02-16-2012, 12:08 | #1 (permalink) |
Freak Poster Join Date: Nov 2005 Location: Sliven, Bulgaria
Member: 198847 Status: Offline Thanks Meter: 109 | Cordless Phone FC8050- Error unlocking 1.unlock metod: read code - result-error 2.unlock metod: standart-result-done, but phone is locked 3.unlock metod: standart fast- result-done, but phone is locked 4.unlock metod: smart fast-result-error Code: ==== [16/2/2012 г. 12:39:22] ==== COM5 [VCP0] selected module v4.16 Action: read unlock codes unlock method: read codes Model: _Autodetect MT6205-6239 NOR Checking data, wait... Phone should be Switched OFF ! Press and HOLD Power button now ! 19200 autodetect Initializing [6223:8A08]... CPU: MT6223 high speed boot On chip: 0011:55E8:000C status: FF Connecting at 19200, wait... Release Power button now ! Phone detected, wait... Hardware: MT6223,E08 Date: 2000.00.00 Version: 1.0 Version: 08GE0_H_07_11 Version: ATEL23_08A_HW detecting structure #2... 1 2 3 5 7 8 9 11 13 done 80 byte(s) read imei: 35876002429204 connection Ok detecting structure #1... 0 1 2 3 4 7 8 9 12 13 14 15 17 20 21 22 23 24 27 28 29warning: wrong packet cs 32 33 34 35warning: wrong packet cs 37error: detection failed (26 tries), read flash and send to support error: can't read required data error: operation failed ! Finished, time used: 15 sec Remove/Install battery now ! ==== [16/2/2012 г. 12:39:58] ==== COM5 [VCP0] selected module v4.16 Device: _Autodetect MT6205-6239 NOR Checking data, wait... advanced flash detection enabled Action: "sp-unlock" unlock method: standard ffs/eeprom backup enabled, it may takes several minutes ! ====> Boot ... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing [6223:8A08]... CPU: MT6223 high speed boot On chip: 0011:55E8:000C status: FF boot packet size: 0400 Release Power button now ! Boot Done ====> Initialize ... detecting chip #00 in region #00... flash: 7F227E220A2201:2BEA0000000000 flash: AMD/Fujitsu std [D 0008x002000 003Ex010000 0008x002000] 4Mb otp offset: 00000000 detecting chip #01 in region #00... flash: 7F227E220A2201:2BEA0000000000 flash: AMD/Fujitsu std [D 0008x002000 003Ex010000 0008x002000] 4Mb otp offset: 00000000 detecting chip #02 in region #00... flash: 7F227E220A2201:2BEA0000000000 flash: AMD/Fujitsu std [D 0008x002000 003Ex010000 0008x002000] 4Mb otp offset: 00000000 detecting chip #03 in region #00... flash: 7F227E220A2201:2BEA0000000000 flash: AMD/Fujitsu std [D 0008x002000 003Ex010000 0008x002000] 4Mb otp offset: 00000000 detecting chip #04 in region #00... flash: 7F227E220A2201:2BEA0000000000 flash: AMD/Fujitsu std [D 0008x002000 003Ex010000 0008x002000] 4Mb otp offset: 00000000 detecting chip #05 in region #00... flash: 7F227E220A2201:2BEA0000000000 flash: AMD/Fujitsu std [D 0008x002000 003Ex010000 0008x002000] 4Mb otp offset: 00000000 detecting chip #06 in region #00... flash: 7F227E220A2201:2BEA0000000000 flash: AMD/Fujitsu std [D 0008x002000 003Ex010000 0008x002000] 4Mb otp offset: 00000000 detecting chip #07 in region #00... flash: 7F227E220A2201:2BEA0000000000 flash: AMD/Fujitsu std [D 0008x002000 003Ex010000 0008x002000] 4Mb otp offset: 00000000 detecting chip #08 in region #00... flash: 7F227E220A2201:2BEA0000000000 flash: AMD/Fujitsu std [D 0008x002000 003Ex010000 0008x002000] 4Mb otp offset: 00000000 detecting chip #09 in region #00... flash: 7F227E220A2201:2BEA0000000000 flash: AMD/Fujitsu std [D 0008x002000 003Ex010000 0008x002000] 4Mb otp offset: 00000000 detecting chip #0A in region #00... flash: 7F227E220A2201:2BEA0000000000 flash: AMD/Fujitsu std [D 0008x002000 003Ex010000 0008x002000] 