06-16-2021, 08:19 | #1 (permalink) |
Insane Poster Join Date: Feb 2017 Location: India
Member: 2683601 Status: Offline Thanks Meter: 46 | Itel L6502 Frp Failed Load IDBase v8331 Ok! Operation : Format FS / Reset Settings [ v2.12 ] Mode : Default [ Reset Settings + FRP ] BootMode : FLASH 1. Power off device, wait 10-15 seconds 2. Press and hold BooKey ( 1 : BOTH VOL , 2 : VOL+ , 3 : VOL- ) 3. Insert cable in device! Wait for device ... Device Connected! BootVersion : SPRD3 Boot : INF : Itel : L6502 Sending Init Boot ... Boot sent! Kick FDL ... BootVersion : Spreadtrum Boot Block version 1.1 Protocol setup ... Port speed : 921600 Sending Flash Boot ... Boot sent! Kick FLASH FDL ... FDL : 0x0008 FDL : EMMC_RO : False ; EMMC_PART : True ; EMMC_RPMB_SET : False FDL : RAW : 0x0002 FDL : FLH : 0x400000 FDL : SEC : RSA auth required! >>> ERROR : FLASH FDL AUTHENTIFICATION FAILED! >>> Error : Fail to boot FDL! >>> Check previous message for more info! Reconnect Power/Cable! |
06-16-2021, 09:42 | #2 (permalink) | |
Freak Poster Join Date: Sep 2017 Location: Tanzania
Member: 2758606 Status: Offline Sonork: pasua Thanks Meter: 108 | Quote:
06-16-2021, 11:56 | #3 (permalink) |
Member: 462970 Status: Offline Thanks Meter: 20,352 | Update with test support of itel devices with RSA auth can be found here : https://forum.gsmhosting.com/vbb/14409459-post40.html Need put in EXISITNG SP2 folder and fill login/password to use! |
10-18-2021, 22:09 | #4 (permalink) |
Major Poster Join Date: May 2008 Location: tunisia
Member: 775012 Status: Offline Thanks Meter: 6 | Card found : B5426370 , v0150 Infinity-Box Chinese Miracle II : SPD/USC Module [SP2] v2.14 Load IDBase v8331 Ok! Operation : Format FS / Reset Settings [ v2.14 ] Mode : Reset FRP BootMode : FLASH 1. Power off device, wait 10-15 seconds 2. Press and hold BooKey ( 1 : BOTH VOL , 2 : VOL+ , 3 : VOL- ) 3. Insert cable in device! Wait for device ... Device Connected! BootVersion : SPRD3 Boot : INF : Itel : L6502 Sending Init Boot ... Boot sent! Kick FDL ... BootVersion : Spreadtrum Boot Block version 1.1 Protocol setup ... Port speed : 921600 Sending Flash Boot ... Boot sent! Kick FLASH FDL ... FDL : 0x0008 FDL : EMMC_RO : False ; EMMC_PART : True ; EMMC_RPMB_SET : False FDL : RAW : 0x0002 FDL : FLH : 0x400000 FDL : SEC : RSA auth required! FDL : Process authentification ... FDL : SEC : RSA auth passed! FDL : Control transfered! Boot Done! Wipe Ok : FRP Reconnect Power/Cable! Done! Elapsed: 00:01:49 |
