07-22-2020, 08:34 | #1 (permalink) |
Freak Poster Join Date: Aug 2010 Location: Jalpur
Member: 1367756 Status: Offline Thanks Meter: 9 | Dongle misconfiguration error 66 Dongle misconfigretion error show WHEN INSERT DONGLE IN PC SHOW MISCONFIGRATION HERE IS LOG Card-Reader: Generic EMV Smartcard Reader 0 ATR: 3B7F96000080318065B0850201F312FFFE829000 Card Manager: A000000018434D00 SerialNumber: 000016A3 ROM: Integrated Circuit Fabricator: 4790 Integrated Circuit Type: 5081 OS: Identifier: 1291 Release Date: 1102 Release Level: 0201 EEPROM: Fabrication Date: 8115 Serial Number: 000016A3 Batch Identifier: 200A Module Fabricator: 4082 Module Packaging Date: 9055 IC Card Manufacturer: 1293 IC Em******* Date: 9055 Pre Personalizer: 5004 Pre Personalization Date: 9055 Pre Personalization Equipment Identifier: 00000047 Personalizer: 0000 Personalization Date: 0000 Personalization Equipment Identifier: 00000000 m_iopCard.Serial: 000016A3200A4082 GP Version: 2.1.1 SCP Version: 1, Option: 5 = DongleManager [Infinity] v1.80 [7/22/2020 7:44:18] === Searching... Card-Reader: Generic EMV Smartcard Reader 0 HWID: 000016A3200A4082 Box/Dongle found: Infinity-Box/Dongle Reading... Serial No (S/N): 203A16A3 Firmware version: 0144.02 === Process started: 7/22/2020 7:44:20 === Connecting to server Server connection successfully established Checking DongleManager version... Your DongleManager is up-to-date Checking Dongle Identification... Authenticating on server... Authentication stage error: Server answer:[0031] Dongle identification data damaged. Contact to http://www.infinity-box.com/support/?r=2 Report Post Reply With Quote |
07-22-2020, 09:38 | #2 (permalink) | |
Member: 1043909 Status: Online Thanks Meter: 60,926 | Quote:
07-22-2020, 12:02 | #4 (permalink) |
Member: 1367756 Status: Offline Thanks Meter: 9 | Dear team I have buy new cm2 dongle work 2 days then this error massage show I have complete uninstall whole software and than install so I have not felt.bin file team please help me |
07-22-2020, 12:13 | #5 (permalink) |
Member: 1367756 Status: Offline Thanks Meter: 9 | Mr yellow boss please help me Sir I have buy new dongle and work only two days if you have take some charges I agree but fix my problem because my work is completely stop hope would you like to solve my problam |
07-22-2020, 15:19 | #6 (permalink) |
Member: 1043909 Status: Online Thanks Meter: 60,926 | It is very bad fault.bin file has an information about problem people who told you to delete fault.bin file was very stupid, you made a big mistake with file possible to solve problem in 1 minute but without file it may takes days do not worry friend, team will help you Download and run Sysinternals Process Explorer - https://docs.microsoft.com/en-us/sys...ocess-explorer Copy/paste list of all running processes. |
07-22-2020, 15:21 | #7 (permalink) |
Member: 1043909 Status: Online Thanks Meter: 60,926 | Sir no need any charges. You have support. Support is free of charge. Just fllow the instruction given by supporters |
07-23-2020, 10:52 | #8 (permalink) |
Member: 1367756 Status: Offline Thanks Meter: 9 | dear yellow sir i am new user you provide me explorer i am giving image as a upload if you possible give me any online software like sonark team viver and solve it its very urgent https://ibb.co/CB4kqnR https://ibb.co/m5Ckrk2 https://ibb.co/Nywb1SV |
07-23-2020, 12:49 | #10 (permalink) |
Member: 148515 Status: Offline Thanks Meter: 19,534 | sir you have used USB SHARING software, it's violation of usage rules ! you must read NOTE here https://www.infinity-box.com/support/?s=2 you delete (or hide from supporters) fault.bin file this file has information about problem reason but you do not give it to us ! now you must read NOTE, confirm that you undertstand the rules. after that copy/past TEXT of running process instead of upload low quality images with zero information |
07-23-2020, 13:44 | #12 (permalink) |
Member: 1367756 Status: Offline Thanks Meter: 9 | Dear team I'm not using sharing tool and nothing hide any thing I have complete uninstall whole setup so icant provide you dalut .bin file if you can not trust sir I will give you any I'd like teamvier ammy admin etc you can chek my system for your kind information other cm2 dongle work my PC perfectly dear team please solve my problem Only use 2 days this dongle so you can understand my problem 🙏🙏🙏🙏🙏🙏🙏🙏 |
07-23-2020, 17:29 | #13 (permalink) |
Member: 148515 Status: Offline Thanks Meter: 19,534 | yes sir, I understand your problem to fix your problem supporters need to get info about your PC config STEP 1: Download and run Sysinternals Process Explorer - https://download.sysinternals.com/fi...ssExplorer.zip STEP 2: Run procexp64.exe STEP 3: go to menu File -> Save STEP 4: Save file STEP 5: Copy/paste file content here now waiting for two things 1. your confirmaton that you read dngle usage rules 2. list of running process as per instruction |
07-23-2020, 22:31 | #14 (permalink) |
Member: 130995 Status: Offline Thanks Meter: 35,227 | @shoaib102 if you don't want to find a soluthin for the problem you can simply ignore all instructions and supporters efforts and update your dongle firmware let's hope we don't see you returned back with the same issue next day |
07-24-2020, 15:59 | #15 (permalink) |
Junior Member Join Date: Mar 2006 Location: Togo
Member: 252143 Status: Offline Thanks Meter: 6 | Hello, i have same problem after buying Infinity-Box/Dongle 2 years Updates Support Renewal Chinese Miracle 2 included (CM2). So i sent my fault.bin file to support ([email protected]). Then am waitting for response!!! Thanks and best regards Last edited by imothep_xp; 07-24-2020 at 16:04. |