4Mb otp offset: 00000000 detecting chip #0B in region #00... flash: 7F227E220A2201:2BEA0000000000 flash: AMD/Fujitsu std [D 0008x002000 003Ex010000 0008x002000] 4Mb otp offset: 00000000 detecting chip #0C in region #00... flash: 7F227E220A2201:2BEA0000000000 flash: AMD/Fujitsu std [D 0008x002000 003Ex010000 0008x002000] 4Mb otp offset: 00000000 detecting chip #0D in region #00... flash: 7F227E220A2201:2BEA0000000000 flash: AMD/Fujitsu std [D 0008x002000 003Ex010000 0008x002000] 4Mb otp offset: 00000000 detecting chip #0E in region #00... flash: 7F227E220A2201:2BEA0000000000 flash: AMD/Fujitsu std [D 0008x002000 003Ex010000 0008x002000] 4Mb otp offset: 00000000 detecting chip #0F in region #00... flash: 7F227E220A2201:2BEA0000000000 flash: AMD/Fujitsu std [D 0008x002000 003Ex010000 0008x002000] 4Mb otp offset: 00000000 number of flash chip/regions detected: 10/01 Initialize Done ====> Set baud ... 230400 Set baud Done ====> Initialize bootcode ... interesting cpu type found Initialize bootcode Done ====> Check firmware integrity ... device parameters detection in progress... detecting chip #00 in region #00... flash: 7F227E220A2201:2BEA0000000000 flash: AMD/Fujitsu std [D 0008x002000 003Ex010000 0008x002000] 4Mb otp offset: 00000000 detecting chip #01 in region #00... flash: 7F227E220A2201:2BEA0000000000 flash: AMD/Fujitsu std [D 0008x002000 003Ex010000 0008x002000] 4Mb otp offset: 00000000 it's time to stop: 2B0000EA18F09FE518F09FE518F09FE518F09FE518F09FE5 number of flash chip/regions detected: 01/01 total flash region size: 00400000 usb bootloader detect... .. usb bootloader detect (phase #2)... .. usb bootloader (chip) is absent searching rom info... search rom info finished rom info structure: [standard] type (04) TCL-ID is absent rom info detection finished rom info ver: 04 sw version: ATEL23_08A_BULGRIAN_PCB01_GSM_MT6223_S00.08GE0_H_07_11.BIN project-id: 08GE0_H_07_11, 00000000 code offset: 00000000 ffs offset/size [01]: 00380000/00080000 rom info structure: [standard] type (04) TCL-ID is absent detecting ffs/eeprom area in 1 chip(s)... standard ffs/eeprom offset detected: 00380000 standard ffs/eeprom offset confirmed: 00380000 detecting ffs/eeprom size... ffs/eeprom size: 00080000 ffs/eeprom chip: 00 ffs/eeprom area: 00000000:00380000-003FFFFF firmware area: 00000000-0037FFFF detecting startup code area #2... ................................................................................................................................................................................................................................................................ startup code area #2 is absent detecting ffs/eeprom structure pass 1... .......... ffs/eeprom: detect std location pass #1... .............. ffs/eeprom: detect ext location pass #1... ............ ffs/eeprom: detect standard offset pass #1... ffs/eeprom record offset detected ffs/eeprom: detect standard data... ffs/eeprom record size detected ffs/eeprom layout detection complete ffs/eeprom detected ok: element #1 sec info (detailed) detection... searching sec info#1... . search sec info#1 finished Check firmware integrity Done ====> Check firmware content ... Check firmware content Done ====> Backup required data ... reading: ATEL23_08A_BULGRIAN_PCB01_GSM_MT6223_S00.08GE0_H_07_11__ffs... file saved: D:\Program Files\InfinityBox\MModule\Backup\FC8050\ATEL23_08A_BULGRIAN_PCB01_GSM_MT6223_S00.08GE0_H_07_11__ffs_20120216-124208.B0E.bin flash: 7F227E220A2201:2BEA0000000000 Backup required data Done ====> Patch required data ... detection procedure, wait... detection procedure completed Patch required data Done ====> Special operation ... Special operation Done ====> Write ... flash: 7F227E220A2201:2BEA0000000000 Write: ffs Write Done ====> Finalization ... Finalization Done Finished, time used: 2 min 21 sec Remove/Install battery now ! ==== [16/2/2012 г. 12:47:51] ==== COM5 [VCP0] selected module v4.16 Device: _Autodetect MT6205-6239 NOR Checking data, wait... advanced flash detection enabled Action: "sp-unlock" unlock method: standard fast ====> Boot ... