06-22-2011, 16:43 | #1 (permalink) |
No Life Poster Join Date: Aug 2006 Location: Pakistan Age: 33
Member: 323959 Status: Offline Sonork: 100.1613721 Thanks Meter: 79 | dead china cpu change module v3.31 Device: Autodetect 6205-6239 NOR Checking data, wait... advanced flash detection enabled Action: repair security area ====> Boot ... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing [6225:8A03:8A00]... CPU: MT6225 high speed boot On chip: 0001:FF0F:FFFF status: 01 boot packet size: 0400 Release Power button now ! Boot Done ====> Initialize ... detecting chip #00 in region #00... flash: EC240200000000:18E59F00000000 flash: Samsung K5L2833ATA T 16Mb otp offset: 00FF0000 detecting chip #01 in region #00... flash: EC240200000000:18E59F00000000 flash: Samsung K5L2833ATA T 16Mb otp offset: 00FF0000 detecting chip #02 in region #00... flash: EC240200000000:18E59F00000000 flash: Samsung K5L2833ATA T 16Mb otp offset: 00FF0000 detecting chip #03 in region #00... flash: EC240200000000:18E59F00000000 flash: Samsung K5L2833ATA T 16Mb otp offset: 00FF0000 number of flash chip/regions detected: 04/01 Initialize Done ====> Set baud ... 921600 Set baud Done ====> Initialize bootcode ... Initialize bootcode Done ====> Check firmware integrity ... device parameters detection in progress... detecting chip #00 in region #00... flash: EC240200000000:18E59F00000000 flash: Samsung K5L2833ATA T 16Mb otp offset: 00FF0000 detecting chip #01 in region #00... flash: EC240200000000:18E59F00000000 flash: Samsung K5L2833ATA T 16Mb otp offset: 00FF0000 it's time to stop: 18F09FE518F09FE518F09FE518F09FE518F09FE518F09FE5 number of flash chip/regions detected: 01/01 total flash region size: 01000000 usb bootloader detect... .. usb bootloader detect (phase #2)... .. usb bootloader (chip) is absent searching rom info... search rom info finished rom info structure: [protected] type (05), 1 record(s) TCL-ID is absent startup code area #1 record #1 is damaged, recalculation required rom info detection finished device-id: 45B2968B rom info ver: 05 sw version: TELSDA25_08A_GEMINI_PCB01_GPRS_MT6225_S00.MAUI_08A _W08_40_MP_V3_F1.BIN project-id: MAUI.08A.W08.40.MP.V3.F1, 5CC6823C code offset: 00000000 ffs offset/size [01]: 00E00000/00200000 rom info structure: [protected] type (05), 1 record(s) TCL-ID is absent detecting startup code area #2... .................................................. .................................................. .................................................. .................................................. .................................................. ...... startup code area #2 is absent startup code area #1 check... rpl file not found: C:\InfinityBox\ChineseMiracle\id.45B2968B.[TELSDA25_08A_GEMINI_PCB01_GPRS_MT6225_S00.MAUI_08A _W08_40_MP_V3_F1.BIN_3C82C65C].rpl rpl file not found: C:\InfinityBox\ChineseMiracle\id.45B2968B._TELSDA2 5_08A_GEMINI_PCB01_GPRS_MT6225_S00.MAUI_08A_W08_40 _MP_V3_F1.BIN_3C82C65C_.rpl rpl file not found: C:\InfinityBox\ChineseMiracle\backup_security\id.4 5B2968B.[TELSDA25_08A_GEMINI_PCB01_GPRS_MT6225_S00.MAUI_08A _W08_40_MP_V3_F1.BIN_3C82C65C].rpl rpl file not found: C:\InfinityBox\ChineseMiracle\backup_security\id.4 5B2968B._TELSDA25_08A_GEMINI_PCB01_GPRS_MT6225_S00 .MAUI_08A_W08_40_MP_V3_F1.BIN_3C82C65C_.rpl ==================== warning: unknown firmware: TELSDA25_08A_GEMINI_PCB01_GPRS_MT6225_S00.MAUI_08A _W08_40_MP_V3_F1.BIN_3C82C65C Unknown firmware found (v.3.31, database date: 29.05.2011), user action required: 1. download latest software from support area and try again 2. if no still luck follow the next procedure: - find good working phone with the same firmware: TELSDA25_08A_GEMINI_PCB01_GPRS_MT6225_S00.MAUI_08A _W08_40_MP_V3_F1.BIN - make "Read full flash" operation - send flash backup files to support: [email protected] or upload files to RapidShare AG, Cham, Switzerland or 4shared.com - free file sharing and storage - include in your e-mail full text from phone back label (phone name etc.) - be little bit patient and wait update ==================== error: startup code area #1 can't be fixed sec info (fast) detection... searching sec info#1... . search sec info#1 finished error: incorrect ffs address range Finished, time used: 1 min 20 sec Remove/Install battery now ! |
06-22-2011, 16:47 | #2 (permalink) |
