Register | FAQ | Donate | Forum Rules | Root any Device | ★iPhone Unlock★ | [ Easy-JTAG ] | Direct Unlock Source | Search | Today's Posts | Mark Forums Read |
![]() | #1502 (permalink) | |
Junior Member ![]() ![]() Join Date: Sep 2014
Member: 2254630 Status: Offline Thanks Meter: 2 | Quote:
file fault.bin=https://mega.nz/file/y0JX0SYT#vR_UcjD_3SUNLN0tizgoI49FVtU2blSd3s49WVpmU JE | |
![]() | #1504 (permalink) |
Freak Poster ![]() ![]() ![]() ![]() Join Date: Aug 2014 Location: France Age: 33
Member: 2235775 Status: Offline Thanks Meter: 348 | My dongle is not working: Fault File: https://drive.google.com/file/d/1LfE...ew?usp=sharing === DongleManager [Infinity] v1.80 [9/28/2020 13:14:08] === Searching... Card-Reader: Alcor Micro USB Smart Card Reader 0 HWID: 010385681C6A1292 Box/Dongle found: Infinity-Box/Dongle Reading... Serial No (S/N): D0358568 Firmware version: 0145.02 === Process started: 9/28/2020 13:14:10 === Connecting to server Server connection successfully established Checking DongleManager version... Your DongleManager is up-to-date Checking Dongle Identification... Authenticating on server... Authentication stage error: Server answer:[0031] Dongle identification data damaged. Write to https://www.infinity-box.com/support/?r=2 |
![]() | #1505 (permalink) | |
Product Supporter ![]() ![]() ![]() Join Date: May 2005
Member: 148515 Status: Offline Thanks Meter: 19,150 | Quote:
now update dongle with DongleManager then delete fault.bin file then run Infinity software | |
![]() | #1506 (permalink) |
Member: 2235775 Status: Offline Thanks Meter: 348 | === DongleManager [Infinity] v1.80 [10/19/2020 21:30:26] === Box/Dongle type selected: Infinity-Box/Dongle Card-Reader: Alcor Micro USB Smart Card Reader 0 HWID: 010385681C6A1292 Box/Dongle found: Infinity-Box/Dongle Reading... Serial No (S/N): D0358568 Firmware version: 0145.02 === Process started: 10/19/2020 21:30:27 === Connecting to server Server connection successfully established Checking DongleManager version... Your DongleManager is up-to-date Checking Dongle Identification... Authenticating on server... Authentication stage error: Server answer:[0031] Dongle identification data damaged. Write to https://www.infinity-box.com/support/?r=2 Fault file https://drive.google.com/file/d/1LfE...ew?usp=sharing |
![]() | #1507 (permalink) | |
Product Supporter ![]() ![]() ![]() Join Date: Jun 2009
Member: 1043909 Status: Offline Thanks Meter: 59,594 | Quote:
![]() | #1508 (permalink) | |
No Life Poster ![]() ![]() ![]() ![]() ![]() ![]() ![]() Join Date: Oct 2005 Location: iSiddeque Age: 40
Member: 188260 Status: Offline Sonork: 100.1590438 Thanks Meter: 427 | I am facing dongle misconfiguration problem. not found fault.bin Quote:
Need help? | |
![]() | #1509 (permalink) | |
Probably there is a software conflict with the next application(s): C:\program files (x86)\intel\bluetooth\devmonsrv.exe C:\program files (x86)\intel\intel(r) usb 3.0 extensible host controller driver\application\iusb3mon.exe C:\program files\renesas electronics\usb 3.0 host controller driver\application\nusb3mon.exe C:\program files (x86)\nec electronics\usb 3.0 host controller driver\application\nusb3mon.exe C:\program files\via xhci uasp utility\usb3monitor.exe What to do: 1. Delete or rename files (see above) 2. Reboot PC 3. Delete fault.bn file 4. Update dongle firmware with DongleManager now 5. Run Infinity software. | |
![]() | #1510 (permalink) |
Junior Member Join Date: Nov 2007
Member: 637795 Status: Offline Thanks Meter: 2 | help dongle misconfiguration === DongleManager [Infinity] v1.80 [11/2/2020 17:53:07] === Searching... Card-Reader: Gemalto e-gate Smart Card 0 HWID: 0000D71900001942 Box/Dongle found: Infinity-Box/Dongle Serial No (S/N): 78D4D719 Firmware version: 0145.02 Box/Dongle misconfiguration Diagnostic code: 62 "UK Edition" status: Off Last launched Application: 0030 v.0145 => Activations: - 00: Infinity-Box/Dongle v0145 - 07: #7 => Options: - Infinity-Box/Dongle - Infinity SM |
![]() | #1511 (permalink) | |
Why do you use debugger and other crack tools with Infinity software ? | |
![]() | #1512 (permalink) |
Member: 637795 Status: Offline Thanks Meter: 2 | no please no crack softwares. i have added link to fault.bin file. the box was working correctly and i have active support. i just plugged it into my laptop to service an itel p15 phone and it would not open the software. i tired to update and i got that error here is link to fault.bin https://mega.nz/file/6k4mEIbY#A8R1YN...eyqRix7RztctLA |
![]() | #1513 (permalink) | |
Update dongle firmware now delete fault.bin file now you can run Infinity software | |