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing [6223:8A08]... CPU: MT6223 high speed boot On chip: 0011:55E8:000C status: FF boot packet size: 0400 Release Power button now ! Boot Done ====> Initialize ... detecting chip #00 in region #00... flash: 7F227E220A2201:2BEA0000000000 flash: AMD/Fujitsu std [D 0008x002000 003Ex010000 0008x002000] 4Mb otp offset: 00000000 detecting chip #01 in region #00... flash: 7F227E220A2201:2BEA0000000000 flash: AMD/Fujitsu std [D 0008x002000 003Ex010000 0008x002000] 4Mb otp offset: 00000000 detecting chip #02 in region #00... flash: 7F227E220A2201:2BEA0000000000 flash: AMD/Fujitsu std [D 0008x002000 003Ex010000 0008x002000] 4Mb otp offset: 00000000 detecting chip #03 in region #00... flash: 7F227E220A2201:2BEA0000000000 flash: AMD/Fujitsu std [D 0008x002000 003Ex010000 0008x002000] 4Mb otp offset: 00000000 detecting chip #04 in region #00... flash: 7F227E220A2201:2BEA0000000000 flash: AMD/Fujitsu std [D 0008x002000 003Ex010000 0008x002000] 4Mb otp offset: 00000000 detecting chip #05 in region #00... flash: 7F227E220A2201:2BEA0000000000 flash: AMD/Fujitsu std [D 0008x002000 003Ex010000 0008x002000] 4Mb otp offset: 00000000 detecting chip #06 in region #00... flash: 7F227E220A2201:2BEA0000000000 flash: AMD/Fujitsu std [D 0008x002000 003Ex010000 0008x002000] 4Mb otp offset: 00000000 detecting chip #07 in region #00... flash: 7F227E220A2201:2BEA0000000000 flash: AMD/Fujitsu std [D 0008x002000 003Ex010000 0008x002000] 4Mb otp offset: 00000000 detecting chip #08 in region #00... flash: 7F227E220A2201:2BEA0000000000 flash: AMD/Fujitsu std [D 0008x002000 003Ex010000 0008x002000] 4Mb otp offset: 00000000 detecting chip #09 in region #00... flash: 7F227E220A2201:2BEA0000000000 flash: AMD/Fujitsu std [D 0008x002000 003Ex010000 0008x002000] 4Mb otp offset: 00000000 detecting chip #0A in region #00... flash: 7F227E220A2201:2BEA0000000000 flash: AMD/Fujitsu std [D 0008x002000 003Ex010000 0008x002000] 4Mb otp offset: 00000000 detecting chip #0B in region #00... flash: 7F227E220A2201:2BEA0000000000 flash: AMD/Fujitsu std [D 0008x002000 003Ex010000 0008x002000] 4Mb otp offset: 00000000 detecting chip #0C in region #00... flash: 7F227E220A2201:2BEA0000000000 flash: AMD/Fujitsu std [D 0008x002000 003Ex010000 0008x002000] 4Mb otp offset: 00000000 detecting chip #0D in region #00... flash: 7F227E220A2201:2BEA0000000000 flash: AMD/Fujitsu std [D 0008x002000 003Ex010000 0008x002000] 4Mb otp offset: 00000000 detecting chip #0E in region #00... flash: 7F227E220A2201:2BEA0000000000 flash: AMD/Fujitsu std [D 0008x002000 003Ex010000 0008x002000] 4Mb otp offset: 00000000 detecting chip #0F in region #00... flash: 7F227E220A2201:2BEA0000000000 flash: AMD/Fujitsu std [D 0008x002000 003Ex010000 0008x002000] 4Mb otp offset: 00000000 number of flash chip/regions detected: 10/01 Initialize Done ====> Set baud ... 