09-09-2016, 10:52 | #1 (permalink) |
Freak Poster Join Date: Jan 2016 Location: Paranaque
Member: 2519102 Status: Offline Sonork: [email protected] Thanks Meter: 93 | help cm2spd 1.21 read pac my83 dtv chip sc7731c sopported chip or not sopported give me any idea read firmware Operation : Read FullFlash [ v1.21 ] 1. Remove battery. Insert battery back 2. Press and hold 'VolumeUp' and 'VolumeDown' keys 3. Insert cable ==== Wait for phone... Phone found! [ 13 ] Port Opened Sync... InitBoot Done [ 0x81 ] , Ver : SPRD3 Sync... Sending FDL [Info] : If SW freeze here more, than 15 seconds - remove cable Boot failed! Boot failed! Reconnect Power/Cable! Operation : HW Info OP [ v1.21 ] 1. Remove battery. Insert battery back 2. Press and hold 'VolumeUp' and 'VolumeDown' keys 3. Insert cable ==== Wait for phone... Phone found! [ 13 ] Open Port Failed! Reconnect Power/Cable! Operation : HW Info OP [ v1.21 ] 1. Remove battery. Insert battery back 2. Press and hold 'VolumeUp' and 'VolumeDown' keys 3. Insert cable ==== Wait for phone... Phone found! [ 13 ] Port Opened Sync... InitBoot Done [ 0x81 ] , Ver : SPRD3 Sync... Sending FDL [Info] : If SW freeze here more, than 15 seconds - remove cable Boot failed! Boot failed! Reconnect Power/Cable! |
The Following 3 Users Say Thank You to abetskiy boy For This Useful Post: |
09-09-2016, 11:01 | #3 (permalink) |
Freak Poster Join Date: Jul 2004 Location: Ukraine
Member: 74053 Status: Offline Thanks Meter: 75 | select three modes (Generic/Android 5x/Crev/Android 6x) in turn and check with each, the latest version of the program has significantly expanded support for memory chips, most likely it will be a mode Generic |
09-10-2016, 05:03 | #4 (permalink) |
Member: 2519102 Status: Offline Sonork: [email protected] Thanks Meter: 93 | pls check again my83 dtv Operation : Read FullFlash [ v1.21 ] 1. Remove battery. Insert battery back 2. Press and hold 'VolumeUp' and 'VolumeDown' keys 3. Insert cable ==== Wait for phone... Phone found! [ 50 ] Port Opened Sync... InitBoot Done [ 0x81 ] , Ver : SPRD3 Sync... Sending FDL [Info] : If SW freeze here more, than 15 seconds - remove cable FDL Ready! Boot Ver : SC7731 Crev eMMC Loader v2.0 Sending FLASH FDL FLASH FDL Ready! Boot Ok! FlashMode Set : Ok! Detected eMMC Flash , Structure detect Ok! [FW_READER] : Step #1 Passed! [FW_READER] : Step #2 Passed! [FW_READER] : Step #3 Failed! Error_Info : DVL Failed , If it Android 5.x - Root Required Reconnect Power/Cable! |
09-10-2016, 06:03 | #5 (permalink) | |
No Life Poster Join Date: May 2008
Member: 770503 Status: Offline Thanks Meter: 1,215 | Quote:
Code: Root Phone if still show same log reboot PC, reboot phone and repeat reading FW with CM2SPD. | |
09-10-2016, 06:52 | #6 (permalink) |
Member: 2519102 Status: Offline Sonork: [email protected] Thanks Meter: 93 | |
The Following User Says Thank You to abetskiy boy For This Useful Post: |
09-10-2016, 07:32 | #8 (permalink) | |
The Following User Says Thank You to mbiborna For This Useful Post: |
09-10-2016, 07:50 | #9 (permalink) |
Member: 2519102 Status: Offline Sonork: [email protected] Thanks Meter: 93 | rooted phone but same problem any idea again like driver adb or driver spd problem pls help |
09-10-2016, 07:55 | #10 (permalink) | |
09-10-2016, 08:34 | #11 (permalink) |
Member: 2519102 Status: Offline Sonork: [email protected] Thanks Meter: 93 | same problem action reboot pc and root again unit no effect same problem try another pc same result idea again what is the problem pc windows driver or usb cable |
09-11-2016, 08:35 | #12 (permalink) |
No Life Poster Join Date: Feb 2001 Location: PH
