05-07-2016, 12:50 | #1 (permalink) |
No Life Poster Join Date: Jun 2010 Location: việt nam
Member: 1327392 Status: Offline Thanks Meter: 409 | [da_error] : Securityboot_boot_not_accepted need help mi redmi read FW [DA_ERROR] Operation : Check / Read Info [ v1.47 ]1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 32 ] Sync... Inital Boot Ok! BB_CPU_PID : 6795 BB_CPU_NME : [MediaTek] Helio[X10]|MT6795_S00 BB_CPU_EXT : 0xCA00 , 0x8A00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x01000000 BromVer : 0x00FF BLVersion : 0x0001 PreLoader : Active [ Boot with PL ] BootLdrSS : LOCKED with SPRELOADER Processing DA stage DA Select done, will use MTK_AllInOne_DA_v5.1612.01.01 Sending and initialize DA ... [DA_ERROR] : SECURITYBOOT_BOOT_NOT_ACCEPTED Boot Error! Operation Failed Elapsed: 00:00:24 Reconnect Power/Cable! |
The Following User Says Thank You to students For This Useful Post: |
08-12-2017, 11:20 | #9 (permalink) |
Insane Poster Join Date: Aug 2008 Location: philippines
Member: 847906 Status: Offline Sonork: 1654522 Thanks Meter: 5 | already this problem asus ZOODV Wait for phone... Phone found! [ 9 ] Sync... Inital Boot Ok! BB_CPU_PID : 6580 BB_CPU_NME : [MediaTek] MT6580_S00 BB_CPU_EXT : 0xCA00 , 0x8A00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x00000000 BromVer : 0x00FF BLVersion : 0x0001 PreLoader : Active [ Boot with PL ] BootLdrSS : NORMAL with PRELOADER Processing DA stage DA Select done, will use MTK_AllInOne_DA_v5.1624.16.07 Sending and initialize DA ... [DA_ERROR] : SECURITYBOOT_BOOT_NOT_ACCEPTED Boot Error! Operation Failed Elapsed: 00:00:08 Reconnect Power/Cable! |
09-12-2017, 08:57 | #10 (permalink) |
No Life Poster Join Date: Sep 2011 Location: NOKIA
Member: 1663119 Status: Offline Sonork: iffi3 Thanks Meter: 213 | Wait for phone... Phone found! [ 5 ] Sync... Inital Boot Ok! BB_CPU_PID : 6580 BB_CPU_NME : [MediaTek] MT6580_S00 BB_CPU_EXT : 0xCA00 , 0x8A00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x00000000 BromVer : 0x00FF BLVersion : 0x0001 PreLoader : Active [ Boot with PL ] BootLdrSS : NORMAL with PRELOADER Processing DA stage DA Select done, will use MTK_AllInOne_DA_v5.1624.16.07 Sending and initialize DA ... [DA_ERROR] : SECURITYBOOT_BOOT_NOT_ACCEPTED Boot Error! |
09-17-2017, 22:48 | #11 (permalink) |
Junior Member Join Date: Oct 2014 Location: auther planet
Member: 2281251 Status: Offline Thanks Meter: 1 | 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 16 ] Sync... Inital Boot Ok! BB_CPU_PID : 6583 BB_CPU_NME : [MediaTek] MT6583|6589_S00 BB_CPU_EXT : 0xCA01 , 0x8A00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x00000000 BromVer : 0x00FF BLVersion : 0x0001 PreLoader : Active [ Boot with PL ] BootLdrSS : NORMAL with PRELOADER Processing DA stage DA Select done, will use MTK_AllInOne_DA_v5.1624.16.07 Sending and initialize DA ... [DA_ERROR] : SECURITYBOOT_BOOT_NOT_ACCEPTED Boot Error! |
09-18-2017, 07:56 | #12 (permalink) |