Member: 323959 Status: Offline Sonork: 100.1613721 Thanks Meter: 79 | try to ok set back up here log COM5 [Serial3] selected module v3.31 Device: Autodetect 6205-6239 NOR Checking data, wait... advanced flash detection enabled Action: write flash "smart write" active write: Firmware TELSDA25_08A_GEMINI_PCB01_GPRS_MT6225_S00.MAUI_08A _W08_40_MP_V3_F1__firmware_part_1_of_1_20110622-020157.B0M.bin skip: Customization/Language Pack skip: Customization skip: Eeprom/ffs ====> Boot ... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing [6225:8A03:8A00]... CPU: MT6225 high speed boot On chip: 0001:FF0F:FFFF status: 01 boot packet size: 0400 Release Power button now ! Boot Done ====> Initialize ... detecting chip #00 in region #00... flash: EC240200000000:18E59F00000000 flash: Samsung K5L2833ATA T 16Mb otp offset: 00FF0000 detecting chip #01 in region #00... flash: EC240200000000:18E59F00000000 flash: Samsung K5L2833ATA T 16Mb otp offset: 00FF0000 detecting chip #02 in region #00... flash: EC240200000000:18E59F00000000 flash: Samsung K5L2833ATA T 16Mb otp offset: 00FF0000 detecting chip #03 in region #00... flash: EC240200000000:18E59F00000000 flash: Samsung K5L2833ATA T 16Mb otp offset: 00FF0000 number of flash chip/regions detected: 04/01 Initialize Done ====> Set baud ... 921600 Set baud Done ====> Initialize bootcode ... Initialize bootcode Done ====> Check firmware integrity ... usb bootloader detect... .. usb bootloader detect (phase #2)... .. usb bootloader (chip) is absent searching rom info... search rom info finished rom info structure: [protected] type (05), 1 record(s) TCL-ID is absent startup code area #1 is Ok startup code area #1 backup saved: C:\InfinityBox\ChineseMiracle\backup_security\id.4 5B2968B.[TELSDA25_08A_GEMINI_PCB01_GPRS_MT6225_S00.MAUI_08A _W08_40_MP_V3_F1.BIN_C3F4E3FD].rpl rom info detection finished device-id: 45B2968B rom info ver: 05 sw version: TELSDA25_08A_GEMINI_PCB01_GPRS_MT6225_S00.MAUI_08A _W08_40_MP_V3_F1.BIN project-id: MAUI.08A.W08.40.MP.V3.F1, FDE3F4C3 code offset: 00000000 ffs offset/size [01]: 00E00000/00200000 rom info structure: [protected] type (05), 1 record(s) TCL-ID is absent sec info (detailed) detection... searching sec info#1... . search sec info#1 finished Check firmware integrity Done ====> Check firmware content ... Check firmware content Done ====> Backup required data ... Backup required data Done ====> Patch required data ... Patch required data Done ====> Special operation ... Special operation Done ====> Write ... sec info (fast) detection... searching sec info#1... . search sec info#1 finished usb bootloader (file) is absent startup code area #1 check... rpl file not found: C:\InfinityBox\ChineseMiracle\id.45B2968B.[TELSDA25_08A_GEMINI_PCB01_GPRS_MT6225_S00.MAUI_08A _W08_40_MP_V3_F1.BIN_3C82C65C].rpl rpl file not found: C:\InfinityBox\ChineseMiracle\id.45B2968B._TELSDA2 5_08A_GEMINI_PCB01_GPRS_MT6225_S00.MAUI_08A_W08_40 _MP_V3_F1.BIN_3C82C65C_.rpl rpl file not found: C:\InfinityBox\ChineseMiracle\backup_security\id.4 5B2968B.[TELSDA25_08A_GEMINI_PCB01_GPRS_MT6225_S00.MAUI_08A _W08_40_MP_V3_F1.BIN_3C82C65C].rpl rpl file not found: C:\InfinityBox\ChineseMiracle\backup_security\id.4 5B2968B._TELSDA25_08A_GEMINI_PCB01_GPRS_MT6225_S00 .MAUI_08A_W08_40_MP_V3_F1.BIN_3C82C65C_.rpl ==================== warning: unknown firmware: TELSDA25_08A_GEMINI_PCB01_GPRS_MT6225_S00.MAUI_08A _W08_40_MP_V3_F1.BIN_3C82C65C Unknown firmware found (v.3.31, database date: 29.05.2011), user action required: 1. download latest software from support area and try again 2. if no still luck follow the next procedure: - find good working phone with the same firmware: TELSDA25_08A_GEMINI_PCB01_GPRS_MT6225_S00.MAUI_08A _W08_40_MP_V3_F1.BIN - make "Read full flash" operation - send flash backup files to support: [email protected] or upload files to RapidShare AG, Cham, Switzerland or 4shared.com - free file sharing and storage - include in your e-mail full text from phone back label (phone name etc.) - be little bit patient and wait update ==================== error: startup code area #1 can't be fixed detecting startup code area #2... startup code area #2 is absent You can flash phone now but can not finalize it, in most cases phone CAN NOT power-on. Do you want to continue anyway ? file saved: C:\InfinityBox\ChineseMiracle\backup_security\TELS DA25_08A_GEMINI_PCB01_GPRS_MT6225_S00.MAUI_08A_W08 _40_MP_V3_F1__system_log_45B2968B_C3F4E3FD_2011062 2-020303.B0X.bin Area: Firmware flash: EC240200000000:18E59F00000000 Write: Firmware |
Working IMEI changed phone? | Barjo | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 2 | 03-01-2015 11:49 |
what prog changes imei on 6110 and how do i do it? | Ravetrancer | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 3 | 07-31-2012 20:09 |
Can anybody help me with solution to change 51/61/3210 IMEI? | soff | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 1 | 02-08-2011 15:28 |
Change Bin-file in Nokia..possible?? | BiG | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 2 | 11-20-1999 16:56 |
ESN Change | OGOMEZ | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 0 | 09-21-1999 23:56 |
