03-10-2016, 11:39 | #1 (permalink) |
No Life Poster Join Date: Jul 2002 Location: sri lanka Age: 39
Member: 13932 Status: Offline Sonork: 100.1609876 Thanks Meter: 411 | SC7731 firmware error.. Code: ==== Wait for phone... Phone found! [ 34 ] Port Opened Sync... InitBoot Done [ 0x81 ] , Ver : SPRD3 Sync... Sending FDL [Info] : If SW freeze here more, than 15 seconds - remove cable FDL Ready! Boot Ver : SC773x eMMC v2.0 Loader Infinity Sending FLASH FDL FLASH FDL Ready! Boot Ok! FLASH : eMMC Flash , Structure : Ok! Reading extended info ... Model Name : A1000 Model Brand : Lenovo Model Device: A1000 AndrVersion : 5.0 BaseBand CPU: A1000 CompileDate : 9/6/2015 3:36:52 AM Project Ver : A1000_USR_S26632_1509061131_SPRD7731_ROW Model Ext : Lenovo A1000 ExtraInfo : HWInfo not exists, normal phone ExtraInfo : GSM Phone Elapsed: 00:00:13 PAC file size is 2.45GB |
The Following User Says Thank You to iqballk For This Useful Post: |
03-11-2016, 12:43 | #3 (permalink) |
Member: 13932 Status: Offline Sonork: 100.1609876 Thanks Meter: 411 | Code: Operation : Flash [ v1.16 ] ======= Flash Files set for flashing : [ MCU ] : A1000_USR_S29644_1510281850_SPRD7731_SINGLE_ROW.pac CRVersion : BP_R1.0.0 PacCPUinfo : SC77xx PacVersion : A1000_USR_S29644_1510281850_SPRD7731_SINGLE_ROW File : fdl1.bin File : fdl2.bin File : nvitem.bin File : nvitem_wcn.bin File : u-boot-spl-16k.bin File : SC7702_sc7731g_band128.bin File : DSP_DM_G2.bin File : SC8800G_x30g_wcn_dts_modem.bin File : boot.img File : recovery.img File : system.img File : userdata.img File : boot_logo.bmp File : boot_logo.bmp File : prodnv.img File : cache.img File : u-boot.bin File : oem.img 1. Remove battery. Insert battery back 2. Press and hold 'VolumeUp' and 'VolumeDown' keys 3. Insert cable ==== Wait for phone... Phone found! [ 34 ] Port Opened Sync... InitBoot Done [ 0x81 ] , Ver : SPRD3 Sync... Sending FDL [Info] : If SW freeze here more, than 15 seconds - remove cable PickUp loaders from pac FDL Ready! Boot Ver : Spreadtrum Boot Block version 1.1 Sending FLASH FDL FLASH FDL Ready! Boot Ok! FlashMode Set : Ok! PMTManager : Load 0x18 records PMTManager : PMT Update Ok! Flashing now [FlashProc] : ERASE Current ID : ERASEUBOOT Current Part : uboot [FlashProc] : Ok! [FlashProc] : BOOTCODE Current ID : SPLLOADER Current File : u-boot-spl-16k.bin Flashing now ... [FlashProc] : Ok! [FlashProc] : CODE Current ID : MODEM_W Current File : SC7702_sc7731g_band128.bin Flashing now ... [FlashProc] : Ok! [FlashProc] : CODE Current ID : DSP_W Current File : DSP_DM_G2.bin Flashing now ... [FlashProc] : Ok! [FlashProc] : CODE Current ID : MODEM_WCN Current File : SC8800G_x30g_wcn_dts_modem.bin Flashing now ... [FlashProc] : Ok! [FlashProc] : CODE Current ID : BOOT Current File : boot.img Flashing now ... [FlashProc] : Ok! [FlashProc] : CODE Current ID : RECOVERY Current File : recovery.img Flashing now ... [FlashProc] : Ok! [FlashProc] : IMAGE Current ID : SYSTEM Current File : system.img Flashing now ... [FlashProc] : Error with code 0x0002 |
03-11-2016, 17:25 | #4 (permalink) |
Member: 462970 Status: Offline Thanks Meter: 20,352 | Alive by HW A1000 log : Code: Operation : Flash [ v1.16 ] ======= Flash Files set for flashing : [ MCU ] : A1000_USR_S29576_1510212227_SPRD7731_ROW.pac CRVersion : BP_R1.0.0 PacCPUinfo : SC77xx PacVersion : A1000_USR_S29576_1510212227_SPRD7731_ROW File : fdl1.bin File : fdl2.bin File : nvitem.bin File : nvitem_wcn.bin File : u-boot-spl-16k.bin File : SC7702_sc7731g_band128.bin File : DSP_DM_G2.bin File : SC8800G_x30g_wcn_dts_modem.bin File : boot.img File : recovery.img File : system.img File : userdata.img File : boot_logo.bmp File : boot_logo.bmp File : prodnv.img File : cache.img File : u-boot.bin File : oem.img 1. Remove battery. Insert battery back 2. Press and hold 'VolumeUp' and 'VolumeDown' keys 3. Insert cable ==== Wait for phone... Phone found! [ 5 ] Port Opened Sync... InitBoot Done [ 0x81 ] , Ver : SPRD3 Sync... Sending FDL [Info] : If SW