230400 Set baud Done ====> Initialize bootcode ... interesting cpu type found Initialize bootcode Done ====> Check firmware integrity ... device parameters detection in progress... detecting chip #00 in region #00... flash: 7F227E220A2201:2BEA0000000000 flash: AMD/Fujitsu std [D 0008x002000 003Ex010000 0008x002000] 4Mb otp offset: 00000000 detecting chip #01 in region #00... flash: 7F227E220A2201:2BEA0000000000 flash: AMD/Fujitsu std [D 0008x002000 003Ex010000 0008x002000] 4Mb otp offset: 00000000 it's time to stop: 2B0000EA18F09FE518F09FE518F09FE518F09FE518F09FE5 number of flash chip/regions detected: 01/01 total flash region size: 00400000 usb bootloader detect... .. usb bootloader detect (phase #2)... .. usb bootloader (chip) is absent searching rom info... search rom info finished rom info structure: [standard] type (04) TCL-ID is absent rom info detection finished rom info ver: 04 sw version: ATEL23_08A_BULGRIAN_PCB01_GSM_MT6223_S00.08GE0_H_07_11.BIN project-id: 08GE0_H_07_11, 00000000 code offset: 00000000 ffs offset/size [01]: 00380000/00080000 rom info structure: [standard] type (04) TCL-ID is absent detecting ffs/eeprom area in 1 chip(s)... standard ffs/eeprom offset detected: 00380000 standard ffs/eeprom offset confirmed: 00380000 detecting ffs/eeprom size... ffs/eeprom size: 00080000 ffs/eeprom chip: 00 ffs/eeprom area: 00000000:00380000-003FFFFF firmware area: 00000000-0037FFFF detecting startup code area #2... ................................................................................................................................................................................................................................................................ startup code area #2 is absent detecting ffs/eeprom structure pass 1... .......... ffs/eeprom: detect std location pass #1... .............. ffs/eeprom: detect ext location pass #1... ............ ffs/eeprom: detect standard offset pass #1... ffs/eeprom record offset detected ffs/eeprom: detect standard data... ffs/eeprom record size detected ffs/eeprom layout detection complete ffs/eeprom detected ok: element #1 sec info (detailed) detection... searching sec info#1... . search sec info#1 finished Check firmware integrity Done ====> Check firmware content ... Check firmware content Done ====> Backup required data ... flash: 7F227E220A2201:2BEA0000000000 Backup required data Done ====> Patch required data ... ............ lock area found Patch required data Done ====> Special operation ... Special operation Done ====> Write ... flash: 7F227E220A2201:2BEA0000000000 flash: 7F227E220A2201:2BEA0000000000 Write: lock-area-1 Write Done ====> Finalization ... Finalization Done Finished, time used: 1 min 36 sec Remove/Install battery now ! ==== [16/2/2012 г. 12:51:29] ==== COM5 [VCP0] selected module v4.16 Action: "sp-unlock" unlock method: smart fast Model: _Autodetect MT6205-6239 NOR Checking data, wait... Phone should be Switched OFF ! Press and HOLD Power button now ! 19200 autodetect Initializing [6223:8A08]... CPU: MT6223 high speed boot On chip: 0011:55E8:000C status: FF Connecting at 19200, wait... Release Power button now ! Phone detected, wait... Hardware: MT6223,E08 Date: 2000.00.00 Version: 1.0 Version: 08GE0_H_07_11 Version: ATEL23_08A_HW detecting structure #2... 1 2 3 5 7 8 9 11 13 done 80 byte(s) read imei: 35876002429204 connection Ok detecting structure #1... 0 1 2 3 4 7 8 9 12 13 14 15 17 20 21 22 23 24 27 28 29 32 33 34 35warning: wrong packet cs 37error: detection failed (26 tries), read flash and send to support error: can't read required data error: operation failed ! Finished, time used: 17 sec Remove/Install battery now ! |
02-17-2012, 15:36 | #3 (permalink) |
