dear team please add panasonic eluga A dear team please add panasonic eluga ahttp://i.imgur.com/76dAzTO.png |
now follow the software advice and send the logs including device info to rd[at]infinity-box.com |
here is log handset info----- device name- panasonic eluga A company- panasonic Operation : Read Flash [ v1.10 ] 1. Power Off Phone , Remove battery , Insert back 2. PRESS and HOLD BOTH VOLUME KEYS! 3. Insert USB cable. In some cases require use EDL cable or TP to force EDL mode! Wait for phone... Device Found! Initialize ... Handshake passed! BB_IDC_CPU : SnapDragon 2x/4x|00 [MSM8x12] ID_BLOCK_S : 07E5557C ID_BLOCK_I : 008140E1 ID_BLOCK_L : 17C5C7670F58A9174C1498A5719E4FCA ID_BLOCK_L : 067811E55298E077D40F1858B74448DF Use CM2 Internal Loader Error : Prepare target failed! Unsupported SecureType! Send log and report.log to support! Include device info also! Reconnect Power/Cable! |
is there any solution to read the firmware of eluga a , i have one working set and i want to read the software .. Infinity-Box Chinese Miracle Qualcomm Module [QLM] v 1.14 Operation : Identify [ v1.14 ] 1. Power Off Phone , Remove battery , Insert back 2. PRESS and HOLD BOTH VOLUME KEYS! 3. Insert USB cable. In some cases require use EDL cable or TP to force EDL mode! Wait for phone... Device Found! Initialize ... Handshake passed! BB_IDC_CPU : SnapDragon 2x/4x|00 [MSM8x12] ID_BLOCK_S : 049EE152 ID_BLOCK_I : 008140E1 ID_BLOCK_L : 49AF9D396506DF699A3EF2DB07C8619C ID_BLOCK_L : CFA7DE2C8D512BBE0DC8C1937C8DB106 Use CM2 Internal Loader Error : Prepare target failed! Unsupported SecureType! Send log and report.log to support! Include device info also! Reconnect Power/Cable! |
Very old and secure type, unsupported for now. Have no idea will it be at all or not. |
I Think I Have Loader For This If U Can Add In Next Update I Can Send U...:);) |
Even if mprg - can add as well, but need check it first :) |
i have 3 sets same problem , only 9008 port, if any loader can help , i can test and reply ... |
will i be able to recover my dead sets ? |
Infinity Use Its Own Loaders....For Select Loader From Firmware U Need Rawprogram.xml But Eluga A Having Different File Format N Flash In Fastboot Mode So U Can't Do With CM2 ATM. I Have EDL Flashing File Too But It Also Having Diff Format Not Like Other Phones...It Having 3 XML ... 1st Contain Loader 2nd Contain "Content" 3rd Having Patch If U Select This With CM2 U Get Invalid File Format Or File Damage Error. Soon It Will Be Supported I Will Send Loaders To Team For Add This ASAP. :-) |
Hello, We are working and trying to add this model, hopefully will be added. Br. Infinity Box Team. |
can anyone give the qfil file of this set ? @hitech care can u please give me that loader ? |
is there any progress to add the loaders of this device with cm2 ? Quote:
