08-02-2012, 15:22 | #1 (permalink) |
Freak Poster Join Date: Sep 2004 Location: BG, Sofia Age: 47
Member: 82937 Status: Offline Sonork: 100.1613800 Thanks Meter: 7 | Cordless Phone FC8050 - not unlocked module v4.36 Device: Cordles-Phone-FC8050 Checking data, wait... advanced flash detection enabled Action: "sp-unlock" unlock method: standard fast ====> Boot ... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing [6223:8A08]... CPU: MT6223 high speed boot On chip: 0011:7210:000C status: FF boot packet size: 0400 Release Power button now ! Boot Done ====> Initialize ... detecting chip #00 in region #00... flash: 7F227E220A2201:2BEA0000000000 flash: AMD/Fujitsu std [D 0008x002000 003Ex010000 0008x002000] 4Mb otp offset: 00000000 number of flash chip/regions detected: 01/01 Initialize Done ====> Set baud ... 921600 Set baud Done ====> Initialize bootcode ... interesting cpu type found Initialize bootcode Done ====> Check firmware integrity ... usb bootloader detect... .. usb bootloader detect (phase #2)... .. usb bootloader (chip) is absent searching rom info... search rom info finished rom info structure: [standard] type (04) TCL-ID is absent rom info detection finished rom info ver: 04 sw version: ATEL23_08A_BULGRIAN_PCB01_GSM_MT6223_S00.08GE0_H_0 7_11.BIN project-id: 08GE0_H_07_11, 00000000 code offset: 00000000 ffs offset/size [01]: 00380000/00080000 rom info structure: [standard] type (04) TCL-ID is absent ffs/eeprom address assigned: 00380000 sec info (detailed) detection... searching sec info#1... . search sec info#1 finished Check firmware integrity Done ====> Check firmware content ... Check firmware content Done ====> Backup required data ... flash: 7F227E220A2201:2BEA0000000000 Backup required data Done ====> Patch required data ... ............ lock area found ............ lock area found Patch required data Done ====> Special operation ... Special operation Done ====> Write ... flash: 7F227E220A2201:2BEA0000000000 flash: 7F227E220A2201:2BEA0000000000 Write: lock-area-1 flash: 7F227E220A2201:2BEA0000000000 flash: 7F227E220A2201:2BEA0000000000 Write: lock-area-4 Write Done ====> Finalization ... Finalization Done Finished, time used: 41 sec Remove/Install battery now ! I try all metods but phone is still locked |
08-02-2012, 15:53 | #2 (permalink) |
Member: 130995 Status: Offline Thanks Meter: 35,227 | Hello, Please, post here operation log for "read unlock codes" operation. Also, what text you see at phone LCD when you power-on phone with wrong sim card ? What code was asked by phone ? |
08-02-2012, 16:24 | #3 (permalink) |
Member: 82937 Status: Offline Sonork: 100.1613800 Thanks Meter: 7 | COM4 [VCP0] selected module v4.36 Device: Cordles-Phone-FC8050 Checking data, wait... Operation: SP-unlock unlock method: read codes can not find file: meta_dll.dll error: last error: 0001:General error Shutdown... done error: operation failed Finished, time used: 1 sec Remove/Install battery now ! Phone don't ask for code. On LCD the text is "Error!". By SIM with 284-01 (Mtel Bulgaria) phone is work. Thanks for your fast answer. |
11-07-2012, 19:18 | #6 (permalink) |
Member: 82937 Status: Offline Sonork: 100.1613800 Thanks Meter: 7 | COM10 [VCP0] selected module v4.39 Device: Cordles-Phone-FC8050 Checking data, wait... Operation: SP-unlock unlock method: read codes interface: META_DLL_v6.1108.00 Connect... Phone should be Switched OFF ! Press and HOLD Power button now ! Connecting... done Release Power button now ! BaseBand chip version: MT6223, E08 ECO version: DSP firmware version: 2000.00.00 DSP patch version: 1.0 S/W version: 08GE0_H_07_11 H/W board version: ATEL23_08A_HW Melody version Melody V0.0 Version: 08GE0_H_07_11 80 byte(s) read imei #1: 13579024681122007810 warning: imei #1 is incorrect (default factory value) ! Repair imei #1 for correct phone functionality ! 186 byte(s) read 38 byte(s) read Phone lock: Off Phone code: 123456 174 byte(s) read 972 byte(s) read lock[1] code: + default lock[2] code: + default lock[3] code: + 1122 lock[4] code: - default lock[5] code: - default lock[6] code: + default lock[7] code: + default if code is not accepted by phone: - insert wrong sim card into phone - power-On phone - enter code: 12345678 - wait 10 seconds - power-Off phone via "Power" button (do not remove battery) - read unlock codes again Shutdown... done Finished, time used: 23 sec Remove/Install battery now ! With new ver again no unlock on lcd message is "Operator locked" |
6110 power does not stay on | sc~micro | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 6 | 08-30-2014 08:14 |