No Life Poster Join Date: Jun 2012 Location: bhopal
Member: 1778370 Status: Offline Sonork: sujan_goa Thanks Meter: 66 | Wait for phone... Phone found! [ 9 ] Sync... Inital Boot Ok! BB_CPU_PID : 6737 BB_CPU_NME : [MediaTek] MT6737_S00 BB_CPU_EXT : 0xCA00 , 0x8A00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x00000000 BromVer : 0x00FF BLVersion : 0x0001 PreLoader : Active [ Boot with PL ] BootLdrSS : NORMAL with PRELOADER Processing DA stage DA Select done, will use MTK_AllInOne_DA_v5.1624.16.07 Sending and initialize DA ... [DA_ERROR] : SECURITYBOOT_BOOT_NOT_ACCEPTED Boot Error! Operation Failed Elapsed: 00:00:08 Reconnect Power/Cable! Report Post set frp lock infocus if9001 |
09-18-2017, 08:08 | #15 (permalink) |
No Life Poster Join Date: Jul 2011 Location: dunia antah berantah
Member: 1616754 Status: Offline Thanks Meter: 245 | Operation : Check / Read Info [ v1.58 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 8 ] Sync... Inital Boot Ok! BB_CPU_PID : 6797 BB_CPU_NME : [MediaTek] Helio[X20]|MT6797_S00 BB_CPU_EXT : 0xCA01 , 0x8A00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x01000000 BromVer : 0x0005 BLVersion : 0x00FE PreLoader : NOT Active [ Erased ] BootLdrSS : SIGNED with SPRELOADER Processing DA stage DA Select done, will use MTK_AllInOne_DA_v5.1624.16.07 Sending and initialize DA ... DAgent configured successfully Connection agent : BROM DRAM configured from ScatFW! Link with DAgent established eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0x15 , OEM : 0100 [eMMC] : FLASH_INF : [SAMSUNG] , R4BNJ [eMMC] : FLASH_CID : 150100424A4E4234520745DD4FB4B303 [eMMC] : FLASH_BRT : 0x00400000 , 0x00400000 , 0x00400000 [eMMC] : FLASH_LEN : 0x0000000747C00000 [eMMC] : FLASH_UCP : 29820 MiB [eMMC 32 GiB] DEV RID : 0x9F804864CFA650964FF07A004CC1FC60 INT RAM : 0x00000000 EXT RAM : 0xC0000000 [3 GiB] [NAND] : FLASH : NOT INSTALLED [UFSM] : FLASH : NOT INSTALLED [HSUSB] : MODE : FULL-SPEED Boot Ok! [AP] : Initial info read Ok! Brand : Xiaomi ProdName : nikel ProdModel : Redmi Note 4 Device : nikel AndroidVer: 6.0 MTKxCPU : MT6797 MTKxPRJ : alps-mp-m0.mp9-V1.64_lcsh6797.6c.lw.m_P68 EXTRA : LCD : Not info available LCD Res : 1920x1080 TOUCH [0] : GT1XX CAM [0] : imx258_mipi_raw CAM [1] : imx258_mipi_raw_qteck CAM [2] : s5k5e8yx_main_mipi_raw_qteck CAM [3] : s5k5e8yx_main_mipi_raw CAM [4] : s5k5e8yx_sub_mipi_raw CAM [5] : s5k5e8yx_sub_mipi_raw_qteck MODEM : lcsh6797_6c_lw_m_lwctg lcsh6797_6c_lw_m_c2k LOCALE : en_US zh_CN zh_TW es_ES pt_BR ru_RU fr_FR de_DE tr_TR vi_VN ms_MY in_ID th_TH it_IT ar_EG hi_IN bn_IN ur_PK fa_IR pt_PT nl_NL el_GR hu_HU tl_PH ro_RO cs_CZ ko_KR km_KH iw_IL my_MM pl_PL es_US bg_BG hr_HR lv_LV lt_LT sk_SK uk_UA de_AT da_DK fi_FI nb_NO sv_SE en_GB hy_AM zh_HK et_EE ja_JP kk_KZ sr_RS sl_SI ca_ES Done! Elapsed: 00:00:17 Reconnect Power/Cable! |
The Following User Says Thank You to wutangclan33 For This Useful Post: |
