05-21-2020, 07:57 | #1 (permalink) |
Freak Poster Join Date: Mar 2014 Location: sargodha,Pakistan
Member: 2141372 Status: Offline Thanks Meter: 14 | Dongle misconfiguration erorr there is no fault.bin in any folder,i update firmware one time using dongle manger,i see thread with dongle misconfigration erorr and try to solve my problme but it remains same === DongleManager [Infinity] v1.80 [5/21/2020 11:47:59] === Box/Dongle type selected: Infinity-Box/Dongle Card-Reader: FT SCR2000 0 HWID: 0102A6741C6A1292 Box/Dongle found: Infinity-Box/Dongle Reading... Serial No (S/N): D7ADA674 Firmware version: 0143.02 === Process started: 5/21/2020 11:48:02 === Connecting to server Server connection successfully established Checking DongleManager version... Your DongleManager is up-to-date Checking Dongle Identification... Authenticating on server... Authentication stage error: Server answer:[0031] Dongle identification data damaged. Contact to http://www.infinity-box.com/support/?r=2 |
05-21-2020, 11:21 | #3 (permalink) | |
Member: 148515 Status: Offline Thanks Meter: 19,534 | Quote:
fault.bin file should be there. Have you deleted it ? What Infinity software you tried to run last time ? | |
05-21-2020, 11:54 | #4 (permalink) |
Member: 2141372 Status: Offline Thanks Meter: 14 | acctualy my cm2Mtk2 not working ,as i uninstall and reinstall again it works for one or two time,i try to install mtk2 to my laptop and conect cm2 for work but it could not open.i conect again to my pc then it shows dongle configration.now i install a fresh copy of window and install all cm2 software but it shows again dongle misconfigration.all software of cm2 are clean there is no fault.bin file in any folder. |
05-21-2020, 12:11 | #5 (permalink) |
Member: 2141372 Status: Offline Thanks Meter: 14 | in cm2mtk2 folder there is a file name (config)in config file show this ... and cm2 mtk2 folder (fs_external.dll) became 13 kb when i install mtk2 setup its size was 11kb Last edited by InfinityHelp; 05-21-2020 at 12:17. |
05-21-2020, 12:18 | #6 (permalink) | |
if you reinstall windows this means you deleted all files. right ? anyway please double check your pc and find fault.bin fle. do you see it now ? | |
05-21-2020, 13:57 | #8 (permalink) | |
after that update dongle firmware result ? | |
05-22-2020, 10:17 | #10 (permalink) |
Member: 148515 Status: Offline Thanks Meter: 19,534 | Ok, good. Anyway, let me remind you that if you want to use CM2MT2 v2.10 please follow the instruction before run exe - https://www.infinity-box.com/news/?r=3999 |