freeze here more, than 15 seconds - remove cable PickUp loaders from pac FDL Ready! Boot Ver : Spreadtrum Boot Block version 1.1 Sending FLASH FDL FLASH FDL Ready! Boot Ok! FlashMode Set : Ok! PMTManager : Load 0x18 records PMTManager : PMT Update Ok! Flashing now [FlashProc] : ERASE Current ID : ERASEUBOOT Current Part : uboot [FlashProc] : Ok! [FlashProc] : BOOTCODE Current ID : SPLLOADER Current File : u-boot-spl-16k.bin Flashing now ... [FlashProc] : Ok! [FlashProc] : CODE Current ID : MODEM_W Current File : SC7702_sc7731g_band128.bin Flashing now ... [FlashProc] : Ok! [FlashProc] : CODE Current ID : DSP_W Current File : DSP_DM_G2.bin Flashing now ... [FlashProc] : Ok! [FlashProc] : CODE Current ID : MODEM_WCN Current File : SC8800G_x30g_wcn_dts_modem.bin Flashing now ... [FlashProc] : Ok! [FlashProc] : CODE Current ID : BOOT Current File : boot.img Flashing now ... [FlashProc] : Ok! [FlashProc] : CODE Current ID : RECOVERY Current File : recovery.img Flashing now ... [FlashProc] : Ok! [FlashProc] : IMAGE Current ID : SYSTEM Current File : system.img Flashing now ... [FlashProc] : Ok! [FlashProc] : IMAGE Current ID : USERDATA Current File : userdata.img Flashing now ... [FlashProc] : Ok! [FlashProc] : CODE Current ID : BOOTLOGO Current File : boot_logo.bmp Flashing now ... [FlashProc] : Ok! [FlashProc] : CODE Current ID : FASTBOOT_LOGO Current File : boot_logo.bmp Flashing now ... [FlashProc] : Ok! [FlashProc] : ERASE Current ID : FLASH Current Part : wruntimenv1 [FlashProc] : Ok! [FlashProc] : ERASE Current ID : FLASH_WCN Current Part : wcnruntimenv1 [FlashProc] : Ok! [FlashProc] : CODE Current ID : PRODNV Current File : prodnv.img Flashing now ... [FlashProc] : Ok! [FlashProc] : IMAGE Current ID : CACHE Current File : cache.img Flashing now ... [FlashProc] : Ok! [FlashProc] : ERASE Current ID : ERASEMISC Current Part : misc [FlashProc] : Ok! [FlashProc] : BOOTCODE Current ID : UBOOTLOADER Current File : u-boot.bin Flashing now ... [FlashProc] : Ok! [FlashProc] : IMAGE Current ID : OEM Current File : oem.img Flashing now ... [FlashProc] : Ok! Elapsed: 00:08:13 Reconnect Power/Cable! |
10-04-2016, 23:45 | #6 (permalink) |
Junior Member Join Date: Aug 2015 Location: South africa
Member: 2448481 Status: Offline Thanks Meter: 3 | sm-g920 cert write done 100% BACKUP INSTRUCTIONS: Phone must be rooted! If the software can't root the phone automatically, then you must root your device manually. 1. Power on the phone. 2. Tap 7 times on 'Build number' in 'Settings'-'About phone' to enable 'Developer options', go to 'Settings'-'Developer options' and enable 'USB debugging'. 3. Connect the phone to PC with USB cable, install drivers if needed. 4. Select device in ADB settings. 5. Press 'Read EFS' button to read backup or 'Write EFS' to restore. 6. Press 'Read CERT' button to read certificates or 'Write CERT' to restore. 7. Press 'Write NV DATA' if you need to restore NV backup. Operation: Write CERT Selected model: SM-G928C Software version: 26.9 Waiting ADB device... Please, allow USB debugging on phone... OK Reading phone info... Model: SM-G928C Android version: 6.0.1 Product code: SM-G928CZKAXFA Phone version: G928FXXU2BPDA PDA version: G928CXXU2BPDB CSC version: G928COJV2BPDA CSC country code: SOUTH AFRICA CSC sales code: XFA HW version: MP 0.500 Phone SN: R58G80MY9DT Modem board: SHANNON333 RF cal date: 20150811 IMEI: Checking Super user right... true Initialization zTool... OK Running zTool, please wait... Start... OK Initialization... OK Generate and check client proof... OK Verify proof by client... OK Reading data... OK HWID: 48 10 AB 1F D4 07 00 00 00 00 00 00 00 00 00 00 Initialization AT RIL... AT RIL stopped, restarting... Checking for compatible phone and cert Phone KEY ID: 0784 Checking certificate file... OK KEY ID: 0784 Reading NV data... OK Checking NV data... OK Calculating... OK Crypting CERT 1... OK Writing NV data... OK Rebooting phone... OK Write CERT done Done with Samsung Tool PRO v.26.9 |
