02-18-2009, 19:03 | #1 (permalink) |
Freak Poster Join Date: Mar 2006
Member: 241452 Status: Offline Thanks Meter: 36 | Dongle big problem |
02-18-2009, 19:09 | #2 (permalink) | |
Member: 130995 Status: Offline Thanks Meter: 35,229 | Quote:
What was happened that box stop to work ? | |
02-18-2009, 20:31 | #4 (permalink) | |
You need to buy and replace FT232 chip inside box. Make "search" in this forum regarding "FT232" and you will see detailed information. | |
02-28-2009, 09:56 | #6 (permalink) |
Freak Poster Join Date: Jun 2006
Member: 295357 Status: Offline Thanks Meter: 15 | plz solve problem this ----------Process started: 1:55:49 PM---------- Locating server... Server address found#1 Connecting to server#1... Server connection successfully established S/N: ********, Firmware: 0112.02 Authenticating on server... Authentication stage error: Server reported error:[0007] No more upgrade logs: Dongle is up-to-date and has latest firmware. Don't try more ! If software can not start (or SmartCard data is damaged) contact to [email protected] |
02-28-2009, 10:01 | #7 (permalink) | |
Product Supporter Join Date: Mar 2005 Age: 44
Member: 128745 Status: Offline Thanks Meter: 16,936 | Quote:
you will get answer with repair instructions | |
02-28-2009, 10:20 | #8 (permalink) | |
No Life Poster Join Date: Jan 2006 Location: Chandigarh,India Age: 40
Member: 220603 Status: Offline Thanks Meter: 1,164 | Quote:
The Following User Says Thank You to deepakgarg For This Useful Post: |
02-28-2009, 16:46 | #9 (permalink) |
Member: 295357 Status: Offline Thanks Meter: 15 | my problem is that pinfinder set not detect show this error software version: 1.17 cable type: 1x18 (L18B) platform: MT: MT6205, MT6217-MT6228, MT6230 searching adapter at COM4... adapter found, version: 2000 pins: 18, plain power cycles: 1 activation cycles: 7 power-off delay: 20 start Rx/Tx: 1/1 Loading configuration... Initializing... Press and HOLD phone Power button now ! detecting pins... failed to detect pins time required: 135 sec Power Off ! Set parameter to value 20 (or more) and repeat operation (parameter "Finder activation tries") |
02-28-2009, 16:57 | #10 (permalink) | |
02-28-2009, 18:58 | #11 (permalink) | |
What is your phone CPU chip name ? | |
big problem with my mx key | sshreesai | MXKEY Nokia Flasher and Unlocker (by Alim Hape) | 4 | 03-31-2010 10:07 |
Jaf big problem | haytham_84 | J.A.F. By Jafsupport.com | 0 | 03-29-2010 20:53 |
6085 big problem | kami1987 | MXKEY Nokia Flasher and Unlocker (by Alim Hape) | 1 | 03-29-2010 13:42 |
dongle big big big problem?????? | sabersabir | Easy-Unlocker | 8 | 07-29-2009 22:44 |
