06-16-2016, 20:03 | #1 (permalink) |
No Life Poster Join Date: Dec 2006 Location: BEST COUNTRY
Member: 421947 Status: Online Sonork: 100:1658491 Thanks Meter: 239 | Mt6572 imei Operation : Repair Security [ v1.49 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 44 ] Sync... Inital Boot Ok! BB_CPU_PID : 6572 BB_CPU_NME : [MediaTek] MT6572_S00 BB_CPU_EXT : 0xCA01 , 0x8B00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x00000000 BromVer : 0x00FF BLVersion : 0x0001 PreLoader : Active [ Boot with PL ] BootLdrSS : NORMAL with SPRELOADER Processing DA stage DA Select done, will use MTK_AllInOne_DA_v5.1620.10.01 Sending and initialize DA ... Running DA ver.4.2 on BBID : 0x88 NAND Flash : NOT INSTALLED eMMC Flash : 110100303034474530019D6509F252A7 Initialize Memory ... DRAM already initialized by Preloader DAgent sent , init HW now eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0x11 , OEM : 0100 [eMMC] : FLASH_INF : [TOSHIBA] , 0EG40 [eMMC] : FLASH_CID : 110100303034474530019D6509F252A7 [eMMC] : FLASH_BRT : 0x00200000 , 0x00200000 , 0x00080000 [eMMC] : FLASH_LEN : 0x00000000EC000000 [eMMC] : FLASH_UCP : 3776 MiB [eMMC 4 GiB] DEV RID : 0x5131DCAD63176833A573CA75032D9A3F INT RAM : 0x00020000 EXT RAM : 0x20000000 [512 MiB] BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! IMEI [00] : 354501483852458 IMEI [01] : 354501483852458 Set IMEI [00] : 354501483853213 Prepare finished. Security check required! Wait for phone... Phone found! [ 44 ] Sync... Repair done! Done! Elapsed: 00:00:49 Reconnect Power/Cable! |
06-17-2016, 01:15 | #2 (permalink) |
No Life Poster Join Date: Apr 2009 Location: Inside Infinity
Member: 1010626 Status: Offline Sonork: using fb Thanks Meter: 735 | Hello, As some time bb is not ok but it shows so first repair bb and then repair security... if still not solve write NV ram and repair... if stilll not then flash and see hope ur prblm will solve Sent from my S_plus using Tapatalk |
06-17-2016, 17:30 | #3 (permalink) |
Member: 421947 Status: Online Sonork: 100:1658491 Thanks Meter: 239 | Hello and another phone that log show complate but no results May be I am doing imei repaiar note true Operation : Repair Security [ v1.50 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 44 ] Sync... Inital Boot Ok! BB_CPU_PID : 6575 BB_CPU_NME : [MediaTek] MT6575|MT6577_S00 BB_CPU_EXT : 0xCB00 , 0x8A00 , 0xE201 Processing BROM stage i2c Init : 00000000 SpeedSet : 0000 VChrgSet : 0x28 , BatStat : 0x02 WD Disable stat : 0x0000 Settings for BROM configured! SecCfgVal : 0x00000000 BromVer : 0x00FF BLVersion : 0x0001 PreLoader : Active [ Boot with PL ] BootLdrSS : NORMAL with SPRELOADER Processing DA stage DA Select done, will use MTK_AllInOne_DA_v5.1620.10.01 Sending and initialize DA ... Running DA ver.3.2 on BBID : 0x84 Initialize Memory ... DRAM already initialized by Preloader DAgent sent , init HW now eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0x90 , OEM : 014A [eMMC] : FLASH_INF : [HYNIX] , HYNIX [eMMC] : FLASH_CID : 90014A2058494E594812A1A74F038F1F [eMMC] : FLASH_BRT : 0x00200000 , 0x00200000 , 0x00200000 [eMMC] : FLASH_LEN : 0x00000000E7000000 [eMMC] : FLASH_UCP : 3696 MiB [eMMC 4 GiB] DEV RID : 0xF98D36945AFDD49BB86B86F4CB2323F1 INT RAM : 0x00020000 EXT RAM : 0x20000000 [512 MiB] BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! Set IMEI [00] : 353163058073296 Prepare finished. Security check required! Wait for phone... Phone found! [ 44 ] Sync... Repair done! |
06-17-2016, 19:07 | #7 (permalink) | |
Member: 421947 Status: Online Sonork: 100:1658491 Thanks Meter: 239 | Quote:
second phone imei have repaiar alredy if You can help please solve 1st phone imei | |
06-17-2016, 19:10 | #8 (permalink) |
Member: 462970 Status: Offline Thanks Meter: 20,352 | If baseband OK - do Format FS. Run phone. Power it off. Repair security. If not work - read modem config ( BPLGUI in extra tab ) and use with mauimeta, try repair with it. |
