 003Ex010000 0008x002000] 4Mb otp offset: 00000000 detecting chip #06 in region #00... flash: 7F227E220A2201:2BEA0000000000 flash: AMD/Fujitsu std [D 0008x002000 003Ex010000 0008x002000] 4Mb otp offset: 00000000 detecting chip #07 in region #00... flash: 7F227E220A2201:2BEA0000000000 flash: AMD/Fujitsu std [D 0008x002000 003Ex010000 0008x002000] 4Mb otp offset: 00000000 detecting chip #08 in region #00... flash: 7F227E220A2201:2BEA0000000000 flash: AMD/Fujitsu std [D 0008x002000 003Ex010000 0008x002000] 4Mb otp offset: 00000000 detecting chip #09 in region #00... flash: 7F227E220A2201:2BEA0000000000 flash: AMD/Fujitsu std [D 0008x002000 003Ex010000 0008x002000] 4Mb otp offset: 00000000 detecting chip #0A in region #00... flash: 7F227E220A2201:2BEA0000000000 flash: AMD/Fujitsu std [D 0008x002000 003Ex010000 0008x002000] 4Mb otp offset: 00000000 detecting chip #0B in region #00... flash: 7F227E220A2201:2BEA0000000000 flash: AMD/Fujitsu std [D 0008x002000 003Ex010000 0008x002000] 4Mb otp offset: 00000000 detecting chip #0C in region #00... flash: 7F227E220A2201:2BEA0000000000 flash: AMD/Fujitsu std [D 0008x002000 003Ex010000 0008x002000] 4Mb otp offset: 00000000 detecting chip #0D in region #00... flash: 7F227E220A2201:2BEA0000000000 flash: AMD/Fujitsu std [D 0008x002000 003Ex010000 0008x002000] 4Mb otp offset: 00000000 detecting chip #0E in region #00... flash: 7F227E220A2201:2BEA0000000000 flash: AMD/Fujitsu std [D 0008x002000 003Ex010000 0008x002000] 4Mb otp offset: 00000000 detecting chip #0F in region #00... flash: 7F227E220A2201:2BEA0000000000 flash: AMD/Fujitsu std [D 0008x002000 003Ex010000 0008x002000] 4Mb otp offset: 00000000 number of flash chip/regions detected: 10/01 Initialize Done ====> Set baud ... 921600 Set baud Done ====> Initialize bootcode ... interesting cpu type found Initialize bootcode Done ====> Check firmware integrity ... device parameters detection in progress... detecting chip #00 in region #00... flash: 7F227E220A2201:2BEA0000000000 flash: AMD/Fujitsu std [D 0008x002000 003Ex010000 0008x002000] 4Mb otp offset: 00000000 detecting chip #01 in region #00... flash: 7F227E220A2201:2BEA0000000000 flash: AMD/Fujitsu std [D 0008x002000 003Ex010000 0008x002000] 4Mb otp offset: 00000000 it's time to stop: 2B0000EA18F09FE518F09FE518F09FE518F09FE518F09FE5 number of flash chip/regions detected: 01/01 total flash region size: 00400000 usb bootloader detect... .. usb bootloader detect (phase #2)... .. usb bootloader (chip) is absent searching rom info... search rom info finished rom info structure: [standard] type (04) TCL-ID is absent rom info detection finished rom info ver: 04 sw version: ATEL23_08A_BULGRIAN_PCB01_GSM_MT6223_S00.08GE0_H_0 7_11.BIN project-id: 08GE0_H_07_11, 00000000 code offset: 00000000 ffs offset/size [01]: 00380000/00080000 rom info structure: [standard] type (04) TCL-ID is absent detecting ffs/eeprom area in 1 chip(s)... standard ffs/eeprom offset detected: 00380000 standard ffs/eeprom offset confirmed: 00380000 detecting ffs/eeprom size... ffs/eeprom size: 00080000 ffs/eeprom chip: 00 ffs/eeprom area: 00000000:00380000-003FFFFF firmware area: 00000000-0037FFFF sec info (detailed) detection... searching sec info#1... . search sec info#1 finished Check firmware integrity Done ====> Check firmware content ... Check firmware content Done ====> Backup required data ... reading: ATEL23_08A_BULGRIAN_PCB01_GSM_MT6223_S00.08GE0_H_0 7_11__ffs... file saved: C:\InfinityBox\MModule\mtel-nov\ATEL23_08A_BULGRIAN_PCB01_GSM_MT6223_S00.08GE0 _H_07_11__ffs_20120104-183747.B0E.bin flash: 7F227E220A2201:2BEA0000000000 Backup required data Done ====> Patch required data ... Patch required data Done ====> Special operation ... Special operation Done ====> Write ... Write Done ====> Finalization ... ffs formatting... flash: 7F227E220A2201:2BEA0000000000 Finalization Done Finished, time used: 1 min 17 sec Remove/Install battery now ! File system has been modified ! It is need to press and HOLD phone "Power" button during long time (up to 1 min) to make phone Powered-On ! |
02-22-2012, 10:27 | #12 (permalink) | |
Please, send operation log text for unlock operation to [email protected] Also, do you know locked operator MCC/MNC ? | |
6110 power does not stay on | sc~micro | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 6 | 08-30-2014 08:14 |