Member: 3468 Status: Offline Thanks Meter: 308 | Hi, use kingroot apk here's my log Operation : Read FullFlash [ v1.21 ] 1. Remove battery. Insert battery back 2. Press and hold 'VolumeUp' and 'VolumeDown' keys 3. Insert cable ==== Wait for phone... Phone found! [ 5 ] Port Opened Sync... InitBoot Done [ 0x81 ] , Ver : SPRD3 Sync... Sending FDL [Info] : If SW freeze here more, than 15 seconds - remove cable FDL Ready! Boot Ver : SC7731 Crev eMMC Loader v2.0 Sending FLASH FDL FLASH FDL Ready! Boot Ok! FlashMode Set : Ok! Detected eMMC Flash , Structure detect Ok! [FW_READER] : Step #1 Passed! [FW_READER] : Step #2 Passed! [FW_READER] : Step #3 Passed! Phone found! [ 5 ] Port Opened Sync... InitBoot Done [ 0x81 ] , Ver : SPRD3 Sync... Sending FDL [Info] : If SW freeze here more, than 15 seconds - remove cable FDL Ready! Boot Ver : SC7731 Crev eMMC Loader v2.0 Sending FLASH FDL FLASH FDL Ready! Boot Ok! Model Name : scx20_sp7731cea_fs259_project Model Brand : sprd Model Device: scx20_sp7731cea_fs259 AndrVersion : 5.1 BaseBand CPU: SP7731CEA_FS259 Project Ver : S500TA_MY83DTV_20160520_V1.07 Model Ext : MyPhone my83 DTV [Read Mode] : HSUSB : 0x3000 [FW_READER] : Reading Firmware Now ... [Read Ok] : u-boot-spl-16k.bin [Read Ok] : u-boot.bin [Read Ok] : prodnv.img [Read Ok] : sc7731C_CP0_modem.bin [Read Ok] : DSP_DM_Gx.bin [Read Ok] : nvitem_w.bin [Read Ok] : sc8830g_modem_CP2_Trunk_W15.49.3_Release.bin [Read Ok] : nvitem_wcn.bin [Read Ok] : logo_480x854.bin [Read Ok] : fblogo_320x480.bin [Read Ok] : boot.img [Read Ok] : system.img [Read Ok] : oem.bin [Read Ok] : sysinfo.bin [Read Ok] : cache.img [Read Ok] : recovery.img [Read Ok] : fbootlogo3.bin [Read Ok] : fbootlogo4.bin [Read Ok] : fbootlogo5.bin [Read Ok] : userdata.img AndroidInfo created Firmware Size : 1465 MiB Saved to : C:\InfinityBox\CM2SPD\Read_out\SP7731CEA_FS259_scx 20_sp7731cea_fs259_5.1_S500TA_MY83DTV_20160520_V1. 07_MyPhone_my83_DTV\ Done! Elapsed: 00:13:09 Reconnect Power/Cable! |
09-11-2016, 09:47 | #13 (permalink) |
Member: 2519102 Status: Offline Sonork: [email protected] Thanks Meter: 93 | boss bkit yun akin ayaw padin sa sa root same probz padin bka sa driver ng pc ko anu gamit mu driver palink naman salamat |
09-11-2016, 10:52 | #14 (permalink) |
Member: 2519102 Status: Offline Sonork: [email protected] Thanks Meter: 93 | done problem windows 7 ultimate not sopport starter windows Operation : Read FullFlash [ v1.21 ] 1. Remove battery. Insert battery back 2. Press and hold 'VolumeUp' and 'VolumeDown' keys 3. Insert cable ==== Wait for phone... Phone found! [ 4 ] Port Opened Sync... InitBoot Done [ 0x81 ] , Ver : SPRD3 Sync... Sending FDL [Info] : If SW freeze here more, than 15 seconds - remove cable FDL Ready! Boot Ver : SC7731 Crev eMMC Loader v2.0 Sending FLASH FDL FLASH FDL Ready! Boot Ok! FlashMode Set : Ok! Detected eMMC Flash , Structure detect Ok! [FW_READER] : Step #1 Passed! [FW_READER] : Step #2 Passed! [FW_READER] : Step #3 Passed! Phone found! [ 4 ] Port Opened Sync... InitBoot Done [ 0x81 ] , Ver : SPRD3 Sync... Sending FDL [Info] : If SW freeze here more, than 15 seconds - remove cable FDL Ready! Boot Ver : SC7731 Crev eMMC Loader v2.0 Sending FLASH FDL FLASH FDL Ready! Boot Ok! Model Name : scx20_sp7731cea_fs259_project Model Brand : sprd Model Device: scx20_sp7731cea_fs259 AndrVersion : 5.1 BaseBand CPU: SP7731CEA_FS259 Project Ver : S500TA_MY83DTV_20160520_V1.07 Model Ext : MyPhone my83 DTV [Read Mode] : HSUSB : 0x3000 [FW_READER] : Reading Firmware Now ... [Read Ok] : u-boot-spl-16k.bin [Read Ok] : u-boot.bin [Read Ok] : prodnv.img [Read Ok] : sc7731C_CP0_modem.bin [Read Ok] : DSP_DM_Gx.bin [Read Ok] : nvitem_w.bin [Read Ok] : sc8830g_modem_CP2_Trunk_W15.49.3_Release.bin [Read Ok] : nvitem_wcn.bin [Read Ok] : logo_480x854.bin [Read Ok] : fblogo_320x480.bin [Read Ok] : boot.img [Read Ok] : system.img [Read Ok] : oem.bin [Read Ok] : sysinfo.bin [Read Ok] : cache.img [Read Ok] : recovery.img [Read Ok] : fbootlogo3.bin [Read Ok] : fbootlogo4.bin [Read Ok] : fbootlogo5.bin [Read Ok] : userdata.img AndroidInfo created Firmware Size : 1465 MiB Saved to : C:\Users\Ultimate\Documents\SP7731CEA_FS259_scx20_ sp7731cea_fs259_5.1_S500TA_MY83DTV_20160520_V1.07_ MyPhone_my83_DTV\ Done! Elapsed: 00:12:49 Reconnect Power/Cable! |
