08-07-2021, 10:13 | #1 (permalink) |
No Life Poster Join Date: May 2011 Location: KPK Mardan Age: 36
Member: 1582572 Status: Offline Sonork: 100.1609641 Thanks Meter: 573 | misconfiguration Connect Infinity Box/Dongle to PC and DISCONNECT all other Boxes/Dongles === DongleManager [Infinity] v1.88 [07/08/2021 1:56:00 PM] === Searching... Card-Reader: Alcor Micro USB Smart Card Reader 0 HWID: 0000CCDA21344082 Box/Dongle found: Infinity-Box/Dongle [CM2] Serial No (S/N): 3B2ACCDA Firmware version: 0148.02 Box/Dongle misconfiguration Diagnostic code: 66 "UK Edition" status: Off Last launched Application: 0030 v.0148 => Activations: - 00: Infinity-Box/Dongle [CM2] v0148 => Options: - Infinity-Box/Dongle [CM2] Smart-Card update process may takes up to 4-5 minutes Software may seem hanging but DO NOT close or terminate application, just let the process to be finished - Connect Infinity Box/Dongle to PC and DISCONNECT all other Boxes/Dongles - Disable Antivirus and Firewall - DO NOT interrupt process even if you think that software freez! === DongleManager [Infinity] v1.88 [07/08/2021 1:56:10 PM] === Box/Dongle type selected: Infinity-Box/Dongle [CM2] Card-Reader: Alcor Micro USB Smart Card Reader 0 HWID: 0000CCDA21344082 Box/Dongle found: Infinity-Box/Dongle [CM2] Reading... Serial No (S/N): 3B2ACCDA Firmware version: 0148.02 === Started: 07/08/2021 1:56:11 PM === Connecting to server... Connection successfully established Checking DongleManager version... DongleManager is up-to-date Checking Dongle Identification... Authenticating on server... Authentication stage error: Server answer: [0031] Dongle identification data damaged. Write to https://www.infinity-box.com/support/?r=2 Do you want to report an issue to Support? Yes Box/Dongle type selected: Infinity-Box/Dongle [CM2] Box/Dongle misconfiguration Diagnostic code: 66 Username: 003B2ACCDA ==> Scan C:\Users\Raees\Desktop\DongleManager for report.log ==> Scan c:\InfinityBox for report.log ==> Scan c:\Program Files for report.log ==> Scan c:\Program Files (x86) for report.log Found files: 0 ==> Scan C:\Users\Raees\Desktop\DongleManager for *.ibin.log ==> Scan c:\InfinityBox for *.ibin.log ==> Scan c:\Program Files for *.ibin.log ==> Scan c:\Program Files (x86) for *.ibin.log Found files: 0 ==> Scan C:\Users\Raees\Desktop\DongleManager for fault.bin ==> Scan c:\InfinityBox for fault.bin ==> Scan c:\Program Files for fault.bin ==> Scan c:\Program Files (x86) for fault.bin Found files: 1 Upload: c:\InfinityBox\BEST2\fault.bin Smart-Card update process may takes up to 4-5 minutes Software may seem hanging but DO NOT close or terminate application, just let the process to be finished - Connect Infinity Box/Dongle to PC and DISCONNECT all other Boxes/Dongles - Disable Antivirus and Firewall - DO NOT interrupt process even if you think that software freez! Delete: c:\InfinityBox\BEST2\fault.bin You can contact to support with this reference: Ticket-ID:1628326606.790~003B2ACCDA~fault.bin; Answer is here https://forum.infinity-box.com//viewtopic.php?p=3135 |
