05-21-2020, 14:11 | #1411 (permalink) | |
Member: 148515 Status: Offline Thanks Meter: 19,534 | Quote:
There is a software conflict with this application: \program files\avast software\avast\aswidsagent.exe Disable AVAST, delete fault.bn file and run Infinity software. Team is working to fix this compatibility issue. | |
05-21-2020, 14:12 | #1412 (permalink) | |
\program files\renesas electronics\usb 3.0 host controller driver\application\nusb3mon.exe - Disable this process - delete fault.bn file - update dongle firmware with DongleManager now and then run Infinity software. Team is working to fix this compatibility issue. | |
05-21-2020, 14:14 | #1413 (permalink) | |
Member: 148515 Status: Offline Thanks Meter: 19,534 | Quote: \program files\renesas electronics\usb 3.0 host controller driver\application\nusb3mon.exe - Disable this process - delete fault.bn file - update dongle firmware with DongleManager now and then run Infinity software. Team is working to fix this compatibility issue. | |
05-21-2020, 14:41 | #1414 (permalink) |
Junior Member Join Date: May 2005 Location: Minsk Age: 55
Member: 145991 Status: Offline Thanks Meter: 1 | === DongleManager [Infinity] v1.80 [21.05.2020 16:16:20] === Box/Dongle type selected: Infinity-Box/Dongle Card-Reader: Alcor Micro USB Smart Card Reader 0 HWID: 0001FAD1FF021982 Box/Dongle found: Infinity-Box/Dongle Reading... Serial No (S/N): 2105FAD1 Firmware version: 0143.02 === Process started: 21.05.2020 16:16:23 === Connecting to server Server connection successfully established Checking DongleManager version... Your DongleManager is up-to-date Checking Dongle Identification... Authenticating on server... Authentication stage error: Server answer:[0031] Dongle identification data damaged. Contact to http://www.infinity-box.com/support/?r=2 |
05-21-2020, 15:20 | #1415 (permalink) | |
There is a software conflict with this application: \program files (x86)\nec electronics\usb 3.0 host controller driver\application\nusb3mon.exe - Disable this process - delete fault.bn file - update dongle firmware with DongleManager now and then run Infinity software. Team is working to fix this compatibility issue. | |
05-22-2020, 08:07 | #1416 (permalink) |
Freak Poster Join Date: Jul 2007
Member: 540932 Status: Offline Thanks Meter: 36 | after installing new update 2.10 i face this problem delete fault.bin uninstall software reinstall software update dongle but problem not solved read serial no and updating logs === DongleManager [Infinity] v1.80 [5/22/2020 12:06:00] === Searching... Card-Reader: FT SCR2000 0 HWID: 0003657401171292 Box/Dongle found: [BEST] Serial No (S/N): 117B6574 Firmware version: 0122.02 Box/Dongle misconfiguration Diagnostic code: 70 "UK Edition" status: Off Last launched Application: 0030 v.0143 => Activations: - 00: Infinity-Box/Dongle v0143 - 03: [BEST] v0122 - 06: #6 - 07: #7 => Options: - Infinity BEST - Infinity SM - spt === DongleManager [Infinity] v1.80 [5/22/2020 11:56:28] === Box/Dongle type selected: [BEST] Card-Reader: FT SCR2000 0 HWID: 0003657401171292 Box/Dongle found: [BEST] Reading... Serial No (S/N): 117B6574 Firmware version: 0122.02 === Process started: 5/22/2020 11:56:30 === Connecting to server Server connection successfully established Checking DongleManager version... Your DongleManager is up-to-date Checking Dongle Identification... Authenticating on server... Authentication stage error: Server answer:[0031] Dongle identification data damaged. Contact to http://www.infinity-box.com/support/?r=2 |
05-22-2020, 08:39 | #1418 (permalink) |
No Life Poster Join Date: Mar 2006 Location: PAKISTAN/MULTAN
Member: 242838 Status: Offline Thanks Meter: 83 | My BEST Dongle not working i Tried to update with Dongle manger now i m Facing this Problem kindly help me in this matter here is Log === DongleManager [Infinity] v1.80 [5/22/2020 12:03:39] === Box/Dongle type selected: [BEST] Card-Reader: FT SCR2000 0 HWID: 0102976910321292 === Process started: 5/22/2020 12:03:39 === Connecting to server Server connection successfully established Checking DongleManager version... Your DongleManager is up-to-date Checking Dongle Identification... Authenticating on server... Authentication stage error: Server answer:[0010] Dongle Authentication fail. Probably last attempt was interrupted or wrong Smart-Card connected. Contact to http://www.infinity-box.com/support/?r=2 THANKS IN ADVANCE INFINITY TEAM |
05-22-2020, 10:28 | #1419 (permalink) | |
Now update PC as per instruction - https://www.infinity-box.com/news/?r=3999 After that update dongle firmware with DongleManager to fix "misconfiguration" message | |
05-22-2020, 10:29 | #1421 (permalink) | |
Install required Card-Reader Drivers: - File with Drivers: CardReader_Fetian_FT2K.7z - File with Instruction: Infinity-Box_How_to_update_FT_SCR2000_CardReader_drivers.pd f Drivers version after installation should be 2.5.6.0823 or 2.5.9.1202 Download files - https://www.infinity-box.com/support/?r=6 OR Insert Smart-Card into another Card-Reader (good result for today is with Alcor Card-Reader) The next steps are: - run DongleManager - update Dongle firmware IMPORTANT: only ONE update try is allowed so in case of problem DO NOT try to update card again ! | |
06-07-2020, 10:41 | #1422 (permalink) |
No Life Poster Join Date: Jan 2015 Location: Narsingdi, Dhaka, Bangladesh Age: 28
Member: 2325851 Status: Offline Sonork: 100.1680491 Thanks Meter: 2,363 | please help sir smart-card misconfiguration! contact to support! === DongleManager [Infinity] v1.80 [6/7/2020 15:38:15] === Searching... Card-Reader: Generic EMV Smartcard Reader 1 HWID: 0001013313114082 Box/Dongle found: Infinity-Box/Dongle Serial No (S/N): 92570133 Firmware version: 0143.02 Box/Dongle misconfiguration Diagnostic code: FF "UK Edition" status: Off Last launched Application: 0000 v.0000 => Activations: - 00: Infinity-Box/Dongle v0000 - 07: #7 => Box/Dongle misconfiguration. Contact to support ! |
06-07-2020, 12:52 | #1423 (permalink) | |
Update card now | |
06-08-2020, 06:14 | #1425 (permalink) | |
Member: 2325851 Status: Offline Sonork: 100.1680491 Thanks Meter: 2,363 | Quote:
=== DongleManager [Infinity] v1.80 [6/8/2020 11:13:25] === Box/Dongle type selected: Infinity-Box/Dongle Card-Reader: Generic EMV Smartcard Reader 1 HWID: 0001013313114082 Box/Dongle found: Infinity-Box/Dongle Reading... Serial No (S/N): 92570133 Firmware version: 0143.02 === Process started: 6/8/2020 11:13:26 === Connecting to server Server connection successfully established Checking DongleManager version... Your DongleManager is up-to-date Checking Dongle Identification... Authenticating on server... Authentication stage error: Server answer:[0031] Dongle identification data damaged. Contact to http://www.infinity-box.com/support/?r=2 | |
