01-24-2021, 22:17 | #1 (permalink) |
Junior Member Join Date: Jun 2017 Location: Maputo,nampula
Member: 2730213 Status: Offline Thanks Meter: 2 | MT6785 Infinity-Box [ Chinese Miracle ] MediaTek Service Module [ MTK ] v2.17 Load IDBase v729152 Ok! Operation : Reset Settings/Format FS [ v2.17 ] Mode : SMART RESET 1. Make sure device is powered off. Power off, if need. Wait 20 seconds after 2. Insert USB cable in phone Waiting for device connection ... PTFN : MediaTek USB Port (COM115) MODE : BOOTROM PORT : 115 Waiting BOOT ack ... BROM : Skip ACK verify BROM : Init BROM BROM init passed! CHIP : MT6785 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0000 CODE : Krug TYPE : MODERN RAPHAEL BROM : MEID : 684F479B6CAF7F0272D6FDFE74A98E50 BROM : SecLevel : 0x000000E7 BROM : SecMode : SBC+SLA+SDA+EXT BROM : BROM|BL : 0x05|0xFE BROM : BOOTROM MODE : Xiaomi : Helio [G90][A22] | Manual : Disabled BROM : SOCID : 82E34F9FAD8CAAC196FB03FD2827828A5AEC50F5069D8C65E2 D896C56BA4864F BROM : SLA : Local Auth BROM : SLA : Auth Passed! BROM : SLA : 0x0000001F AGENT : Look for suitable BootChain in DA ... AGENT : MTK_AllInOne_DA_V2.bin AGENT : Found MT6785 AGENT : MTK_DOWNLOAD_AGENT BROM : Sending 1st DA ... BROM : DA sent BROM :Transfer control to DA ... DA : AGENT started! DA : SYNC DA : MODE : BROM DA : EXT_RAM NOT initialized! DA : EMI : Failed to get EMI info from selected source! Error : Fail to init protocol! >>> Internal EMI : Select other EMI number! External Preloader - make sure it correct for connected device! Reconnect Power/Cable! |
01-24-2021, 22:20 | #2 (permalink) |
Member: 2730213 Status: Offline Thanks Meter: 2 | Operation : HW Report [ v2.17 ] HWreport : Mode : UFS 1. Make sure device is powered off. Power off, if need. Wait 20 seconds after 2. Insert USB cable in phone Waiting for device connection ... PTFN : MediaTek USB Port (COM115) MODE : BOOTROM PORT : 115 Waiting BOOT ack ... BROM : Skip ACK verify BROM : Init BROM BROM init passed! CHIP : MT6785 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0000 CODE : Krug TYPE : MODERN RAPHAEL BROM : MEID : 684F479B6CAF7F0272D6FDFE74A98E50 BROM : SecLevel : 0x000000E7 BROM : SecMode : SBC+SLA+SDA+EXT BROM : BROM|BL : 0x05|0xFE BROM : BOOTROM MODE : Xiaomi : Helio [G90][A22] | Manual : Disabled BROM : SOCID : 82E34F9FAD8CAAC196FB03FD2827828A5AEC50F5069D8C65E2 D896C56BA4864F BROM : SLA : Local Auth BROM : SLA : Auth Passed! BROM : SLA : 0x0000001F AGENT : Look for suitable BootChain in DA ... AGENT : MTK_AllInOne_DA_V2.bin AGENT : Found MT6785 AGENT : MTK_DOWNLOAD_AGENT BROM : Sending 1st DA ... BROM : DA sent BROM :Transfer control to DA ... DA : AGENT started! DA : SYNC DA : MODE : BROM DA : EXT_RAM NOT initialized! DA : EMI : Failed to get EMI info from selected source! Boot done! Memory Info : CID : MT128GASAO4U21 EXT_CSD Info : [UFS] life cycle check, pre_eol_info=1, life_time_est_a=1, life_time_est_b=1 [UFS] vendor id : 0x12c [UFS] ufs id : MT128GASAO4U21 [UFS] ufs fwver: [UFS] dev_quirk = 0x0 [UFS] info: number of active LU: 3, check OK. [UFS] info: number of Boot LU: 2, check OK. [UFS] info: LU Configuration Check OK. Bootable UFS [UFS] info: Boot LU Configuration Check OK. Active Boot LU: LU0 [UFS] warn: Power on, reset, or bus device reset occupied [UFS] Sense Data: ASC=29, ASCQ=0 [UFS] warn: Power on, reset, or bus device reset occupied [UFS] Sense Data: ASC=29, ASCQ=0 [UFS] warn: Power on, reset, or bus device reset occupied [UFS] Sense Data: ASC=29, ASCQ=0 [UFS] warn: Power on, reset, or bus device reset occupied [UFS] Sense Data: ASC=29, ASCQ=0 [UFS] info: HS-G3-2 Overall status : MLC status : 0% - 10% used SLC status : 0% - 10% used EOL status : Normal ( Less than 80% reserved blocks used ) |
01-24-2021, 22:27 | #3 (permalink) | |
Member: 1043909 Status: Offline Thanks Meter: 60,861 | Quote:
good | |