Member: 198847 Status: Offline Thanks Meter: 109 | Hello, In the list cannot see Cordless Phone FC8050: Wait... trying to select model: /FC8050 Device: _Autodetect MT6205-6239 NOR Initialization done |
The Following User Says Thank You to Petyo For This Useful Post: |
02-18-2012, 23:45 | #4 (permalink) |
Member: 1043909 Status: Offline Thanks Meter: 60,861 | Yes, I have double checked and want to say - it was my fault. Please, try to keep phone with you for 1-2 more days until we will release new exe. |
02-22-2012, 09:13 | #5 (permalink) |
Member: 198847 Status: Offline Thanks Meter: 109 | Hello I tried again to unlock Gordless Phone, but again without result. 1.Unlock metod-read code-ok (code 12345678), but the phone not asks to enter the code. The display appears Operator locked! I tried other methods to unlock-results for all methods is ok, but phone is locked: Operator locked! Code: ==== [22/2/2012 г. 09:21:00] ==== COM5 [VCP0] selected module v4.19 Action: read unlock codes unlock method: read codes Model: Cordles-Phone-FC8050 Checking data, wait... Phone should be Switched OFF ! Press and HOLD Power button now ! 19200 autodetect Initializing [6223:8A08]... CPU: MT6223 high speed boot On chip: 0011:5140:000C status: FF Connecting at 19200, wait... Release Power button now ! Phone detected, wait... Hardware: MT6223,E08 Date: 2000.00.00 Version: 1.0 Version: 08GE0_H_07_11 Version: ATEL23_08A_HW 80 byte(s) read imei: 35876002429246 connection Ok 186 byte(s) read 38 byte(s) read Phone lock: Off Phone code: 1122 174 byte(s) read reading data... 972 byte(s) read lock[1] code: + default lock[2] code: + default lock[3] code: + 1122 lock[4] code: - default lock[5] code: - default lock[6] code: + default lock[7] code: + default if code is not accepted by phone: - insert wrong sim card into phone - power-On phone - enter code: 12345678 - wait 10 seconds - power-Off phone via "Power" button (do not remove battery) - read unlock codes again Finished, time used: 32 sec Remove/Install battery now ! ==== [22/2/2012 г. 09:22:42] ==== COM5 [VCP0] selected module v4.19 Device: Cordles-Phone-FC8050 Checking data, wait... advanced flash detection enabled Action: "sp-unlock" unlock method: standard ffs/eeprom backup enabled, it may takes several minutes ! ====> Boot ... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing [6223:8A08]... CPU: MT6223 high speed boot On chip: 0011:5140:000C status: FF boot packet size: 0400 Release Power button now ! Boot Done ====> Initialize ... detecting chip #00 in region #00... flash: 7F227E220A2201:2BEA0000000000 flash: AMD/Fujitsu std [D 0008x002000 003Ex010000 0008x002000] 4Mb otp offset: 00000000 number of flash chip/regions detected: 01/01 Initialize Done ====> Set baud ... 460800 Set baud Done ====> Initialize bootcode ... interesting cpu type found Initialize bootcode Done ====> Check firmware integrity ... usb bootloader detect... .. usb bootloader detect (phase #2)... .. usb bootloader (chip) is absent searching rom info... search rom info finished rom info structure: [standard] type (04) TCL-ID is absent rom info detection finished rom info ver: 04 sw version: ATEL23_08A_BULGRIAN_PCB01_GSM_MT6223_S00.08GE0_H_07_11.BIN project-id: 08GE0_H_07_11, 00000000 code offset: 00000000 ffs offset/size [01]: 00380000/00080000 rom info structure: [standard] type (04) TCL-ID is absent ffs/eeprom address assigned: 00380000 sec info (detailed) detection... searching sec info#1... . search sec info#1 finished Check firmware integrity Done ====> Check firmware content ... Check firmware content Done ====> Backup required data ... reading: