Old 11-19-2010, 22:41   #1 (permalink)
virgix's Avatar
Member: 69608
Thanks Meter: 63
D-One DG628 Cannot flash by infinity
Connecting...
Booting...
Release Power button now !
bootcode current/expected: 3.2/3.2
CPU: 6235:8A04:8A01
status: FF
bbchip bl ver: FE
NOR flash chip: not installed
NAND flash id[0053]: 00AD:00A100000015 [HYNIX] H8BCS0PG0MBP
chip size: 128Mb
page/spare size: 0800/0040
pages per block: 0040
bits i/o: 08
address cycles: 04
internal RAM size: 00010000
external RAM: S_DA_RAM_ERROR
done
Set baudrate (921600)...
done
ram test...
testing...
ram test passed
===> detect existing firmware structure...
detect ffs...
ffs offset/size: 02620000/059E0000
firmware size: 38Mb
ffs size: 89Mb
detect sec ro...
detect custom parameters...
detect project-id...
project-id: X10_DG628TEK_1GFMGB16_02S0112
detect NAND info...
number of areas/bytes to read: 1:001A0000
reading (HW_STORAGE_NAND NUTL_READ_PAGE_ONLY)...
error: can not read memory: 0FAA:S_FT_READBACK_FAIL
can not read memory, errorcode: 0FAA
it may be problem with current operation and/or future software functionality
contact to support !
error: last error: 0FAA:S_FT_READBACK_FAIL
Disconnect...
done
Finished, time used: 39 sec
Remove/Install battery now !
phone read ok by other software....
Old 11-19-2010, 23:03   #2 (permalink)
virgix's Avatar
Member: 69608
Thanks Meter: 63
problem solved by chinese miracle V3.24
Connect...
Connecting...
Booting...
CPU: 6235:8A04:8A01
status: FF
bbchip bl ver: FE
chip size: 128Mb
bits i/o: 08
address cycles: 04
done
Set baudrate (460800)...
done
ram test...
testing...
ram test passed
detect ffs...
ffs offset/size: 02000000/02000000
firmware size: 32Mb
ffs size: 32Mb
detect sec ro...
project-id: X10_DG628TEK_FMGB16_02S0927
detect NAND info...
nfi area detection...
bootloader version: RATECH35_08B_BOOTLOADER_V005_MT6235B_X10_SK_FMJ_ML A_08S0721.bin
warning: id-page1 area is invalid
nfi area detection (0 cores) finished: failed
TCL-ID detection...
TCL-ID detection done
startup code area #1 detection...
startup code area #1 detection done
rom info ver: 07
sw version: RATECH35_08B_PCB01_GPRS_MT6235B_S01.X10_DG628TEK_F MGB16_02S0927.BIN
project-id: X10_DG628TEK_FMGB16_02S0927, 00000000
code offset: 00000000
ffs offset/size [01]: 02000000/02000000
rom info structure: [standard] type (07)
TCL-ID is absent
===> done
nfi area detection (3 cores) finished: Ok
startup code area #1 check...
done
number of cores: 3
loading files...
number of areas: 3
done
write...
write bootloader...
write core...
Format (HW_STORAGE_NAND)...
Disconnect...
done
Finished, time used: 9 min 57 sec
The Following User Says Thank You to virgix For This Useful Post:
How can I do a Welcome note for my 6110 a dosn't have any one ? Viper Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 8 06-27-2015 11:57
5110 flash new software , need help steve Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 4 01-03-2015 05:41
Copy from one 6110 to another Leif Nielsen Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 1 06-10-1999 22:36
Page generated in 0.29476 seconds with 10 queries
