[DA_ERROR] : DRAM Configure failedCodeDefine : DA_DEVICE_NOT_FOUND pl;z help can some one say wat is the problem by seeing log Operation : Flash Erase [ v1.58 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 19 ] Sync... Inital Boot Ok! BB_CPU_PID : 6580 BB_CPU_NME : [MediaTek] MT6580_S00 BB_CPU_EXT : 0xCA00 , 0x8A00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x00000000 BromVer : 0x0005 BLVersion : 0x00FE PreLoader : NOT Active [ Erased ] BootLdrSS : NORMAL with PRELOADER Processing DA stage DA Select done, will use MTK_AllInOne_DA_v5.1624.16.07 Sending and initialize DA ... Running DA ver.4.2 on BBID : 0x94 NAND Flash : NOT INSTALLED eMMC Flash : 90014A4838473165050755A552744325 Initialize Memory ... [DA_ERROR] : DRAM Configure failed! ErroCode : 0xC40B0000 EMICFG_RET_FAILED CodeDefine : DA_DEVICE_NOT_FOUND Boot Error! Operation Failed Elapsed: 00:00:35 Reconnect Power/Cable! |