Cordles-Phone-FC8050_ATEL23_08A_BULGRIAN_PCB01_GSM_MT6223_S00.08GE0_H_07_11__ffs... file saved: D:\Program Files\InfinityBox\MModule\Backup\FC8050\Cordles-Phone-FC8050_ATEL23_08A_BULGRIAN_PCB01_GSM_MT6223_S00.08GE0_H_07_11__ffs_20120222-092336.B0E.bin flash: 7F227E220A2201:2BEA0000000000 Backup required data Done ====> Patch required data ... detection procedure, wait... detection procedure completed detection procedure, wait... detection procedure completed Patch required data Done ====> Special operation ... Special operation Done ====> Write ... flash: 7F227E220A2201:2BEA0000000000 Write: ffs Write Done ====> Finalization ... Finalization Done Finished, time used: 1 min 0 sec Remove/Install battery now ! ==== [22/2/2012 г. 09:25:24] ==== COM5 [VCP0] selected module v4.19 Device: Cordles-Phone-FC8050 Checking data, wait... advanced flash detection enabled Action: "sp-unlock" unlock method: standard fast ====> Boot ... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing [6223:8A08]... CPU: MT6223 high speed boot On chip: 0011:5140:000C status: FF boot packet size: 0400 Release Power button now ! Boot Done ====> Initialize ... detecting chip #00 in region #00... flash: 7F227E220A2201:2BEA0000000000 flash: AMD/Fujitsu std [D 0008x002000 003Ex010000 0008x002000] 4Mb otp offset: 00000000 number of flash chip/regions detected: 01/01 Initialize Done ====> Set baud ... 460800 Set baud Done ====> Initialize bootcode ... interesting cpu type found Initialize bootcode Done ====> Check firmware integrity ... usb bootloader detect... .. usb bootloader detect (phase #2)... .. usb bootloader (chip) is absent searching rom info... search rom info finished rom info structure: [standard] type (04) TCL-ID is absent rom info detection finished rom info ver: 04 sw version: ATEL23_08A_BULGRIAN_PCB01_GSM_MT6223_S00.08GE0_H_07_11.BIN project-id: 08GE0_H_07_11, 00000000 code offset: 00000000 ffs offset/size [01]: 00380000/00080000 rom info structure: [standard] type (04) TCL-ID is absent ffs/eeprom address assigned: 00380000 sec info (detailed) detection... searching sec info#1... . search sec info#1 finished Check firmware integrity Done ====> Check firmware content ... Check firmware content Done ====> Backup required data ... flash: 7F227E220A2201:2BEA0000000000 Backup required data Done ====> Patch required data ... ............ lock area found ............ lock area found Patch required data Done ====> Special operation ... Special operation Done ====> Write ... flash: 7F227E220A2201:2BEA0000000000 flash: 7F227E220A2201:2BEA0000000000 Write: lock-area-1 flash: 7F227E220A2201:2BEA0000000000 flash: 7F227E220A2201:2BEA0000000000 Write: lock-area-4 Write Done ====> Finalization ... Finalization Done Finished, time used: 38 sec Remove/Install battery now ! ==== [22/2/2012 г. 09:26:46] ==== COM5 [VCP0] selected module v4.19 Action: "sp-unlock" unlock method: smart fast Model: Cordles-Phone-FC8050 Checking data, wait... Phone should be Switched OFF ! Press and HOLD Power button now ! 19200 autodetect Initializing [6223:8A08]... CPU: MT6223 high speed boot On chip: 0011:5140:000C status: FF Connecting at 19200, wait... Release Power button now ! Phone detected, wait... Hardware: MT6223,E08 Date: 2000.00.00 Version: 1.0 Version: 08GE0_H_07_11 Version: ATEL23_08A_HW 80 byte(s) read imei: 35876002429246 connection Ok 186 byte(s) read reading data... reading data #2... building new data... writing data... 174 byte(s) read reading data... 972 byte(s) read building new data... writing data... verifying... verification Ok done Finished, time used: 24 sec Remove/Install battery now ! |
